tp-fancontrol startet nicht mehr
Bayasa
Rather New Member
12 Jan. 2007
Hallo!
Ich habe ein Problem mit tp-fancontrol skript.
Das Skript startet sich nicht mehr. Hier ist die Ausgabe auf Terminal.
# sudo tp-fancontrol
25384: old priority 0, new priority -10
> Activating watchdog with delay 9 sec
> Starting dynamic fan control
> Shutting down, switching to automatic fan control
Und hier unten Ausgabe von
~$ sudo bash -x tp-fancontrol
+ THRESHOLDS=(50 70 47 60 43 55 49 68 40 50 40 50 37 47 37 47 45 60 48 62 50 65 47 58 47 60)
+ LEVELS=(0 2 4 7)
+ ANTIPULSE=(0 1 1 0)
+ OFF_THRESH_DELTA=3
+ MIN_THRESH_SHIFT=0
+ MAX_THRESH_SHIFT=0
+ MIN_WAIT=180
+ IBM_ACPI=/proc/acpi/ibm
+ HDAPS_TEMP=/sys/bus/platform/drivers/hdaps/hdaps/temp1
+ PID_FILE=/var/run/tp-fancontrol.pid
+ LOGGER=/usr/bin/logger
+ INTERVAL=3
+ SETTLE_TIME=6
+ RESETTLE_TIME=600
+ SUSPEND_TIME=5
+ DISK_POLL_PERIOD=15
+ HITACHI_MODELS='^(HTS4212..H9AT00|HTS726060M9AT00|HTS5410..G9AT00|IC25[NT]0..ATCS0[45]|HTE541040G9AT00|HTS5416..J9(AT|SA)00)'
+ SEP=,
+ WATCHDOG_DELAY=9
++ grep -q watchdog /proc/acpi/ibm/fan
++ echo true
+ HAVE_WATCHDOG=true
++ grep -q disengaged /proc/acpi/ibm/fan
++ echo true
+ HAVE_LEVELCMD=true
+ QUIET=false
+ DRY_RUN=false
+ DAEMONIZE=false
+ AM_DAEMON=false
+ KILL_DAEMON=false
+ SUSPEND_DAEMON=false
+ SYSLOG=false
+ DISK_POLL_TIME=-15
+ getopts s:S:qtdlp:kuh OPT
+ '[' 1 -gt 0 ']'
+ false
+ false
+ false
+ false
+ false
+ '[' -e /var/run/tp-fancontrol.pid ']'
+ set_priority
+ false
+ renice -10 -p 24175
+ control_fan
+ set -e -E -u
+ trap 'cleanup; exit 2' HUP INT ABRT QUIT SEGV TERM
+ trap cleanup EXIT
+ trap 'log '\''Got SIGUSR1'\''; setlevel 0; RESTART=true; sleep 5' USR1
+ false
+ true
+ log 'Activating watchdog with delay 9 sec'
+ false
+ echo '> Activating watchdog with delay 9 sec'
+ false
+ echo 'watchdog 9'
+ init_state
+ IDX=0
+ NEW_IDX=0
+ START_TIME=0
+ MAX_IDX=3
+ SETTLE_LEFT=0
+ RESETTLE_LEFT=0
+ FIRST=true
+ RESTART=false
+ log 'Starting dynamic fan control'
+ false
+ echo '> Starting dynamic fan control'
+ false
+ true
+ update_disk_temp
+ ((  SECONDS >= DISK_POLL_TIME + DISK_POLL_PERIOD  ))
+ LAST_DISK_TEMP=-128
+ for DEV in '{sda,hda}'
+ [[ -b /dev/sda ]]
++ cat /sys/block/sda/device/model
+ local 'MODEL=FUJITSU MHV2100A'
+ [[ FUJITSU MHV2100A =~ \^\(HTS4212\.\.H9AT00\|HTS726060M9AT00\|HTS5410\.\.G9AT00\|IC25\[NT]0\.\.ATCS0\[45]\|HTE541040G9AT00\|HTS5416\.\.J9\(AT\|SA\)00\) ]]
+ [[ -b /dev/hda ]]
+ DISK_POLL_TIME=0
++ thermometer
++ [[ -r /proc/acpi/ibm/thermal ]]
++ read THERMAL
++ read X Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 Z1 Z2 Z3 JNK
+++ echo 'temperatures:	45 39 32 -128 -128 -128 -128 -128 41 47 41 -128 -128 -128 -128 -128'
++ [[ temperatures: == \t\e\m\p\e\r\a\t\u\r\e\s\: ]]
++ echo -n '45 39 32 -128 -128 -128 -128 -128 '
++ [[ -n 41 ]]
++ [[ -n 47 ]]
++ [[ -n 41 ]]
++ echo -n ', 41 47 41 '
++ echo -n ', -128 '
++ '[' -r /sys/bus/platform/drivers/hdaps/hdaps/temp1 ']'
+++ cat /sys/bus/platform/drivers/hdaps/hdaps/temp1
++ Y=39
++ ((  39 > 100  ))
++ echo -n '39 '
++ return 0
+ TEMPS='45 39 32 -128 -128 -128 -128 -128 , 41 47 41 , -128 39 '
+ false
++ speedometer
++ sed -n 's/^speed:[ \t]*//p' /proc/acpi/ibm/fan
+ SPEED=3853
+ false
++ getlevel
++ perl -e 'm/^EC 0x20: .* .(..)$/ and print $1 and exit 0 while <>; exit 1'
+ ECLEVEL=86
++ date +%s
+ NOW=1265727619
+ grep -q '[^ 0-9,\n-]'
+ echo '45 39 32 -128 -128 -128 -128 -128 , 41 47 41 , -128 39 '
+ MAX_Z=0
+ SENSOR=0
+ Z_STR=0+
+ TEMP_STR=
+ for TEMP in '$TEMPS'
+ [[ 45 == \, ]]
+ '[' 2 -le 26 ']'
+ [[ 45 == -128 ]]
+ [[ 45 == 128 ]]
+ MIN=50
+ MAX=70
+ [[ 70 -le 50 ]]
+ ((  TEMP < MIN - OFF_THRESH_DELTA  ))
+ Z=0
+ '[' 0 -gt 0 ']'
+ MAX_Z=0
+ Z_STR=0+0
+ TEMP_STR='45 '
+ ((  ++SENSOR  ))
+ [[ 39 == \, ]]
+ '[' 4 -le 26 ']'
+ [[ 39 == -128 ]]
+ [[ 39 == 128 ]]
+ MIN=47
+ MAX=60
+ [[ 60 -le 47 ]]
+ Z=0
+ '[' 0 -gt 0 ']'
+ MAX_Z=0
+ Z_STR=0+00
+ TEMP_STR='45 39 '
+ ((  ++SENSOR  ))
+ [[ 32 == \, ]]
+ '[' 6 -le 26 ']'
+ [[ 32 == -128 ]]
+ [[ 32 == 128 ]]
+ MIN=43
+ MAX=55
+ [[ 55 -le 43 ]]
+ Z=0
+ '[' 0 -gt 0 ']'
+ MAX_Z=0
+ Z_STR=0+000
+ TEMP_STR='45 39 32 '
+ ((  ++SENSOR  ))
+ [[ -128 == \, ]]
+ '[' 8 -le 26 ']'
+ [[ -128 == -128 ]]
+ Z=_
+ TEMP=_
+ Z_STR=0+000_
+ TEMP_STR='45 39 32 _ '
+ ((  ++SENSOR  ))
+ [[ -128 == \, ]]
+ '[' 10 -le 26 ']'
+ Z=_
+ TEMP=_
+ Z_STR=0+000__
+ TEMP_STR='45 39 32 _ _ '
+ ((  ++SENSOR  ))
+ [[ -128 == \, ]]
+ '[' 12 -le 26 ']'
+ Z=_
+ TEMP=_
+ Z_STR=0+000___
+ TEMP_STR='45 39 32 _ _ _ '
+ ((  ++SENSOR  ))
+ [[ -128 == \, ]]
+ '[' 14 -le 26 ']'
+ Z=_
+ TEMP=_
+ Z_STR=0+000____
+ TEMP_STR='45 39 32 _ _ _ _ '
+ ((  ++SENSOR  ))
+ [[ -128 == \, ]]
+ '[' 16 -le 26 ']'
+ Z=_
+ TEMP=_
+ Z_STR=0+000_____
+ TEMP_STR='45 39 32 _ _ _ _ _ '
+ ((  ++SENSOR  ))
+ Z_STR=0+000_____,
+ TEMP_STR='45 39 32 _ _ _ _ _ , '
+ continue
+ [[ 41 == \, ]]
+ '[' 18 -le 26 ']'
+ [[ 41 == -128 ]]
+ [[ 41 == 128 ]]
+ MIN=45
+ MAX=60
+ [[ 60 -le 45 ]]
+ Z=0
+ '[' 0 -gt 0 ']'
+ MAX_Z=0
+ Z_STR=0+000_____,0
+ TEMP_STR='45 39 32 _ _ _ _ _ , 41 '
+ ((  ++SENSOR  ))
+ [[ 47 == \, ]]
+ '[' 20 -le 26 ']'
+ [[ 47 == -128 ]]
+ [[ 47 == 128 ]]
+ MIN=48
+ MAX=62
+ [[ 62 -le 48 ]]
++ floor_div -4 14
++ echo -1
+ Z=1
+ '[' 1 -ge 1 ']'
+ '[' 1 -le 6 ']'
+ '[' 0 -gt 1 ']'
+ MAX_Z=1
+ Z_STR=0+000_____,01
+ TEMP_STR='45 39 32 _ _ _ _ _ , 41 47 '
+ ((  ++SENSOR  ))
+ [[ 41 == \, ]]
+ '[' 22 -le 26 ']'
+ [[ 41 == -128 ]]
+ [[ 41 == 128 ]]
+ MIN=50
+ MAX=65
+ [[ 65 -le 50 ]]
+ Z=0
+ '[' 1 -gt 0 ']'
+ Z_STR=0+000_____,010
+ TEMP_STR='45 39 32 _ _ _ _ _ , 41 47 41 '
+ ((  ++SENSOR  ))
+ Z_STR=0+000_____,010,
+ TEMP_STR='45 39 32 _ _ _ _ _ , 41 47 41 , '
+ continue
+ [[ -128 == \, ]]
+ '[' 24 -le 26 ']'
+ Z=_
+ TEMP=_
+ Z_STR=0+000_____,010,_
+ TEMP_STR='45 39 32 _ _ _ _ _ , 41 47 41 , _ '
+ ((  ++SENSOR  ))
+ [[ 39 == \, ]]
+ '[' 26 -le 26 ']'
+ [[ 39 == -128 ]]
+ [[ 39 == 128 ]]
+ MIN=47
+ MAX=60
+ [[ 60 -le 47 ]]
+ Z=0
+ '[' 1 -gt 0 ']'
+ Z_STR=0+000_____,010,_0
+ TEMP_STR='45 39 32 _ _ _ _ _ , 41 47 41 , _ 39 '
+ ((  ++SENSOR  ))
+ '[' 13 -gt 0 ']'
+ ((  (MAX_Z == 2*IDX-1) && ++MAX_Z  ))
+ cleanup
+ false
+ log 'Shutting down, switching to automatic fan control'
+ false
+ echo '> Shutting down, switching to automatic fan control'
+ false
+ false
+ true
+ echo enable
+ true
+ echo watchdog 0
Kann jemand mir sagen wo das Problem liegt?
