VPN mit einer Zywall USG und einen NCP VPN Client
Viennaboy
Highly Active Member
16 Okt. 2007
Hi
Also für mich sind die beiden ein spanisches dorf ich kenne mich nimma aus...
Die Fehlermeldung vom VPN Client:
13.01.2009 17:28:08  Ipsec - Start building connection
13.01.2009 17:28:08  Ike - phase1:name(USG Firma) - outgoing connect request - main mode.
13.01.2009 17:28:08  Ike - XMIT_MSG1_MAIN - USG Firma
13.01.2009 17:28:08  Ike - NOTIFY : USG Firma : RECEIVED : NO_PROPOSAL_CHOSEN : 14
13.01.2009 17:28:11  Ike - NOTIFY : USG Firma : RECEIVED : NO_PROPOSAL_CHOSEN : 14
13.01.2009 17:28:15  Ike - NOTIFY : USG Firma : RECEIVED : NO_PROPOSAL_CHOSEN : 14
13.01.2009 17:28:19  Ike - NOTIFY : USG Firma : RECEIVED : NO_PROPOSAL_CHOSEN : 14
13.01.2009 17:28:25  ERROR - 4021:IKE(phase1) - Could not contact Gateway (No response) in state <Wait for Message 2> - USG Firma.
13.01.2009 17:28:25  Ike - phase1:name(USG Firma) - error - retry timeout - max retries
13.01.2009 17:28:25  Ipsec - Disconnected from USG Firma on channel 1.
Die Fehlermeldung der USG:
1	2009-01-13 18:29:59 	info 	IKE 	Recv:[NOTFY:INVALID_ID_INFORMATION]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
2	2009-01-13 18:29:59 	info 	IKE 	The cookie pair is : 0x72bbbf93785a06ff / 0x5d36202e7f604664	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
3	2009-01-13 18:29:59 	info 	IKE 	ISAKMP SA [VPN_NCP_Pc] is disconnected	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
4	2009-01-13 18:29:59 	info 	IKE 	Send:[NOTFY:INVALID_ID_INFORMATION]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
5	2009-01-13 18:29:59 	info 	IKE 	Recv:[NOTFY:INVALD_PALOAD_TYPE]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
6	2009-01-13 18:29:59 	info 	IKE 	The cookie pair is : 0x72bbbf93785a06ff / 0x0000000000000000 [count=9]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
7	2009-01-13 18:29:59 	info 	IKE 	Send:[NOTFY:INVALD_PALOAD_TYPE]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
8	2009-01-13 18:29:59 	info 	IKE 	Tunnel [VPN_NCP_Pc] Phase 1 pre-shared key mismatch	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
9	2009-01-13 18:29:59 	info 	IKE 	Send:[ID][HASH][NOTFY:INITIAL_CONTACT]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
10	2009-01-13 18:29:59 	info 	IKE 	Recv:[KE][NONCE] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
11	2009-01-13 18:29:59 	info 	IKE 	Send:[KE][NONCE] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
12	2009-01-13 18:29:59 	info 	IKE 	Recv:[SA][VID][VID] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
13	2009-01-13 18:29:59 	info 	IKE 	Recv Main Mode request from [XXX.XXX.104.68] [count=5]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
14	2009-01-13 18:29:59 	info 	IKE 	Send:[SA][VID][VID] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
15	2009-01-13 18:29:59 	info 	IKE 	Send Main Mode request to [XXX.XXX.104.68] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
16	2009-01-13 18:29:59 	info 	IKE 	Tunnel [VPN_NCP_Pc] Sending IKE request [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
18	2009-01-13 18:29:59 	info 	IKE 	The cookie pair is : 0xa13a2b6a79add9d5 / 0x0000000000000000 [count=13]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
19	2009-01-13 18:29:29 	info 	IKE 	The cookie pair is : 0xf43de93ba2ec30ed / 0x008fb2f45c2b7e43	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
20	2009-01-13 18:29:29 	info 	IKE 	The cookie pair is : 0xf43de93ba2ec30ed / 0x0000000000000000 [count=9]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
21	2009-01-13 18:29:29 	info 	IKE 	The cookie pair is : 0x868351b5f8ce3231 / 0x0000000000000000 [count=13]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
22	2009-01-13 18:29:27 	info 	IKE 	Recv:[NOTFY:INVALID_ID_INFORMATION] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
23	2009-01-13 18:29:27 	info 	IKE 	The cookie pair is : 0x681f58c6d4283419 / 0x78fa60c8ee8a7d0e	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
24	2009-01-13 18:29:27 	info 	IKE 	ISAKMP SA [VPN_NCP_Pc] is disconnected [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
25	2009-01-13 18:29:27 	info 	IKE 	Send:[NOTFY:INVALID_ID_INFORMATION] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
26	2009-01-13 18:29:27 	info 	IKE 	Recv:[NOTFY:INVALD_PALOAD_TYPE] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
27	2009-01-13 18:29:27 	info 	IKE 	The cookie pair is : 0x681f58c6d4283419 / 0x0000000000000000 [count=9]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
28	2009-01-13 18:29:27 	info 	IKE 	Send:[NOTFY:INVALD_PALOAD_TYPE] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
29	2009-01-13 18:29:27 	info 	IKE 	Tunnel [VPN_NCP_Pc] Phase 1 pre-shared key mismatch [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
30	2009-01-13 18:29:27 	info 	IKE 	Send:[ID][HASH][NOTFY:INITIAL_CONTACT] [count=2]	XXX.XXX.104.68:500	XXX.XXX.104.68:500	IKE_LOG
Ich habe keine ahnung was da Falsch sein kanm. :thumbdown:
THX !
