Keine Änderungen ist gut
Hier sind die "keine
Änderungen"
CHANGES IN THIS RELEASE
Version 4.50, 4.51 and 4.52
[Important updates]
Nothing.
[New functions or enhancements]
- Integration with AVAYA IP Softphone.
- Profile Aging feature.
- Ethernet Speed and Duplex setting.
- Wireless WAN PAP/CHAP authentication setting.
- Automatic reconnect VPN setting.
- "Override TCP/IP and DNS defaults" and "Do not automatically include
wireless profiles without security in the roaming list" options in
Client Configuration Policy settings.
- "Disable Ethernet adapter when Ethernet cable is unplugged" option
in Global Settings.
- Roaming speed improvement.
[Problem fixes]
- Copied 802.1x Wireless profile connection fails with the IBM/
ThinkPad/Lenovo Wireless LAN adapters.
- 802.1x profile does not connect after exporting the IBM/ThinkPad/
Lenovo Wireless LAN adapters profile.
- 802.1x profile isn't listed in location switch after export the IBM/
ThinkPad/Lenovo Wireless LAN adapters profile.
- 802.1x profile doesn't connect after editing SSID with the IBM/
- Unable to create 802.1x profile using Find Wireless with the IBM/
- Wireless profile doesn't connect after converting from adhoc to
802.1x with the IBM/ThinkPad/Lenovo Wireless LAN adapters.
- Wrong German translation of error message.
- Wireless WAN connection fails after hibernation/wakeup with Telus2.
- 11g mode is shown in main panel even if AP is set to 11n mode (fixed
with Windows Vista SP1).
- MIMO APs are not listed as 802.11n in Find Wireless Network (fixed
- Dialog window appears when audit process.
- Skip 2nd Wireless LAN to Wireless WAN in location switching.
- Wireless WAN profile fails to connect Intermittently.
- Location switch doesn't save the preferred Wireless LAN profile.
- GDI+Window is shown in Taskbar when MBC is launched.
- Wireless profile isn't seen in Location switching when it is copied.
- Can't connect Wireless profile using Find Wireless when "Do not
automatically include new wired/wireless profile in the roaming list"
is enabled on the ADM server.
- Wireless driver version is not displayed in ACWLIcon and profile
view.
- 802.1x auth properties is not launched with the IBM/ThinkPad/Lenovo
- Wireless USB cannot be detected intermittently.
- Static IP profile does not apply default gateway.
- Language for non-unicode programs in control panel is used in Access
Connections.
- Connect Wireless WAN after Wireless LAN Switch OFF/ON takes 2
attempts.
- Fn + F5 key function window is not displayed correctly in Norwegian.
- Connection log does not show any data while connected Wireless WAN
by dial-up.
- User Data counters in Connection log is not correct, while connected
by Wireless WAN.
- Connection details text file shows wrong SSID.
- All information is not displayed correctly in ACWL Icon on Windows
Vista 64-bit.
