Hey!
Danke für die vielen Tipps. Lubuntu 12.10 klingt ja in der Tat ganz gut.
@linrunner: HDD ist laut Prüfprogramm ok. Wie finde ich denn heraus, dass das Bios aktuell ist? Bei der Grafikkarte handelt es sich um eine Radeon X1300.
Hier der output von sudo tlp-stat:
--- TLP 0.3.7.1 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
USB_AUTOSUSPEND=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
+++ System Info
System = LENOVO ThinkPad T60 2007Y2F
BIOS = 79ETC9WW (2.09 )
Release = Linux Mint 14 Nadia
Kernel = 3.5.0-22-generic i686
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-3.5.0-22-generic root=UUID=c799a40b-f349-45ff-8358-848e7801757e ro quiet splash vt.handoff=7
+++ System Status
TLP power save = enabled
power source = ac
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 1000000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 1833000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 1833000 1333000 1000000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 1000000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 1833000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies = 1833000 1333000 1000000 [kHz]
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
/proc/acpi/ibm/thermal = 60 32 29 65 -128 -128 -128 -128 37 46 50 -128 -128 -128 -128 -128 [°C]
/proc/acpi/ibm/fan = 2934 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 60
/proc/sys/vm/dirty_background_ratio = 1
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = FUJITSU MHV2060BH PL
Firmware = 00840029
APM Level = none/disabled
scheduler = deadline
SMART info:
4 Start_Stop_Count = 6104
5 Reallocated_Sector_Ct = 0
193 Load_Cycle_Count = 89396
194 Temperature_Celsius = 28 (Min/Max 7/54) [°C]
/dev/sdb:
Model = ST9500325AS
Firmware = 0002BSM1
APM Level = 254
SMART info:
+++ SATA Aggressive Link Power Management
No AHCI-enabled host controller detected.
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (disabled by kernel)
+++ Radeon Graphics
/sys/class/drm/card0/device/power_method = profile
/sys/class/drm/card0/device/power_profile = high
+++ Wireless
bluetooth = on
wifi = on
wwan = none (no device)
wlan0(iwl3945): power management = off (disabled by kernel)
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ Runtime Power Management
/sys/bus/pci/devices/0000:00:00.0/power/control = on [Host]
/sys/bus/pci/devices/0000:00:1b.0/power/control = on [Audio]
/sys/bus/pci/devices/0000:02:00.0/power/control = on [Ethernet]
/sys/bus/pci/devices/0000:03:00.0/power/control = on [Wireless]
+++ USB
tlp usb autosuspend = enabled
tlp usb blacklist = (not configured)
Bus 001 Device 002 ID 059b:047a control = auto, autosuspend_delay_ms = 2000 -- Iomega Corp. Select Portable Hard Drive (usb-storage)
Bus 001 Device 004 ID 05e3:0606 control = auto, autosuspend_delay_ms = 2000 -- Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4 USB 2.0 Hub (hub)
Bus 002 Device 002 ID 046d:c06c control = on, autosuspend_delay_ms = 2000 -- Logitech, Inc. Optical Mouse (usbhid)
Bus 005 Device 002 ID 0a5c:2110 control = auto, autosuspend_delay_ms = 2000 -- Broadcom Corp. Bluetooth Controller (btusb)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 003 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 004 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 005 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 001 Device 008 ID 04a9:10b5 control = auto, autosuspend_delay_ms = 2000 -- Canon, Inc. (usblp)
Bus 001 Device 007 ID 1e4e:0100 control = auto, autosuspend_delay_ms = 2000 -- (uvcvideo)
