W 700 Sproadisch Error 2100
robert
19 Jan. 2007
Ich habe immer mal wieder Error 2100 bei meinem W 700 mit Crusial C300 128GB.
Neustes Bios ist drauf.
Die Kombination lief nun seit rund 9 Monaten einwandfrei.
Nun häuft sich Error 2100
Was kann das sein?
Scheint an der Crucial zu liegen:
-> http://boardreader.com/thread/error_2100_with_SSD_Lenovo_Community_24ffrX8syr.html
Crucial C300 SSD's are known for this. Prior to the boot there's a startup check in the SSD's PCB, a sort of self-check. That one is prone to failure in the Crucial SSD disks. I experienced it twice but thankfully was able to recover from it. This happened with the lastest firmware version 00006. Aside from that, the Cucial seems a bit flaky on sata3 as well. I would suggest return the C300, or ...
-> http://forum.crucial.com/t5/Solid-S...w510-error-2100-on-boot-C300-128gb/td-p/42724
Can anyone provide a solution to the error 2100 on boot with SSD's? Mine is a Crucial C300 128gb and I cannot even load the OS yet.
Running latest BIOS on laptop and the SSD is the latest firmware (currently ver 6). I was able to see the drive and partition using a USB3 HDD external case. After placing drive in primary HDD0 was only able to "see" the drive if I set the BIOS sata to "compatibility mode"
Drive passed all the BIOS tests while in "compatibility mode" but OS install still does not complete. If BIOS is set to AHCI mode (which is the correct setting for SSD’s) the W510 boot to an error 2100 and does not recognize the drive.
I opened a ticket with Lenovo. (spoke to first level tech) Was told that since I did not buy SSD from Lenovo and that my original HHD worked I get no support. (surprise). When I said that the SSD loaded fine on a Dell Latitude, reponse was same. Lenovo position is if not from lenovo (no support).
Update: I placed the w510 in diagnostics boot mode. This give a little more time for the hardware to examine itself.
I was able to load the OS finally.
Now I only get a 2100 error 50% of time from cold boot, when cold boot error occurs a 3 finger salute usually brings it right in to os now. When I perform a warm reboot from OS about 25% of time I get the 2100 error. It really is a shame that Lenovo will not even try to resolve this.
FYI for those that suggested the firmware fix from Lenovo, that only supports a limited list of SSD's (probably only the ones they sell directly) and not the Crucial C300
Mmh
Liegt das Problem vielleicht am AHCI Modus.
Ich probier noch mal Compatible
Da lief es einwandfrei.
