Hi chwanziWhat happens if you press Esc?
I don't know if it came with nfcYou have du reprogramm an insert: Machine Type, Serial-Number, UUID and set the Clock.
Also this Question, does this Notebookvhave a NFC Feature?
I tried to search for a tool that can edit bios file and flash but i didn't get success, could you help me to find it out?Should not be the main problem. It only could be, that you have to fix another adress after fixing the written things
Please search for a tool/flash-utility which can add the missing numbers into the bios/uefi, because without you will ever get this notices.
Edit: The Clock you can set in BIOS if you can come in, or in Windows, that is not a real problem and the T440 should also work with wrong date and time![]()
Thanks bro for your interested posts, i faced problems to run commands using winflash64, i must try all.I would say that could work, but it has to be used with the command line and a few options. (view the help-part of the tool; mostly an ? or -? in the command line after the exe-file)
I am not the specialist for flashing thinkpads, but those problems on desktop hardware could be fixed like this with options, or I had to usw Intel FPT (Firmware Programming Tool). FPT is not a simple tool and maybe not that easy to find.
It is a very good tool to reprogramm everything, but the version of FPT has to match with ther firmware you would like to flash, so you need a specialist who can say what version is needed.
I am sorry that I cannot help further.
