T460s Ubuntu 16.04 LTS Probleme mit Package Installation
Sewing31
Rather New Member
27 Okt. 2016
Hallo liebe Community,
ich als Linux Anfänger habe das problem, dass ich beim installieren von packages immer diese Meldung erhalte
[TABLE="width: 100%"]
[TR]
[TD="class: alt2 QuoteBorder"]Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 3.006 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu xenial/main amd64 git amd64 1:2.7.4-0ubuntu1 [3.006 kB]
Fetched 3.006 kB in 0s (3.606 kB/s)
(Reading database ... 229083 files and directories currently installed.)
Preparing to unpack .../git_1%3a2.7.4-0ubuntu1_amd64.deb ...
Unpacking git (1:2.7.4-0ubuntu1) over (1:2.7.4-0ubuntu1) ...
Setting up runit (2.1.2-3ubuntu1) ...
start: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
dpkg: error processing package runit (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up git (1:2.7.4-0ubuntu1) ...
dpkg: dependency problems prevent configuration of git-daemon-run:
git-daemon-run depends on runit; however:
Package runit is not configured yet.
dpkg: error processing package git-daemon-run (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
runit
git-daemon-run
E: Sub-process /usr/bin/dpkg returned an error code (1)[/TD]
[/TR]
[/TABLE]
Es scheint also Probleme mit diesen beiden Packages zu geben. Ich weiss nur leider nicht, wie ich die behebe. Vielleicht kann mir ja jemand helfen?
Danke schon einmal
Der Fehler scheint wohl darin zu liegen, dass runit nach der Installation upstart als Diensteverwalter erwartet, aber seit neuestem systemd in Ubuntu verwendet wird.
Das hier sollte dein Problem beheben: http://askubuntu.com/a/665742
Ratschlag für's nächste Mal, auch für andere Foren: stets den Befehl der zur Ausgabe geführt hat mit posten.
