Original von atomic-virus
ja, normalerweise brauchst du dazu doch bloß den treiber installieren!?
Digital Line Detect is an application that BVRP Software created that will pop up when a digital current is detected on your phone line. The signal is sent from your modem to our application and our application will pop-up if a digital signal is detected to warn you so you do not damage your modem hardware.
V.92 modems enhanced with the new NetWaiting feature enable end-users with Call Waiting to be notified of incoming calls while remaining on the Internet, allowing them to place the Internet "on hold" for several minutes while taking the telephone call. Users can also place the modem "on hold" and make an outgoing call without losing the Internet connection. NetWaiting also supports Caller ID service by displaying the incoming caller's phone number and identification. In addition, users can maintain a database of frequent callers so that familiar names are displayed and identified.
NetWaiting features an easy-to-use interface that is configurable through the preferences menu. Users have the ability to specify call options, ignoring all incoming calls, accepting all incoming calls and disconnecting the Internet connection, or screening all incoming calls and prompting the user.
