Samsung 540 EVO friert ein.
weelkin
7 Nov. 2011
ich habe letztens ein Firmware upgrade meiner Samsung SSD gemacht ( auf EXT0DB6Q ).
Jetzt hängt mein System öfters mal für ein paar Sekunden.
dmesg sagt dazu:
[ 1124.064305] ata1.00: NCQ disabled due to excessive errors
[ 1124.064315] ata1.00: exception Emask 0x0 SAct 0x300 SErr 0x0 action 0x6 frozen
[ 1124.064321] ata1.00: failed command: WRITE FPDMA QUEUED
[ 1124.064331] ata1.00: cmd 61/60:40:00:42:f7/00:00:12:00:00/40 tag 8 ncq 49152 out
                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 1124.064335] ata1.00: status: { DRDY }
[ 1124.064339] ata1.00: failed command: WRITE FPDMA QUEUED
[ 1124.064346] ata1.00: cmd 61/40:48:60:48:f7/01:00:12:00:00/40 tag 9 ncq 163840 out
[ 1124.064349] ata1.00: status: { DRDY }
[ 1124.064357] ata1: hard resetting link
[ 1124.369316] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1124.370921] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 1124.370930] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1124.370934] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1124.371086] ata1.00: supports DRM functions and may not be fully accessible
[ 1124.372611] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 1124.372617] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1124.372621] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1124.372792] ata1.00: supports DRM functions and may not be fully accessible
[ 1124.372860] ata1.00: configured for UDMA/133
[ 1124.383317] ata1.00: device reported invalid CHS sector 0
[ 1124.383327] ata1.00: device reported invalid CHS sector 0
[ 1124.383372] ata1: EH complete
Er re-settet also den SATA link. Hat jemand von euch das auch schonmal gesehen?
Kernel ist: 4.0.4
Thinkpad: x220
SSD: Samsung SSD 840 EVO 500GB
Gruß,
weelkin
Tritt das nur im Batteriebetrieb oder auch im Netzbetrieb auf?
scheint am powermanagement zu liegen.
moderne SSD haben stromsparmodie die "ältere" chipsätze noch nicht beherschen, würde mal in die richtung "forschen".
leider habe ich bei linux null ahnung wo an welchen stellen geschraubt werden kann.
SSD smartwerte konrollieren, .....
welches dateisystem ?
sektor null problem hat doch mit dem MBR zu tun, oder ?
Dann ist entweder die SSD kaputt oder hat einen Wackelkontakt.
