ThinkVantage Update 476,84 MB??
tippi
20 Aug. 2007
mein TV meldet unter Optionale Aktualisierungen diese Patch, soll ich das machen, oder für was soll das gut sein?? Bin unsicher.
Gruß Tippi
Maintenance Patch for ThinkVantage Client Security Solution
for Microsoft(R) Windows(R) XP and 2000
Version 8.00.0311
Installation Readme
This package will update Client Security Solution versions 8.00.0113,
8.00.0114, 8.00.0305, or 8.00.0309 to version 8.00.0310. Client Security
Solution version 8.00.0113, 8.00.0114, or 8.00.0305 must be installed on your
system for this update to work.
This update requires approximately 47MB of space on your hard drive.
Print this file so that you can refer to it during the installation.
System requirements
- Update your system to the latest BIOS
- 1.5GB of free space on your hard drive
- 256MB of memory is recommended
- Microsoft Windows XP with Service Pack 2 or Windows 2000 with Service
Pack 4 or higher
- 8MB or less of VRAM shared memory set in BIOS
Hi!
ich bin auch aus allen Wolken gefallen, als ichs gelesen hab. Aber: das ist FALSCH! Der lädt nur 30 oder 40MB runter, wenn du startest! Geht also fix.
Bye
Dirk
Original von tippi
Gruß Tippi
Version 8.00.0311
Installation Readme
System requirements
Pack 4 or higher
