W701ds... News...
techno
17 Apr. 2007
Aus iPhone Gizmodo, daher kein Link:
Lenovo's workstation laptop has gotten an overdue upgrade in the form of the W701ds, and now its guts are every bit as over the top as its integrated secondary display. Seriously: this thing is a hoss.
To start, you've got up to Intel's Core i7-920 Extreme processor, a 17-inch WUXGA (1920×1200) primary display, and Nvidia Quadro FX 3800M graphics. The W701ds can ship with up to 16GB DDR3 memory, 500GB HD storage, and all models have WiMAX support, one USB 3.0 and four USB 2.0 ports, and a 2-megapixel camera.
But really, the star of the show is that secondary display, which allows you to keep your mail your chat windows separate from your primary focus. It's a 10.6-inch, WXGA (1280x800) screen that that's stored in the laptop but pops out when needed for work or a fun party trick. Although with a weight over 9 pounds, it's unlikely that you're going to want to drag this monster to many parties. The W701ds will be available in March starting at $3800.
If you want to forgo the extra screen (because you are a crazy person?) and some power and storage, you might want to take a look at the base model of the W701. It compares favorably to the Dell M6500, while its $2200 base price compares favorably to the Dell's $2750. [Lenovo]
Gibt jetzt auch einen Artikel bei Computerbase.
Die Diskussion im Forum dazu ist übrigens sehr lustig :D
edit: Kann mir dieses Zitat aus dem cb Forum nicht verkneifen :thumbsup:
Ein Thinkpad ist mit Macbooks ja nicht gerade vergleichbar. Lenovo spricht professionelle Anwender an, Apple spricht Menschen mit zu viel Geld an...
Die ds-Version gab es schon als W700. Interessant wäre es, wenn es auf beiden Seiten Displays gäbe: Bei Autorennen kann man die zusätzlichen Displays als Rückspiegel nutzen :D
[quote='fishmac',index.php?page=Thread&postID=787178#post787178]Interessant wäre es, wenn es auf beiden Seiten Displays gäbe:[/quote]Dann müsste man einen Grafikchip verbauen der drei Displays gleichzeitig ansteuern kann. Gibt es einen solchen als Laptop-Version?
[quote='DVormann',index.php?page=Thread&postID=787179#post787179]Dann müsste man einen Grafikchip verbauen der drei Displays gleichzeitig ansteuern kann. Gibt es einen solchen als Laptop-Version? [/quote]
Wie wäre es mit zwei Grafikkarten im SLI Verbund?
[quote='Flory',index.php?page=Thread&postID=787181#post787181]Wie wäre es mit zwei Grafikkarten im SLI Verbund? [/quote]Dann musst Du aber die Heatpipe an die Fussbodenheizung anschliessen. :D
[quote='fishmac',index.php?page=Thread&postID=787188#post787188]Dann musst Du aber die Heatpipe an die Fussbodenheizung anschliessen. :D[/quote]
Würde leider nur was bringen, wenn Lenovo mal ArcticSilver oder ähnliches statt der üblichen WärmeleitPADS verwenden würde :( - obwohl, mit deeer Kühlung könnten sie ja dann endlich mal Oberklasse-Grafikchips verbauen ;)
sehr cooles video, wenns um dinge wie thinkpads geht sollte man kein computerbase lesen ;)
[quote='Flory',index.php?page=Thread&postID=787181#post787181][quote='DVormann',index.php?page=Thread&postID=787179#post787179]Dann müsste man einen Grafikchip verbauen der drei Displays gleichzeitig ansteuern kann. Gibt es einen solchen als Laptop-Version? [/quote]
Wie wäre es mit zwei Grafikkarten im SLI Verbund?[/quote]Grafikkarte im SLI Verbund können aber auch nur 2 Monitore ansteueren, außer mittlerweile wurde das geändert.
[quote='meister.',index.php?page=Thread&postID=787294#post787294]sehr cooles video, wenns um dinge wie thinkpads geht sollte man kein computerbase lesen ;)[/quote]
Zum belustigen ist es aber eine herrliche Quelle des Frohsinns! ;-)
