[ 0.000000] BIOS-e820: 000000007fed0000 - 000000007fee5000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007fee5000 - 000000007ff00000 (ACPI NVS)
[ 0.000000] modified: 000000007fed0000 - 000000007fee5000 (ACPI data)
[ 0.000000] modified: 000000007fee5000 - 000000007ff00000 (ACPI NVS)
[ 0.000000] ACPI: RSDP 000f6c00 00024 (v02 IBM )
[ 0.000000] ACPI: XSDT 7fed6ff2 0005C (v01 IBM TP-1Y 00001270 LTP 00000000)
[ 0.000000] ACPI: FACP 7fed7100 000F4 (v03 IBM TP-1Y 00001270 IBM 00000001)
[ 0.000000] ACPI Warning: 32/64X length mismatch in Gpe1Block: 0/32 (20090903/tbfadt-526)
[ 0.000000] ACPI Warning: Optional field Gpe1Block has zero address or length: 000000000000102C/0 (20090903/tbfadt-557)
[ 0.000000] ACPI: DSDT 7fed72e7 0DB08 (v01 IBM TP-1Y 00001270 MSFT 0100000E)
[ 0.000000] ACPI: FACS 7fef6000 00040
[ 0.000000] ACPI: SSDT 7fed72b4 00033 (v01 IBM TP-1Y 00001270 MSFT 0100000E)
[ 0.000000] ACPI: ECDT 7fee4def 00052 (v01 IBM TP-1Y 00001270 IBM 00000001)
[ 0.000000] ACPI: TCPA 7fee4e41 00032 (v01 IBM TP-1Y 00001270 PTL 00000001)
[ 0.000000] ACPI: APIC 7fee4e73 0005A (v01 IBM TP-1Y 00001270 IBM 00000001)
[ 0.000000] ACPI: MCFG 7fee4ecd 0003E (v01 IBM TP-1Y 00001270 IBM 00000001)
[ 0.000000] ACPI: BOOT 7fee4fd8 00028 (v01 IBM TP-1Y 00001270 LTP 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.028081] ACPI: Core revision 20090903
[ 0.100001] ACPI: bus type pci registered
[ 0.100001] ACPI: EC: EC description table is found, configuring boot EC
[ 0.109306] ACPI: Interpreter enabled
[ 0.109312] ACPI: (supports S0 S3 S4 S5)
[ 0.109337] ACPI: Using IOAPIC for interrupt routing
[ 0.117808] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 0.117808] ACPI: Power Resource [PUBS] (on)
[ 0.121131] ACPI: ACPI Dock Station Driver: 3 docks/bays found
[ 0.121157] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.122288] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
[ 0.124075] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.124200] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
[ 0.124269] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP0._PRT]
[ 0.124342] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP2._PRT]
[ 0.124421] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.129034] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.129230] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.129424] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.129617] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.129810] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.130003] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.130196] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.130392] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.130952] ACPI: WMI: Mapper loaded
[ 0.130954] PCI: Using ACPI for IRQ routing
[ 0.138103] pnp: PnP ACPI init
[ 0.138116] ACPI: bus type pnp registered
[ 0.141511] pnp: PnP ACPI: found 13 devices
[ 0.141513] ACPI: ACPI bus type pnp unregistered
[ 0.141517] PnPBIOS: Disabled by ACPI PNP
[ 0.213500] ACPI: AC Adapter [AC] (on-line)
[ 0.213753] ACPI: Lid Switch [LID]
[ 0.213809] ACPI: Sleep Button [SLPB]
[ 0.213867] ACPI: Power Button [PWRF]
[ 0.226098] ACPI: Thermal Zone [THM0] (43 C)
[ 0.314650] ACPI: Battery Slot [BAT0] (battery present)
[ 0.390145] ehci_hcd 0000:00:1d.7: power state changed by ACPI to D0
[ 0.416663] uhci_hcd 0000:00:1d.0: power state changed by ACPI to D0
[ 0.417410] uhci_hcd 0000:00:1d.1: power state changed by ACPI to D0
[ 1.371507] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
[ 1.430075] radeon 0000:01:00.0: power state changed by ACPI to D0
[ 9.870865] parport_pc 00:0a: reported by Plug and Play ACPI
[ 10.280802] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[ 10.280805] thinkpad_acpi: [url]http://ibm-acpi.sf.net/[/url]
[ 10.280808] thinkpad_acpi: ThinkPad BIOS 1YET62WW (1.27 ), EC 1YHT29WW-1.06
[ 10.280810] thinkpad_acpi: IBM ThinkPad T43, model 26684DG
[ 10.280813] thinkpad_acpi: WARNING: Outdated ThinkPad BIOS/EC firmware
[ 10.280815] thinkpad_acpi: WARNING: This firmware may be missing critical bug fixes and/or important features
[ 10.361037] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is blocked
[ 10.362705] Registered led device: tpacpi::thinklight
[ 10.362738] Registered led device: tpacpi::power
[ 10.362756] Registered led device: tpacpi::standby
[ 10.371031] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 10.379110] thinkpad_acpi: fan_init: initial fan status is unknown, assuming it is in auto mode
[ 10.379725] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input6
