T6x SXGA+ Display aus Toshiba M4 Tablet ins T60 14.1?
T42-Freund a.k.a. Padex
10 Mai 2008
Bei meiner Suche nach einem SXGA+ Display für den 14.1" T60 bin ich über das Toshiba Display LTD141KN5K
gestolpert...
Obwohl es in einem Tablet verbaut wurde ist es aber wohl kein FlexView, aber den Typ (TN, S-PVA oder IPS) des Displays konnte ich leider nicht herausfinden. Da ist Toshiba etwas eigen.
Nun ist die Frage, ob es wohl im T60 läuft?!
Meine bisherige Recherche ergab:
Die Pinbelegung laut einem baugleichen Toshiba Display ist:
[TABLE="class: simple"]
[TR]
[TH]Terminal[/TH]
[TH]cable[/TH]
[TH]symbol[/TH]
[TH]function[/TH]
[/TR]
[TR]
[TD] 1[/TD]
[TD]blue single[/TD]
[TD]V[SUB]SS[/SUB][/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD] 2[/TD]
[TD]V[SUB]DD[/SUB][/TD]
[TD]Power supply: +3.3V[/TD]
[/TR]
[TR]
[TD] 3[/TD]
[/TR]
[TR]
[TD] 4[/TD]
[TD]N/C[/TD]
[TD]V[SUB]EDID[/SUB][/TD]
[TD]DDC 3.3V POWER SUPPLY : +3.3V[/TD]
[/TR]
[TR]
[TD] 5[/TD]
[TD]N/C[/TD]
[TD]NC[/TD]
[TD]Non-connectionz[/TD]
[/TR]
[TR]
[TD] 6[/TD]
[TD]N/C[/TD]
[TD]CLK[SUB]EDID[/SUB][/TD]
[TD]DDC Clock (SCL)[/TD]
[/TR]
[TR]
[TD] 7[/TD]
[TD]N/C[/TD]
[TD]DATA[SUB]EDID[/SUB][/TD]
[TD]DDC Data (SDA)[/TD]
[/TR]
[TR]
[TD] 8[/TD]
[TD]blue pair 1[/TD]
[TD]RxOIN0-[/TD]
[TD]Negative LVDS differential data input (Odd), [R0-R5, G0][/TD]
[/TR]
[TR]
[TD] 9[/TD]
[TD]black pair 1[/TD]
[TD]RxOIN0+[/TD]
[TD]Positive LVDS differential data input (Odd), [R0-R5, G0][/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]blue pair 2[/TD]
[TD]RxOIN1-[/TD]
[TD]Negative LVDS differential data input (Odd), [G1-G5, B0-B1][/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]black pair 2[/TD]
[TD]RxOIN1+[/TD]
[TD]Positive LVDS differential data input (Odd), [G1-G5, B0-B1][/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]blue pair 3[/TD]
[TD]RxOIN2-[/TD]
[TD]Negative LVDS differential data input (Odd), [B2-B5, HS, VS, DE][/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]black pair 3[/TD]
[TD]RxOIN2+[/TD]
[TD]Positive LVDS differential data input (Odd), [B2-B5, HS, VS, DE][/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]blue pair 4[/TD]
[TD]RxOCLKIN-[/TD]
[TD]Negative LVDS differential clock input (Odd)[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]black pair 4[/TD]
[TD]RxOCLKIN+[/TD]
[TD]Positive LVDS differential clock input (Odd)[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]black pair 5[/TD]
[TD]RxEIN0-[/TD]
[TD]Negative LVDS differential data input (Even), [R0-R5, G0][/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]blue pair 5[/TD]
[TD]RxEIN0+[/TD]
[TD]Positive LVDS differential data input (Even), [R0-R5, G0][/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]black pair 6[/TD]
[TD]RxEIN1-[/TD]
[TD]Negative LVDS differential data input (Even), [G1-G5, B0-B1][/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]blue pair 6[/TD]
[TD]RXEIN1+[/TD]
[TD]Positive LVDS differential data input (Even), [G1-G5, B0-B1][/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]black pair 7[/TD]
[TD]RxEIN2-[/TD]
[TD]Negative LVDS differential data input (Even), [B2-B5, HS, VS, DE][/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]blue pair 7[/TD]
[TD]RxEIN2+[/TD]
[TD]Positive LVDS differential data input (Even), [B2-B5, HS, VS, DE][/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]GND[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]blue pair 8[/TD]
[TD]RxECLKIN-[/TD]
[TD]Negative LVDS differential clock input (Even)[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]black pair 8[/TD]
[TD]RxECLKIN+[/TD]
[TD]Positive LVDS differential clock input (Even)[/TD]
[/TR]
[/TABLE]
Einen EDID hat es auch und die Daten lauten:
[TR]
[TD]X Resolution[/TD]
[TD]1400[/TD]
[/TR]
[TR]
[TD]Y Resolution[/TD]
[TD]1050[/TD]
[/TR]
[TR]
[TD]Vertical Frequency[/TD]
[TD]60[/TD]
[/TR]
[TR]
[TD]Maximum Vertical Frequency[/TD]
[TD]63 Hz[/TD]
[/TR]
[TR]
[TD]Minimum Vertical Frequency[/TD]
[TD]40 Hz[/TD]
[/TR]
[TR]
[TD]Maximum Horizontal Frequency[/TD]
[TD]67 KHz[/TD]
[/TR]
[TR]
[TD]Minimum Horizontal Frequency[/TD]
[TD]43 KHz[/TD]
[/TR]
[TR]
[TD]Maximum Pixel Clock[/TD]
[TD]110 MHz[/TD]
[/TR]
[TR]
[TD]Preferred Pixel Clock[/TD]
[TD]108 Mhz[/TD]
[/TR]
[TR]
[TD]Horizontal Active[/TD]
[TD]1400 pixels[/TD]
[/TR]
[TR]
[TD]Horizontal Blanking[/TD]
[TD]288 pixels[/TD]
[/TR]
[TR]
[TD]Horizontal Sync Offset[/TD]
[TD]8 pixels[/TD]
[/TR]
[TR]
[TD]Horizontal Sync Pulse Width[/TD]
[TD]8 pixels[/TD]
[/TR]
[TR]
[TD]Vertical Active[/TD]
[TD]1050 lines[/TD]
[/TR]
[TR]
[TD]Vertical Blanking[/TD]
[TD]16 lines[/TD]
[/TR]
[TR]
[TD]Vertical Sync Offset[/TD]
[TD]4 lines[/TD]
[/TR]
[TR]
[TD]Vertical Sync Pulse Width[/TD]
[TD]4 lines[/TD]
[/TR]
[/TABLE]
Falls man es umflashen müsste, hier die *.dta:
0x00 00 FF FF FF FF FF FF 00 30 64 20 55 01 01 01 01
0x10 18 0F 01 02 80 1D 15 FF 0A 0F 15 9A 56 4B 8B 26
0x20 20 50 54 00 00 00 90 40 01 01 01 01 01 01 01 01
0x30 01 01 01 01 01 01 30 2A 78 20 51 1A 10 40 08 08
0x40 44 00 1F D7 10 00 00 1E 00 00 00 FD 00 28 3F 2B
0x50 43 0B 00 0A 20 20 20 20 20 20 00 00 00 FC 00 4C
0x60 54 44 31 34 31 4B 4E 35 4B 0A 20 20 00 00 00 FF
0x70 00 33 48 52 35 46 31 30 30 37 31 35 20 20 00 08
Das Panel wäre eben sehr günstig zu bekommen :D
MUßt wahrscheinlich den CCFL Stecker umbauen und der Rahmen wird auch nicht passen wenn es das für 60 Euro ist (was für mich nicht günstig ist). EDID müßte man ausprobieren. Mal gehts mal gehts nicht. Bisher habe ich alle wo es nicht ging mit Samsung oder BOE EDID zum Laufen bekommen. Ob die Qualität vom dem besser ist als die vom Nachfolger der im T61 sitzt??? Kerze ist heller.
FRG
jup. Der CCFL-Stecker auf alle Fälle. Werde nun erst mal mit einem UXGA experimentieren, dass aber auch nicht gerade die "Leuchte" ist :( (~150 nits)
