InstallShield 21:20:58: Detected X64 OS
InstallShield 21:20:58: Extracting support file ISBEWX64.exe to K:\TMP\{AC700256-9AD0-4B83-98CF-C03308399DDE}\ISBEW64.exe
InstallShield 21:20:59: Setting script cmdline...
InstallShield 21:20:59: ProductCode is {25C64847-B900-48AD-A164-1B4F9B774650}
InstallShield 21:20:59: Initializing Engine
InstallShield 21:20:59: Done Initializing...
InstallShield 21:20:59: Registering Msi Server...
MSI (s) (50!C4) [21:20:59:129]: Resolving source.
MSI (s) (50!C4) [21:20:59:129]: Resolving source to launched-from source.
MSI (s) (50!C4) [21:20:59:129]: Setting launched-from source as last-used.
MSI (s) (50!C4) [21:20:59:129]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\ProgramData\Lenovo\tvsuinstaller\'.
MSI (s) (50!C4) [21:20:59:129]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\ProgramData\Lenovo\tvsuinstaller\'.
MSI (s) (50!C4) [21:20:59:129]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{25C64847-B900-48AD-A164-1B4F9B774650}'.
MSI (s) (50!C4) [21:20:59:129]: SOURCEDIR ==> C:\ProgramData\Lenovo\tvsuinstaller\
MSI (s) (50!C4) [21:20:59:129]: SOURCEDIR product ==> {25C64847-B900-48AD-A164-1B4F9B774650}
MSI (s) (50!C4) [21:20:59:192]: SECREPAIR: CryptAcquireContext: Could not create the default key container
MSI (s) (50!C4) [21:20:59:192]: Determining source type
MSI (s) (50!C4) [21:20:59:192]: Source type from package 'Lenovo System Update.msi': 0
MSI (s) (50!C4) [21:20:59:192]: SECREPAIR: Hash Database: C:\Windows\Installer\SourceHash{25C64847-B900-48AD-A164-1B4F9B774650}
MSI (s) (50!C4) [21:20:59:192]: SECREPAIR: SourceHash database file already exists. Deleting it.
MSI (s) (50!C4) [21:20:59:223]: Note: 1: 2262 2: SourceHash 3: -2147287038
MSI (s) (50!C4) [21:20:59:223]: SECREPAIR: New Hash Database creation complete.
MSI (s) (50!C4) [21:20:59:223]: SECREPAIR: Crypt Provider not initialized. Error:0
MSI (s) (50!C4) [21:20:59:223]: SECREPAIR: Crypt Provider not initialized. Error:997
MSI (s) (50!C4) [21:20:59:223]: SECUREREPAIR: Failed to CreateContentHash of the file: COMMON~1.cab: for computing its hash. Error: 997
MSI (s) (50!C4) [21:20:59:223]: SECREPAIR: Failed to create hash for the install source files
MSI (s) (50!C4) [21:20:59:223]: SECUREREPAIR: SecureRepair Failed. Error code: 3e5ECE434B8
InstallShield 21:20:59: Invoking script function CreateControlPanelItem
InstallShield 21:20:59: CallScriptFunctionFromMsiCA() ends
MSI (s) (50:44) [21:20:59:254]: NOTE: custom action CreateControlPanelItem unexpectedly closed the hInstall handle (type MSIHANDLE) provided to it. The custom action should be fixed to not close that handle.
Aktion beendet um 21:20:59: CreateControlPanelItem. Rückgabewert 1.
MSI (s) (50:B8) [21:20:59:254]: Skipping action: UninstallSUService (condition is false)
MSI (s) (50:B8) [21:20:59:254]: Doing action: AllocateRegistrySpace
Aktion 21:20:59: AllocateRegistrySpace. In der Registrierung wird Speicherplatz reserviert
Aktion gestartet um 21:20:59: AllocateRegistrySpace.
Aktion beendet um 21:20:59: AllocateRegistrySpace. Rückgabewert 1.
MSI (s) (50:B8) [21:20:59:254]: Doing action: ProcessComponents
Aktion 21:20:59: ProcessComponents. Registrierung der Komponente(n) wird aktualisiert
Aktion gestartet um 21:20:59: ProcessComponents.
MSI (s) (50:B8) [21:20:59:254]: Note: 1: 2205 2: 3: MsiPatchCertificate
MSI (s) (50:B8) [21:20:59:254]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (50:B8) [21:20:59:254]: Resolving source.
MSI (s) (50:B8) [21:20:59:254]: Resolving source to launched-from source.
MSI (s) (50:B8) [21:20:59:254]: Setting launched-from source as last-used.
MSI (s) (50:B8) [21:20:59:254]: SOURCEDIR ==> C:\ProgramData\Lenovo\tvsuinstaller\
MSI (s) (50:B8) [21:20:59:254]: SOURCEDIR product ==> {25C64847-B900-48AD-A164-1B4F9B774650}
MSI (s) (50:B8) [21:20:59:254]: SECUREREPAIR: SecureRepair Failed. Error code: 3e5ECE434B8
Fehler 997. Überlappender E/A-Vorgang wird verarbeitet.
