Frage ich jett mal im Zusamehang mit diesem Projekt hier
http://sourceforge.net/projects/internetspeedem/
Dankesehr für die Antworten
It is very easy...
To understand the process please read following steps
carefully,
Step 1
Start the application. (You may have already done it)
Step 2
Set following settings according to your environment,
Actual Host Name & Port
Actual host name means the address where the
actual server (Ex: apache) is running. You
can enter the port also. Normally if you are
running the server locally it is "localhost".
False Host Port
False host means Internet Speed emulator's
listening port. It is running locally and the
access address to the server comes as
http://localhost:<falseport>
(Ex: [url]http://localhost:4999[/url])
Max Connections
Maximum connections handled at a time.
Delay
Delay between two frames in milliseconds
Buffer Size
Data is divided into chucks of buffer size
and between two chunks it wastes the specified
delay time.
Step 3
Run your local server (Ex: Apache)
Step 4
Go to you browser and enter the address
http://localhost:<false port>
That's all!
I love to hear feedbacks...
Dhanushka Krishnajith (Email: [email]idhanu@gmail.com[/email])
