Shit. Considering it's untested and needs a lot more than just a charger I guess i'll just part it out then.Yes, I guess, that you will need a 170W Power Supply.
Worst part is I have a P50 but it's got the square charger. So I need to acquire a 135 or 170W charger to even test it. Great.Minimum is 135W for running (with wrong power supply warning). Loading an battery does work on 90W in turned off state. Perhaps this already helps to test.
Netherlands, so not close unfortunately.There are power jack adapter which could help. Most are the other way round but the ones you would need exist. (for example: https://de.aliexpress.com/item/3296...xp_id=4fa58587-8f5e-4ec6-a2f5-cf3f0c0f87aa-32)
Btw. - were are you located? Perhaps a forum member could provide one for testing purposes?
