T14*/T15* [Think Pad T14 Gen3, Debian Trixie/sid] Nach suspend wacht der Laptop nicht mehr auf.
chris101
17 Okt. 2024
"dmesg -l warn" liefert folgenden Outpout:
[    0.255140] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.255141] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.298347] ACPI: \_SB_.PCI0.GP11: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.300172] ACPI: \_SB_.PCI0.GP12: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.304571] ACPI: \_SB_.PCI0.GP19.NHI0: Overriding _PRW sleep state (S3) by S0 from power resources
[    0.305210] ACPI: \_SB_.PCI0.GP19.NHI1: Overriding _PRW sleep state (S3) by S0 from power resources
[    1.460999] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    1.461002] blacklist: Duplicate blacklisted hash bin:f52f83a3fa9cfbd6920f722824dbe4034534d25b8507246b3b957dac6e1bce7a
[    1.461005] blacklist: Duplicate blacklisted hash bin:c5d9d8a186e2c82d09afaa2a6f7f2e73870d3e64f72c4e08ef67796a840f0fbd
[    1.461007] blacklist: Duplicate blacklisted hash bin:1aec84b84b6c65a51220a9be7181965230210d62d6d33c48999c6b295a2b0a06
[    1.461009] blacklist: Duplicate blacklisted hash bin:c3a99a460da464a057c3586d83cef5f4ae08b7103979ed8932742df0ed530c66
[    1.461011] blacklist: Duplicate blacklisted hash bin:58fb941aef95a25943b3fb5f2510a0df3fe44c58c95e0ab80487297568ab9771
[    1.461013] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    1.461016] blacklist: Duplicate blacklisted hash bin:d626157e1d6a718bc124ab8da27cbb65072ca03a7b6b257dbdcbbd60f65ef3d1
[    1.461018] blacklist: Duplicate blacklisted hash bin:d063ec28f67eba53f1642dbf7dff33c6a32add869f6013fe162e2c32f1cbe56d
[    1.461020] blacklist: Duplicate blacklisted hash bin:29c6eb52b43c3aa18b2cd8ed6ea8607cef3cfae1bafe1165755cf2e614844a44
[    1.461022] blacklist: Duplicate blacklisted hash bin:90fbe70e69d633408d3e170c6832dbb2d209e0272527dfb63d49d29572a6f44c
[    1.461024] blacklist: Duplicate blacklisted hash bin:106faceacfecfd4e303b74f480a08098e2d0802b936f8ec774ce21f31686689c
[    1.461027] blacklist: Duplicate blacklisted hash bin:174e3a0b5b43c6a607bbd3404f05341e3dcf396267ce94f8b50e2e23a9da920c
[    1.461029] blacklist: Duplicate blacklisted hash bin:2b99cf26422e92fe365fbf4bc30d27086c9ee14b7a6fff44fb2f6b9001699939
[    1.461031] blacklist: Duplicate blacklisted hash bin:2e70916786a6f773511fa7181fab0f1d70b557c6322ea923b2a8d3b92b51af7d
[    1.461034] blacklist: Duplicate blacklisted hash bin:3fce9b9fdf3ef09d5452b0f95ee481c2b7f06d743a737971558e70136ace3e73
[    1.461036] blacklist: Duplicate blacklisted hash bin:47cc086127e2069a86e03a6bef2cd410f8c55a6d6bdb362168c31b2ce32a5adf
[    1.461038] blacklist: Duplicate blacklisted hash bin:71f2906fd222497e54a34662ab2497fcc81020770ff51368e9e3d9bfcbfd6375
[    1.461041] blacklist: Duplicate blacklisted hash bin:82db3bceb4f60843ce9d97c3d187cd9b5941cd3de8100e586f2bda5637575f67
[    1.461043] blacklist: Duplicate blacklisted hash bin:8ad64859f195b5f58dafaa940b6a6167acd67a886e8f469364177221c55945b9
[    1.461046] blacklist: Duplicate blacklisted hash bin:8d8ea289cfe70a1c07ab7365cb28ee51edd33cf2506de888fbadd60ebf80481c
[    1.461048] blacklist: Duplicate blacklisted hash bin:aeebae3151271273ed95aa2e671139ed31a98567303a332298f83709a9d55aa1
[    1.461050] blacklist: Duplicate blacklisted hash bin:c409bdac4775add8db92aa22b5b718fb8c94a1462c1fe9a416b95d8a3388c2fc
[    1.461053] blacklist: Duplicate blacklisted hash bin:c617c1a8b1ee2a811c28b5a81b4c83d7c98b5b0c27281d610207ebe692c2967f
[    1.461055] blacklist: Duplicate blacklisted hash bin:c90f336617b8e7f983975413c997f10b73eb267fd8a10cb9e3bdbfc667abdb8b
[    1.461058] blacklist: Duplicate blacklisted hash bin:64575bd912789a2e14ad56f6341f52af6bf80cf94400785975e9f04e2d64d745
[    1.461060] blacklist: Duplicate blacklisted hash bin:45c7c8ae750acfbb48fc37527d6412dd644daed8913ccd8a24c94d856967df8e
[    1.461308] blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
[    1.461311] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    1.461363] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    1.461407] blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
[    1.461468] blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
[    1.461505] blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
[    1.977680] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    3.748180] r8152 10-1.1:1.0: Direct firmware load for rtl_nic/rtl8153b-2.fw failed with error -2
[    3.748184] r8152 10-1.1:1.0: unable to load firmware patch rtl_nic/rtl8153b-2.fw (-2)
[    5.422736] sd 0:0:0:0: [sda] No Caching mode page found
[    5.422739] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.404999] systemd-sysv-generator[471]: SysV service '/etc/init.d/speech-dispatcher' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    7.886512] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Wenn der Laptop in den Suspend Mode geht, blinkt die Power leuchte sanft auf - jedoch kann das Betriebssystem nur durch einen Kaltstart neu gestartet werden.
Nach einer Forensuche wird rasch klar, dass dieses Problem unter zahlreichen Latop Varianten und Betriebssystem unter Linux aufgetreten ist und auftritt.
Hat vielleicht jemand eine Idee wie das Problem angegangen werden könnte ?
Ich versuchte bereits WWAN im BIOS auszuschalten, was bei meinem BIOS jedoch nicht vorhanden ist. Regelmässig wird auch der ath11k treiber verdächtigt.
Hooks Vorschläge gibt es hier:
Vielen Dank!
Vielleicht auch zu simpel gedacht, aber ist die Swap Partition/File groß genug für ein sauberes Aufwachen?
Schon die Fn-Taste zum wecken versucht?
Leider kann die Fn-Taste nicht den Laptop wecken.
Die Swap-Partition sollte genug gross sein. Danke.
cat /proc/swaps
Filename                Type        Size        Used    Priority
/dev/dm-2                               partition    15486972    0    -2
