Tastatur für externen Computer
Bardo
16 Juli 2006
keine Ahnung ob das jetzt trivial oder unmöglich ist:
Ich will meinen Thinkpad unter Linux als Tastatur für eine Rechner unter Windows benutzen.
- VNC
- rdesktop
- serial port ???
- USB ???
Danke für euren input.
Gruss,
Bardo
http://fredrik.hubbe.net/x2vnc.html
This program will let you use two screens on two different computers as if they were connected to the same computer. Even if one of the computers runs Windows 95/98/NT and the other one runs X-windows. If they are both running Windows, you probably want to use Win2VNC instead.
http://synergy2.sourceforge.net/
Synergy lets you easily share a single mouse and keyboard between multiple computers with different operating systems, each with its own display, without special hardware. It's intended for users with multiple computers on their desk since each system uses its own monitor(s).
http://www.realvnc.com/
VNC (Virtual Network Computing) software makes it possible to view and fully-interact with one computer from any other computer or mobile device anywhere on the Internet. VNC software is cross-platform, allowing remote control between different types of computer. For ultimate simplicity, there is even a Java viewer, so that any desktop can be controlled remotely from within a browser without having to install software.
http://www.rdesktop.org/
rdesktop is an open source client for Windows NT Terminal Server and Windows 2000/2003 Terminal Services, capable of natively speaking Remote Desktop Protocol (RDP) in order to present the user's NT desktop. Unlike Citrix ICA, no server extensions are required.
ich persönlich verwende rdesktop, wenn ich mit einer windoze büchse arbeiten muss. Allerdings sollte es schon 2000/2003 Server sein, denn XP kann imho nur einen rdesktop hosten :( d.h. dein PC monitor ist nutzlos, denn da prangert ein lock window. vnc wird auch funktionieren ist aber etwas langsamer und nicht so flexibel wie rdesktop (einstellbare screen grösse). die anderen programme kenne ich nicht.
