- 14 Jan. 2008
Servus Gemeinde,
anbei das Ergebnis von tlp stat
Wo ist mein Fehler...oder läuft das T61p generell so laut.
Bin grade recht zufrieden mit meiner Installation und möchte nun ungern was anderes ausprobieren :-/
Ich hoffe ihr könnt mir helfen.
--- TLP 0.3.7.1 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
USB_AUTOSUSPEND=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
+++ System Info
System = LENOVO ThinkPad T61p 4402392
BIOS = 7LETD0WW (2.30 )
Release = Ubuntu 12.04.1 LTS
Kernel = 3.2.0-35-generic x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-3.2.0-35-generic root=UUID=8fc0f156-78a3-494a-9f20-058b3e877b2c ro quiet splash vt.handoff=7
+++ System Status
TLP power save = enabled
power source = battery
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 800000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 2401000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 2401000 2400000 2000000 1600000 1200000 800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 2401000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies = 2401000 2400000 2000000 1600000 1200000 800000 [kHz]
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
/proc/acpi/ibm/thermal = 45 39 30 48 50 -128 30 -128 31 41 40 -128 -128 -128 -128 -128 [°C]
/proc/acpi/ibm/fan = 3077 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 2
/proc/sys/vm/dirty_writeback_centisecs = 6000
/proc/sys/vm/dirty_expire_centisecs = 6000
/proc/sys/vm/dirty_ratio = 60
/proc/sys/vm/dirty_background_ratio = 1
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = takeMS SSD UTX-2200 120GB
Firmware = 5.0.2
APM Level = 128
TRIM = supported
scheduler = cfq
SMART info:
5 Reallocated_Sector_Ct = 0
9 Power_On_Hours = 2147483647 [h]
177 Wear_Leveling_Count = 0 [%]
194 Temperature_Celsius = 30 (Min/Max 30/30) [°C]
231 Temperature_Celsius = 0 [°C]
233 Media_Wearout_Indicator = 0 [%]
241 Total_LBAs_Written = 0.000 [TB]
/dev/sdb:
Model = Hitachi HCC547550A9E380
Firmware = JE3OA60C
APM Level = 128
scheduler = cfq
SMART info:
4 Start_Stop_Count = 101
9 Power_On_Hours = 74 [h]
193 Load_Cycle_Count = 109
194 Temperature_Celsius = 29 (Min/Max 18/42) [°C]
+++ SATA Aggressive Link Power Management
No AHCI-enabled host controller detected.
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (disabled by kernel)
+++ Wireless
bluetooth = off (software)
wifi = on
wwan = none (no device)
wlan0(iwl4965): power management = off (disabled by kernel)
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ ThinkPad Battery (Main)
/sys/devices/platform/smapi/BAT0/manufacturer = Panasonic
/sys/devices/platform/smapi/BAT0/model = 92P1133
/sys/devices/platform/smapi/BAT0/manufacture_date = 2008-07-01
/sys/devices/platform/smapi/BAT0/first_use_date = 2008-08-21
/sys/devices/platform/smapi/BAT0/cycle_count = 65
/sys/devices/platform/smapi/BAT0/design_capacity = 84240 [mWh]
/sys/devices/platform/smapi/BAT0/last_full_capacity = 73050 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_capacity = 47260 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_percent = 65 [%]
/sys/devices/platform/smapi/BAT0/remaining_running_time_now = 92 [min]
/sys/devices/platform/smapi/BAT0/remaining_charging_time = not_charging [min]
/sys/devices/platform/smapi/BAT0/power_now = -28695 [mW]
/sys/devices/platform/smapi/BAT0/power_avg = -30227 [mW]
/sys/devices/platform/smapi/BAT0/start_charge_thresh = 96 [%]
/sys/devices/platform/smapi/BAT0/stop_charge_thresh = 100 [%]
/sys/devices/platform/smapi/BAT0/force_discharge = 0
+++ Runtime Power Management
/sys/bus/pci/devices/0000:00:00.0/power/control = auto [Host]
/sys/bus/pci/devices/0000:00:19.0/power/control = auto [Ethernet]
/sys/bus/pci/devices/0000:00:1b.0/power/control = auto [Audio]
/sys/bus/pci/devices/0000:03:00.0/power/control = auto [Wireless]
/sys/bus/pci/devices/0000:15:00.1/power/control = auto [Firewire]
/sys/bus/pci/devices/0000:15:00.2/power/control = auto [SD]
/sys/bus/pci/devices/0000:15:00.4/power/control = auto [Card]
/sys/bus/pci/devices/0000:15:00.5/power/control = auto [Card]
+++ USB
tlp usb autosuspend = enabled
tlp usb blacklist = (not configured)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 004 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 005 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 006 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 007 Device 001 ID 1d6b:0001 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 1.1 root hub (hub)
Bus 003 Device 002 ID 0483:2016 control = auto, autosuspend_delay_ms = 2000 -- SGS Thomson Microelectronics Fingerprint Reader (no driver)
Bus 006 Device 002 ID 17ef:1003 control = auto, autosuspend_delay_ms = 2000 -- Lenovo Integrated Smart Card Reader (no driver)
