Welcher CPU passt maximal in meinen SL500??
Santana45
3 Okt. 2009
[font='Comic Sans MS, sans-serif']Hallo an alle,
in meinem SL 500 werkelt ein T3000 seinen Dienst runter,
weiß jemand genau bis zu welchem Proz. ich aufrüsten kann??
Danke im Vorraus![/font]
[font='Comic Sans MS, sans-serif']PS: Chipsatz Mobile Intel(R) 4 Series Express Chipset Family[/font] Essentials Status Launched Launch Date Q2'09 Processor Number T3000 # of Cores 2 # of Threads 2 Clock Speed 1.8 GHz L2 Cache 1 MB FSB Speed 800 MHz Instruction Set 64-bit Embedded Options Available No Supplemental SKU Yes Lithography 45 nm Max TDP 35 W VID Voltage Range 1.000V-1.250V Graphics Specifications Integrated Graphics No Package Specifications TCASE 105C Package Size 35mm x 35mm Processing Die Size 107 mm2 # of Processing Die Transistors 410 million Sockets Supported PGA478 Halogen Free Options Available Yes
Advanced Technologies Intel® Turbo Boost Technology No Intel® Hyper-Threading Technology No Intel® Virtualization Technology (VT-x) No Intel® Trusted Execution Technology No Intel® 64 Yes Enhanced Intel® Speedstep Technology No Intel® Demand Based Switching No Execute Disable Bit Yes
Additional Information
Buy Now
PCN/MDDS
SLGMY
901174: PCN | MDDS
Send feedback on PCN or MDDS links IntelQDMS@pcnalert.com Platform Information
No Associated Platforms
Ordering & Sampling Information
Product Name Socket Step Step TDP Ordering Code SPEC Code Halogen Free VT-x Intel® Celeron® Processor T3000 (1M Cache, 1.80 GHz, 800 MHz FSB) uFCPBGA, Tray PGA478 R0 35 Watts AW80577GG0331ML SLGMY Yes No
Retired & Discontinued
None Available
Enabling Execute Disable Bit functionality requires a PC with a processor with Execute Disable Bit capability and a supporting operating system. Check with your PC manufacturer on whether your system delivers Execute Disable Bit functionality.
64-bit computing on Intel® architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers and applications enabled for Intel® 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Consult with your system vendor for more information.
Hyper-Threading Technology (HT Technology) requires a computer system with an Intel® processor supporting HT Technology and an HT Technology enabled chipset, BIOS and operating system. Performance will vary depending on the specific hardware and software you use. See www.intel.com/products/ht/hyperthreading_more.htm for more information including details on which processors support HT Technology.
Intel® Virtualization Technology requires a computer system with a processor, chipset, BIOS, virtual machine monitor (VMM) and for some uses, certain platform software, enabled for it. Functionality, performance or other benefit will vary depending on hardware and software configurations. Intel Virtualization Technology-enabled VMM applications are currently in development.
Note: Prices subject to change without notice. Prices are for direct Intel customers in 1000-unit bulk quantities and, unless specified, represent the latest technology versions of the products. Taxes and shipping, etc. not included. Prices may vary for other package types and shipment quantities, and special promotional arrangements may apply.
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families. See http://www.intel.com/products/processor_number for details.
System and Maximum TDP is based on worst case scenarios. Actual TDP may be lower if not all I/Os for chipsets are used.
All information provided is subject to change at any time, without notice. Intel may make changes to manufacturing life cycle, specifications, and product descriptions at any time, without notice. The information herein is provided "as-is" and Intel does not make any representations or warranties whatsoever regarding accuracy of the information, nor on the product features, availability, functionality, or compatibility of the products listed. Please contact system vendor for more information on specific products or systems.
Halogen Free implies the following:
Bromine and/or chlorine in materials that may be used during processing, but do not remain within the final product are not included in this definition. The halogens fluorine (F), iodine (I), and astatine (At) are not restricted by this standard.
“BFR/CFR and PVC-Free” Definition:
An article must meet all of the following requirements to be defined as “BFR/CFR and PVC-Free”:
  1. All PCB laminates must meet Br and Cl requirements for low halogen as defined in IPC-4101B
  2. For components other than PCB laminates, all homogeneous materials must contain < 900 ppm (0.09%) of Bromine [if the Bromine (Br) source is from BFRs] and < 900 ppm (0.09%) of Chlorine [if the Chlorine (Cl) source is from CFRs or PVC. Higher concentrations of Br and Cl are allowed in homogenous materials of components other than PCB laminates as long as their sources are not BFRs, CFRs, PVC.
  3. Although the elemental analysis for Br and Cl in homogeneous materials can be performed by any analytical method with sufficient sensitivity and selectivity, the presence or absence of BFRs, CFRs or PVC must be verified by any acceptable analytical techniques that allow for the unequivocal identification of the specific Br or Cl compounds, or by appropriate material declarations agreed to between customer and supplier.
    Max Turbo Frequency refers to the maximum single-core frequency that can be achieved with Intel® Turbo Boost Technology, which requires a PC with a processor with Intel Turbo Boost Technology capability. Intel Turbo Boost Technology performance varies depending on hardware, software, and overall system configuration. Check with your PC manufacturer on whether your system delivers Intel Turbo Boost Technology. See www.intel.com/technology/turboboost/ for more information.
    ?( :huh:
Lenovo nennt vorerst als verfügbare zentrale Recheneinheiten eine T5670 CPU (1.8 GHz, 2MB l2-Cache, 800 MHz FSB, 35W TDP), ein T5870 Kern (2.0 GHz, 2MB l2-Cache, 800 MHz FSB, 35W TDP), ein P8400 (2.26 GHz, 3MB l2-Cache, 1066 MHz FSB, 25W TDP), ein P8600 (2.4 GHz, 3MB l2-Cache, 1066 MHz FSB, 25W TDP) sowie als leistungsstärkste CPU eine T9400 CPU mit 2.53 GHz (6MB l2-Cache, 1066 MHz FSB, 35W TDP).
Du wirst den stärksten C2D mit Penyrn Kern einbauen können.
---> Intel Core 2 Duo T9900
Wenn da'n Celeron 3000 werkelt, wär ich immer vorsichtig mit vorschnellen Empfehlungen.
In Lenovo's SL & R Billigstteilen, wurde teilweise auch der GL40 Chipsatz verbaut!
Audrey
Moin Moin,
bin noch neu in diesem Forum und habe mich bereits durch die dementspreschenden Thread´s gelesen.
Ich möchte gern den CPU meins Lenovo SL500 aufrüsten! Ist es möglich, auch einen T9900 zu verbauen?
Das einzige wobei ich mir hier gedanken mache, ist die höhere TDP von 35Watt auf 45Watt,
schafft der Serienkühler das, oder würde das ThinkPad mit dem Cpu Überhitzen???
Das sollte funktionieren, jedoch erkenne ich nicht den Sinn eine sehr teure CPU in ein eher bescheidenes SL-Thinkpad zu verbauen.
Es sei denn natürlich du bist an die CPU für kleines Geld gekommen.
In der tat ist das einer der Gründe. Ich könnte die CPU relativ günstig bekommen ;)
Und was das Notebook angeht: Auch das habe ich buchstäblich für einen Apfel und ein Ei bekommen :thumbsup:
Auch ein Thinkpad der SL Serie ist es in meinen Augen wert, ein wenig aufgerüstet zu werden,
wenn sich das Ganze in einem Preislich überschaubaren Rahmen hällt. Immerhin ist das SL500
besser als so manches Notebook "von der Stange" :cool: und immernoch leistungsstärker als mein IBM T43p
ich hab mir den T9900 eingebaut. Ich wollte erst mal Ruhe haben!
Habe aber auch noch den originalen T6570 hier, falls du den willst?
Der T9900 läuft ohne Probleme. Kann ich also nur empfehlen. Wenn du den günstig bekommst, dann rein damit.
