Jun 15 20:41:44 mint kernel: [ 150.735122] pci 0000:06:00.0: [8086:15d3] type 01 class 0x060400
Jun 15 20:41:44 mint kernel: [ 150.735226] pci 0000:06:00.0: enabling Extended Tags
Jun 15 20:41:44 mint kernel: [ 150.735956] pci 0000:06:00.0: supports D1 D2
Jun 15 20:41:44 mint kernel: [ 150.735963] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 15 20:41:44 mint kernel: [ 150.741331] pci 0000:07:00.0: [8086:15d3] type 01 class 0x060400
Jun 15 20:41:44 mint kernel: [ 150.741444] pci 0000:07:00.0: enabling Extended Tags
Jun 15 20:41:44 mint kernel: [ 150.741662] pci 0000:07:00.0: supports D1 D2
Jun 15 20:41:44 mint kernel: [ 150.741670] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 15 20:41:44 mint kernel: [ 150.744001] pci 0000:07:01.0: [8086:15d3] type 01 class 0x060400
Jun 15 20:41:44 mint kernel: [ 150.744119] pci 0000:07:01.0: enabling Extended Tags
Jun 15 20:41:44 mint kernel: [ 150.744331] pci 0000:07:01.0: supports D1 D2
Jun 15 20:41:44 mint kernel: [ 150.744339] pci 0000:07:01.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 15 20:41:44 mint kernel: [ 150.745263] pci 0000:07:02.0: [8086:15d3] type 01 class 0x060400
Jun 15 20:41:44 mint kernel: [ 150.745380] pci 0000:07:02.0: enabling Extended Tags
Jun 15 20:41:44 mint kernel: [ 150.745577] pci 0000:07:02.0: supports D1 D2
Jun 15 20:41:44 mint kernel: [ 150.745584] pci 0000:07:02.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 15 20:41:44 mint kernel: [ 150.746837] pci 0000:07:04.0: [8086:15d3] type 01 class 0x060400
Jun 15 20:41:44 mint kernel: [ 150.746954] pci 0000:07:04.0: enabling Extended Tags
Jun 15 20:41:44 mint kernel: [ 150.747156] pci 0000:07:04.0: supports D1 D2
Jun 15 20:41:44 mint kernel: [ 150.747165] pci 0000:07:04.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 15 20:41:44 mint kernel: [ 150.750758] pci 0000:06:00.0: PCI bridge to [bus 07-70]
Jun 15 20:41:44 mint kernel: [ 150.750790] pci 0000:06:00.0: bridge window [mem 0xe0000000-0xe01fffff]
Jun 15 20:41:44 mint kernel: [ 150.750809] pci 0000:06:00.0: bridge window [mem 0xac800000-0xac9fffff 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.751072] pci 0000:07:00.0: PCI bridge to [bus 08]
Jun 15 20:41:44 mint kernel: [ 150.751095] pci 0000:07:00.0: bridge window [mem 0xe0100000-0xe01fffff]
Jun 15 20:41:44 mint kernel: [ 150.751245] pci 0000:07:01.0: PCI bridge to [bus 09-3b]
Jun 15 20:41:44 mint kernel: [ 150.751594] pci 0000:3c:00.0: [8086:15d4] type 00 class 0x0c0330
Jun 15 20:41:44 mint kernel: [ 150.751648] pci 0000:3c:00.0: reg 0x10: [mem 0xe0000000-0xe000ffff]
Jun 15 20:41:44 mint kernel: [ 150.751783] pci 0000:3c:00.0: enabling Extended Tags
Jun 15 20:41:44 mint kernel: [ 150.752017] pci 0000:3c:00.0: supports D1 D2
Jun 15 20:41:44 mint kernel: [ 150.752026] pci 0000:3c:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Jun 15 20:41:44 mint kernel: [ 150.752175] pci 0000:3c:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:07:02.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
Jun 15 20:41:44 mint kernel: [ 150.771795] pci 0000:07:02.0: PCI bridge to [bus 3c]
Jun 15 20:41:44 mint kernel: [ 150.771827] pci 0000:07:02.0: bridge window [mem 0xe0000000-0xe00fffff]
Jun 15 20:41:44 mint kernel: [ 150.784854] pci 0000:07:04.0: PCI bridge to [bus 3d-70]
Jun 15 20:41:44 mint kernel: [ 150.784942] pci_bus 0000:07: Allocating resources
Jun 15 20:41:44 mint kernel: [ 150.784981] pci 0000:07:01.0: bridge window [io 0x1000-0x0fff] to [bus 09-3b] add_size 1000
Jun 15 20:41:44 mint kernel: [ 150.784994] pci 0000:07:01.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 09-3b] add_size 200000 add_align 100000
Jun 15 20:41:44 mint kernel: [ 150.785009] pci 0000:07:01.0: bridge window [mem 0x00100000-0x000fffff] to [bus 09-3b] add_size 200000 add_align 100000
Jun 15 20:41:44 mint kernel: [ 150.785021] pci 0000:07:02.0: bridge window [io 0x1000-0x0fff] to [bus 3c] add_size 1000
Jun 15 20:41:44 mint kernel: [ 150.785032] pci 0000:07:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3c] add_size 200000 add_align 100000
Jun 15 20:41:44 mint kernel: [ 150.785044] pci 0000:07:04.0: bridge window [io 0x1000-0x0fff] to [bus 3d-70] add_size 1000
Jun 15 20:41:44 mint kernel: [ 150.785054] pci 0000:07:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3d-70] add_size 200000 add_align 100000
Jun 15 20:41:44 mint kernel: [ 150.785065] pci 0000:07:04.0: bridge window [mem 0x00100000-0x000fffff] to [bus 3d-70] add_size 200000 add_align 100000
Jun 15 20:41:44 mint kernel: [ 150.785078] pci 0000:06:00.0: bridge window [io 0x1000-0x0fff] to [bus 07-70] add_size 4000
Jun 15 20:41:44 mint kernel: [ 150.785103] pci 0000:06:00.0: BAR 13: assigned [io 0x2000-0x2fff]
Jun 15 20:41:44 mint kernel: [ 150.785124] pci 0000:07:01.0: BAR 14: no space for [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785134] pci 0000:07:01.0: BAR 14: failed to assign [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785148] pci 0000:07:01.0: BAR 15: assigned [mem 0xac800000-0xac9fffff 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785161] pci 0000:07:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785170] pci 0000:07:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785179] pci 0000:07:04.0: BAR 14: no space for [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785186] pci 0000:07:04.0: BAR 14: failed to assign [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785197] pci 0000:07:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785206] pci 0000:07:04.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785216] pci 0000:07:01.0: BAR 13: assigned [io 0x2000-0x2fff]
Jun 15 20:41:44 mint kernel: [ 150.785225] pci 0000:07:02.0: BAR 13: no space for [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785233] pci 0000:07:02.0: BAR 13: failed to assign [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785243] pci 0000:07:04.0: BAR 13: no space for [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785251] pci 0000:07:04.0: BAR 13: failed to assign [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785268] pci 0000:07:04.0: BAR 14: no space for [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785276] pci 0000:07:04.0: BAR 14: failed to assign [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785288] pci 0000:07:04.0: BAR 15: assigned [mem 0xac800000-0xac9fffff 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785299] pci 0000:07:04.0: BAR 13: assigned [io 0x2000-0x2fff]
Jun 15 20:41:44 mint kernel: [ 150.785311] pci 0000:07:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785319] pci 0000:07:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785329] pci 0000:07:02.0: BAR 13: no space for [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785337] pci 0000:07:02.0: BAR 13: failed to assign [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785345] pci 0000:07:01.0: BAR 14: no space for [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785354] pci 0000:07:01.0: BAR 14: failed to assign [mem size 0x00200000]
Jun 15 20:41:44 mint kernel: [ 150.785366] pci 0000:07:01.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785376] pci 0000:07:01.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785385] pci 0000:07:01.0: BAR 13: no space for [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785393] pci 0000:07:01.0: BAR 13: failed to assign [io size 0x1000]
Jun 15 20:41:44 mint kernel: [ 150.785405] pci 0000:07:00.0: PCI bridge to [bus 08]
Jun 15 20:41:44 mint kernel: [ 150.785420] pci 0000:07:00.0: bridge window [mem 0xe0100000-0xe01fffff]
Jun 15 20:41:44 mint kernel: [ 150.785444] pci 0000:07:01.0: PCI bridge to [bus 09-3b]
Jun 15 20:41:44 mint kernel: [ 150.785472] pci 0000:07:02.0: PCI bridge to [bus 3c]
Jun 15 20:41:44 mint kernel: [ 150.785485] pci 0000:07:02.0: bridge window [mem 0xe0000000-0xe00fffff]
Jun 15 20:41:44 mint kernel: [ 150.785506] pci 0000:07:04.0: PCI bridge to [bus 3d-70]
Jun 15 20:41:44 mint kernel: [ 150.785515] pci 0000:07:04.0: bridge window [io 0x2000-0x2fff]
Jun 15 20:41:44 mint kernel: [ 150.785534] pci 0000:07:04.0: bridge window [mem 0xac800000-0xac9fffff 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785551] pci 0000:06:00.0: PCI bridge to [bus 07-70]
Jun 15 20:41:44 mint kernel: [ 150.785559] pci 0000:06:00.0: bridge window [io 0x2000-0x2fff]
Jun 15 20:41:44 mint kernel: [ 150.785572] pci 0000:06:00.0: bridge window [mem 0xe0000000-0xe01fffff]
Jun 15 20:41:44 mint kernel: [ 150.785585] pci 0000:06:00.0: bridge window [mem 0xac800000-0xac9fffff 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.785601] pcieport 0000:00:1d.0: PCI bridge to [bus 06-70]
Jun 15 20:41:44 mint kernel: [ 150.785611] pcieport 0000:00:1d.0: bridge window [io 0x2000-0x2fff]
Jun 15 20:41:44 mint kernel: [ 150.785622] pcieport 0000:00:1d.0: bridge window [mem 0xe0000000-0xe01fffff]
Jun 15 20:41:44 mint kernel: [ 150.785633] pcieport 0000:00:1d.0: bridge window [mem 0xac800000-0xac9fffff 64bit pref]
Jun 15 20:41:44 mint kernel: [ 150.786907] pcieport 0000:06:00.0: enabling device (0006 -> 0007)
Jun 15 20:41:44 mint kernel: [ 150.809547] pcieport 0000:07:04.0: enabling device (0006 -> 0007)
Jun 15 20:41:44 mint kernel: [ 150.811425] xhci_hcd 0000:3c:00.0: xHCI Host Controller
Jun 15 20:41:44 mint kernel: [ 150.811451] xhci_hcd 0000:3c:00.0: new USB bus registered, assigned bus number 3
Jun 15 20:41:44 mint kernel: [ 150.813090] xhci_hcd 0000:3c:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
Jun 15 20:41:44 mint kernel: [ 150.813871] xhci_hcd 0000:3c:00.0: xHCI Host Controller
Jun 15 20:41:44 mint kernel: [ 150.813890] xhci_hcd 0000:3c:00.0: new USB bus registered, assigned bus number 4
Jun 15 20:41:44 mint kernel: [ 150.813903] xhci_hcd 0000:3c:00.0: Host supports USB 3.1 Enhanced SuperSpeed
Jun 15 20:41:44 mint kernel: [ 150.814087] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
Jun 15 20:41:44 mint kernel: [ 150.814100] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 15 20:41:44 mint kernel: [ 150.814108] usb usb3: Product: xHCI Host Controller
Jun 15 20:41:44 mint kernel: [ 150.814115] usb usb3: Manufacturer: Linux 5.15.0-91-generic xhci-hcd
Jun 15 20:41:44 mint kernel: [ 150.814121] usb usb3: SerialNumber: 0000:3c:00.0
Jun 15 20:41:44 mint kernel: [ 150.814738] hub 3-0:1.0: USB hub found
Jun 15 20:41:44 mint kernel: [ 150.814771] hub 3-0:1.0: 2 ports detected
Jun 15 20:41:44 mint kernel: [ 150.818311] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
Jun 15 20:41:44 mint kernel: [ 150.818326] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 15 20:41:44 mint kernel: [ 150.818335] usb usb4: Product: xHCI Host Controller
Jun 15 20:41:44 mint kernel: [ 150.818342] usb usb4: Manufacturer: Linux 5.15.0-91-generic xhci-hcd
Jun 15 20:41:44 mint kernel: [ 150.818348] usb usb4: SerialNumber: 0000:3c:00.0
Jun 15 20:41:44 mint kernel: [ 150.818850] hub 4-0:1.0: USB hub found
Jun 15 20:41:44 mint kernel: [ 150.818896] hub 4-0:1.0: 2 ports detected
Jun 15 20:41:46 mint kernel: [ 151.990119] usb usb3-port2: Cannot enable. Maybe the USB cable is bad?
Jun 15 20:41:46 mint kernel: [ 152.958112] usb usb3-port2: Cannot enable. Maybe the USB cable is bad?
Jun 15 20:41:46 mint kernel: [ 152.958317] usb usb3-port2: attempt power cycle
Jun 15 20:41:48 mint kernel: [ 154.250092] usb usb3-port2: Cannot enable. Maybe the USB cable is bad?
Jun 15 20:41:49 mint kernel: [ 155.218118] usb usb3-port2: Cannot enable. Maybe the USB cable is bad?
Jun 15 20:41:49 mint kernel: [ 155.218243] usb usb3-port2: unable to enumerate USB device
