UPDATE Kompatiblitätsfrage: "ThinkPad Serial Hard Drive Bay Adapter III" #43N3412: Kompatibel mit W510?
imported_krymel
Rather New Member
17 Jan. 2010
<edit>
für alle die sich Hoffnungen gemacht haben, eine zweite Festplatte in den W510 einzubauen,
ist Vorsicht angesagt. Typ II des SATA UltraBay Adapters scheint ebenso wie Typ III des #43N3412 inkompatibel
mit dem W510 zu sein.
Lenovo wird hier wohl in Zukunft (Who knows wann..) einen passenden UltraBay-Adapter liefern.
</edit>
Also: Nicht probehalber kaufen!
<edit>
"The 43N3412 adaptor was delivered and as suspected it will not insert into the W510 Ultrbay slot.
I have notified my Lenovo Engineer and will report back when they resolve the question.
And FYI, I modified my T400/W500 Ultrabay II hard drive adaptor the
other day so it would insert. All that was required was to remove the
little plastic tab. This allowed me to insert the adaptor along with a
hard drive and it locked into position. However, it would not keep the
drives I tested powered so it is obviously not engineered to use the
Ultrabay II or III hard drive adaptors.
Again, when I get a definitive answer on this I'll let you know. I
would imagine they have a 12.5mm hard drive adaptor coming specifically
designed for the W510. At least I hope so. It's a deal breaker for me
considering the BitLocker and Boot from VHD implications."
</edit>
Derjenige scheint den falschen Ultrabay-HDD-Adapter in der richtigen
Verpackung geliefert bekommen zu haben...
FYI,
The Lenovo team looked at the pictures I sent them and they believe
the vendor that administers the loaner program sent me the wrong
Ultrabay hard drive adapter in the right box. They have ordered another
one for me and I believe I'll have it next week."
Also bleibt weiter abzuwarten, ob der Ultrabay HDD Adapter Typ III passend ist.
Ggf. kann hier schon jemand über eigene Erfahrungen berichten?
LG,
Aron
hi,
ich will in mein w510 auch eine 2. platte einbauen.
welcher bay-adapter passt denn nun...
hier steht, der III-er (43N3412) würde nicht passen ?!?
any idea ?
ja, wie hier schon geschrieben, ich bin da grade sehr unsicher ?!?
ach was solls ich bestell ihn halt mal...
Wenn er nicht passt dann kannst du ihn ja eh zurückschicken oder egal wie du es drehst du hast ja bei Onlinebestellungen 15 Tage rückgaberecht. Ich möchte mir auch einen Adapter holen aber nur mit SSD und die sind mir immer noch zu teuer. Ich warte noch bis Anfang 2011.
ja, das ist schon toll, kein risiko :-)
und da das teil ja >40€ kostet zahl ich nicht mal porto...
die ssd hab ich schon, allerdings, solange das W510 nicht da ist, im x60... is schon schön schnell, muss ich sagen !
allerdings (themenwechsel !) erreicht sie im x60 nur 60% der speed wie in meinem i7-920-desktop ?!?
habe den Standard-Adapter mit der Nummer 43N3412 in Verwendung
Der lässt dann oben einen Spalt…
Die 1 TB Platte von WD mit der 12.5 mm Bauhöhe passt und rennt bei mir ohne
Probleme.
Gruss
[quote='sloch',index.php?page=Thread&postID=860443#post860443]habe den Standard-Adapter mit der Nummer 43N3412 in Verwendung
Der lässt dann oben einen Spalt…[/quote]
hmmm, ob das so geschickt ist ? da hätte ich jetzt etwas angst, dass der "designte" luftstrom durcheinander kommt und die kühlung probleme bekommt...
wird deine kiste irgendwie wärmer als normal ?
[quote='sloch',index.php?page=Thread&postID=860443#post860443]Die 1 TB Platte von WD mit der 12.5 mm Bauhöhe passt und rennt bei mir ohne Probleme.[/quote]
wow, so weit sind wir schon. 1tb im notebook, cool :-)
allerdings bekomme ich wohl keine freigabe meiner regierung für so ne anschaffung :-(((
[quote='sloch',index.php?page=Thread&postID=860443#post860443]Hallo,
Gruss[/quote]Kannst du davon bitte mal ein Foto machen? Muss ich sehen um zu wissen, ob mich das stören würde.
Danke & Gruß
Foto ist kein Problem, könnter aber bis nächsten Donnerstag dauern, da ich unterwegs bin.
Gruss
Sebastian
Habe ein Bild in diesem Blog gefunden, falls es noch jemanden interessiert:
Der Unterschied sind 9,5mm zu 12,7mm um genau zu sein.
Bei ebay findet man third party Adapter für 12,7mm Einschübe (leider nur im Ausland). Würde mich interessieren, inwieweit die kompatibel sind und ob es Unterschiede in der Leistung gibt. Bsp.: http://cgi.ebay.de/SATA-2nd-Hard-Di...C_Drives_Storage_Internal&hash=item27b20b2c2a
Gibt es von lenovo generell keinen 12,7mm Adapter oder nur keinen passenden für das W510?
€: So wie ich sehe, ist der Hard Drive Adapater II (43R1980) 12,7mm hoch, wird aber nicht mehr produziert. Verfügbar ist er trotzdem noch. Was spricht dagegen, diesen zu nehmen?
hy slyght der alte adapter passt nicht mehr, entweder den neuen mit spalt oder einen passenden mit dem neuen interface aus der bucht (nach "enhanced" suchen)
