Schrauben-set für T400
  • Ersteller Ersteller Thinker2000
  • Erstellt am Erstellt am
T400: http://www-307.ibm.com/pc/support/site.wss/MIGR-70427.html
Screw kit (including nylon-coated screws):
* M2 × 2 mm with washer, camera (2)
* M2 × 2.7 mm (black), flat head (4)
* M2 × 2.8 mm (silver), flat head (8 )
* M2 × 3 mm (silver), small head (26)
* M2 × 3.5 mm (gold), flat head (14)
* M2 × 3 mm (black), tamper proof head (2)
* M2 × 5 mm (black), flat head (10)
* M2 × 9.5 mm (black), bind head (10)
* M2 × 14 mm (black), flat head (10)
* M2 × 17 mm (10)
* M2.5 Hex stud (2)
* M2.5 × 4 mm, flat head (10)
* M2.5 × 6.5 mm, flat head (12)
* HDD screw M3 × 2.8 (black), flat head (4)
* M3 × 3 mm (2)
* M3 × 4 mm security hex socket (2)
* Screw cap (circle) (4)
* Screw cap (cube) (2)
T4*/R5*: http://www-307.ibm.com/pc/support/site.wss/MIGR-46504.html
* M2 × 2.7 mm (silver), small head (10)
* M2 × 3 mm (silver), small head (20)
* M2 × 3 mm (from outside), pan head (10)
* M2 × 4 mm (black), bind head (30)
* M2 × 4 mm (black), small head (10)
* M2 × 5 mm (gold), bind head (2)
* M2 × 5 mm (black), flat head (20)
* M2 × 10 mm (black), flat head (30)
* M2 × 12 mm (black), flat head (5)
* M2 × 14 mm (black), bind head (10)
* M2 × 14 mm (black), TR7 (5)
* M2 × 14.9 mm for drive bay (5)
* M2 × 19 mm (black), bind head (5)
* M2.5 × 3 mm (gold), flat head (5)
* M2.5 × 4.8 mm (black), bind head (10)
* M3 × 3 mm (PHILLIPS/slotted) (2)
* Hex stud (5) v Security screw (1)
* Screw caps (square, thin)
* Screw caps (oval, not painted)
* Screw caps (not painted)
* Screw caps (square)
* Tape on Bluetooth wireless antenna
Mit Masse unterschiedliche Schraubenlängen
Hmm, doof. bei ebay gibt es kein schraubenset für das T400... außer von einem chinesen...
Frage doch bei unserem Forensponsor nach. Telefonnummer steht ganz oben unter "Impressum"
