8X01-2060-E61P-05UX-HEP8-9AU4-****-****
Windows 7 6.1
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 10.0.10.100
Internal Version: 10,0,10,100
Recorder: <HL-DT-ST DVDRAM GSA-U20N>Version: HX12 - HA 1 TA 0 - 10.0.10.100
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <HL-DT-ST DVDRAM GSA-U20N >Version: HX12 - HA 1 TA 0 - 10.0.10.100
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-U20N E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 3990MB (4085784kB)
Free physical memory: 1998MB (2046376kB)
Memory in use : 49 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.5.2010
UDF/ISO Zusammenstellung
18:21:28 #1 Text 0 File SCSIPTICommands.cpp, Line 464
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:21:28 #2 PHASE 114 File dlgbrnst.cpp, Line 1827
DVD-Video files reallocation completed (no file modified)
18:21:28 #3 Text 0 File Isodoc.cpp, Line 6956
UDF document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:21:28 #4 PHASE 111 File dlgbrnst.cpp, Line 1827
DVD-Video files sorted
18:21:28 #5 ISO9660GEN -11 File Geniso.cpp, Line 3336
First writeable address = 0 (0x00000000)
18:21:28 #6 Text 0 File DVDPlusDualLayer.cpp, Line 1460
SetDriveCaps: Set LAST LBA of layer 1 to 1947855
18:21:28 #7 Text 0 File compose.cpp, Line 874
GenUDF2: 1 transfer items prepared.
18:21:28 #8 ISO9660GEN -11 File Geniso.cpp, Line 3336
18:21:28 #9 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
18:21:29 #10 Text 0 File DlgWaitCD.cpp, Line 314
[E: DVDRAM GSA-U20N ] Last possible write address on media: 4173823
Last address to be written: 3691343
18:21:29 #11 Text 0 File DlgWaitCD.cpp, Line 326
[E: DVDRAM GSA-U20N ] Write in overburning mode: NO (enabled: CD)
18:21:29 #12 Text 0 File DlgWaitCD.cpp, Line 2890
Recorder: HL-DT-ST DVDRAM GSA-U20N, Media type: DVD+R DL
Disc Manufacturer ID: <MBIPG101>, Media Type ID: <R10>, Product revision number: 65
Disc Application Code: 0, Extended Information Indicators: 3
18:21:29 #13 Text 0 File DlgWaitCD.cpp, Line 499
[E: DVDRAM GSA-U20N ] >>> Protocol of DlgWaitCD activities: <<<
18:21:29 #14 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 3691344 (3691344) = #3691344/820:17.69
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3691344 blocks [E: HL-DT-ST DVDRAM GSA-U20N]
18:21:29 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1001
Prepare [E: HL-DT-ST DVDRAM GSA-U20N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7559872512, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3691344 | 0 | 0x00
3691344 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: DVD+R DL
18:21:29 #16 Text 0 File SCSIPTICommands.cpp, Line 251
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:21:29 #17 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:21:29 #18 PHASE 24 File dlgbrnst.cpp, Line 1827
Caching of files started
18:21:29 #19 Text 0 File Burncd.cpp, Line 4400
Cache writing successful.
18:21:29 #20 PHASE 25 File dlgbrnst.cpp, Line 1827
Caching of files completed
18:21:29 #21 PHASE 28 File dlgbrnst.cpp, Line 1827
Maximum transfer rate test started
18:21:29 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2769
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:21:29 #23 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 590400
18:21:29 #24 Text 0 File CUDFTransferItem2.cpp, Line 718
GenUDF2 FS Layout:
Sectors to be written: 3691344
Session Start: Sector 0
Volume Structure: Sector [0, 261] (262 Sectors)
Meta Data: Sector [262, 297] (36 Sectors)
Data: Sector [298, 3691064] (3690767 Sectors)
After Data: Sector [3691065, 3691071] (7 Sectors)
Trailer Track: Sector [3691072, 3691343] (272 Sectors)
GenUDF2 Parameters:
PrepTime: 05-14-2010 18:21:28
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: DVDVideo
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 4173824
Multi Session Mode: None
Disc Type: DVD+R DL
OS Class: 0
Volume ID: Neu
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 1
ECC Block Length: 16
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 16
Make Writable: 0
Access Type: Read-only
18:24:53 #25 Text 0 File WriterStatus.cpp, Line 244
<E: HL-DT-ST DVDRAM GSA-U20N> start writing Lead-Out at LBA 3691344 (385350h), length 0 blocks
18:24:53 #26 PHASE 29 File dlgbrnst.cpp, Line 1776
Maximum transfer rate test completed: 26.2x (36.188 KB/s)
18:24:53 #27 PHASE 36 File dlgbrnst.cpp, Line 1827
Burn process started at 4x (5.540 KB/s)
18:24:53 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2769
18:24:53 #29 Text 0 File DVDPlusDualLayer.cpp, Line 1941
GetDriveCaps: LAST LBA of layer 1 is 1947855
18:26:05 #30 SPTI -1066 File SCSIPassThrough.cpp, Line 217
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A AD 21 00 3E 24 00 00 C0 00 07
Buffer x07f91180: Len x804
18:26:05 #31 Text 0 File DVDPlusDualLayer.cpp, Line 1460
18:26:05 #32 Text 0 File DVDPlusDualLayer.cpp, Line 1941
18:26:05 #33 Text 0 File DVDPlusDualLayer.cpp, Line 785
L0 Data Zone Capacity set to 1947856 (1DB8D0h, 3804MB) -> OK, confirmed setting
18:26:09 #34 CDR -1205 File DVDPlusDualLayer.cpp, Line 812
Burning Layer 1
18:26:09 #35 Text 0 File DVDPlusDualLayer.cpp, Line 822
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
18:26:09 #36 Text 0 File Cdrdrv.cpp, Line 10559
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: MBIPG101
Media type ID: R10
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..783]:
00 00 03 4D 42 49 50 47 - 31 30 31 52 31 30 41 40 ...MBIPG101R10A@
25 25 37 10 00 2C 6C 00 - 2C 6C 20 1F 0C 0C 14 14 %%7..,l.,l......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
04 00 33 7B 5C 00 25 69 - 3A 26 1C 0A 0B 20 02 01 ..3{\.%i:&......
01 00 00 58 62 42 26 1C - 0A 0B 20 02 01 01 00 5F ...XbB&........_
84 00 00 43 66 3E 26 1C - 0A 0B 20 02 01 01 00 00 ...Cf>&.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
E1 0F 32 10 00 03 00 00 - 00 FC FF FF 00 22 D7 FF ..2.........."..
25 25 37 15 00 2D 6D 00 - 2D 6D 19 19 0C 0B 0E 0E %%7..-m.-m......
00 00 00 10 00 19 19 0C - 0B 0E 0E 00 00 00 10 00 ................
04 00 33 7B 5C 00 2C 6D - 4B 19 10 05 04 10 00 00 ..3{\.,mK.......
00 00 00 55 65 3B 24 16 - 09 08 20 00 00 00 00 26 ...Ue;$........&
84 00 00 42 67 2F 24 16 - 09 08 20 00 00 00 00 00 ...Bg/$.........
18:26:09 #37 Text 0 File DVDPlusRW.cpp, Line 637
Start write address at LBA 0
DVD high compatibility mode: Yes
18:26:09 #38 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
18:26:09 #39 Text 0 File CUDFTransferItem2.cpp, Line 718
GenUDF2 FS Layout:
GenUDF2 Parameters:
UDF Revision: 1.02
Session Start: 0
Disc Type: DVD+R DL
OS Class: 0
Volume ID: Neu
Make Writable: 0
18:27:16 #40 SPTI -1061 File SCSIPassThrough.cpp, Line 217
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
CDB Data: 0x2A 00 00 01 6D E0 00 00 20 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0x90
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 3E 44 90
Buffer x11745d00: Len x10000
0x00 00 01 BA 44 00 3D 62 E4 BD 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 B4 ED 58 94 6D B5 03 29 70
0xB0 BA 1A DA 60 DB 0A 0E 48 34 B1 AB 0A 18 38 F5
18:27:16 #41 TRANSFER -20 File ThreadedTransfer.cpp, Line 1222
Could not perform Write
18:27:16 #42 CDR -1061 File Writer.cpp, Line 327
Internal target failure
18:27:16 #43 SPTI -1061 File SCSIPassThrough.cpp, Line 217
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x44
Sense Qual: 0x90
Sense Area: 0x71 00 04 00 00 00 00 0A 00 00 00 3E 44 90
18:27:16 #44 PHASE 127 File dlgbrnst.cpp, Line 1827
Generating DVD high compatibility borders
18:31:40 #45 SPTI -1039 File SCSIPassThrough.cpp, Line 217
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1039)
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Code: 0x09
Sense Qual: 0x02
Sense Area: 0x71 00 04 00 00 00 00 0A 35 01 04 3E 09 02
Buffer x04affa80: Len x20
18:31:40 #46 Text 0 File DVDPlusRW.cpp, Line 901
EndDAO: Last written address 93664
18:31:40 #47 CDR -1061 File WriterStatus.cpp, Line 291
18:31:40 #48 TRANSFER -24 File ThreadedTransfer.cpp, Line 1222
Could not perform end of Disc-at-once
18:31:40 #49 Text 0 File DVDPlusDualLayer.cpp, Line 1460
SetDriveCaps: Set LAST LBA of layer 1 to 0
18:31:40 #50 PHASE 38 File dlgbrnst.cpp, Line 1827
Burn process failed at 4x (5.540 KB/s)
18:31:40 #51 Text 0 File SCSIPTICommands.cpp, Line 301
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:31:40 #52 Text 0 File Cdrdrv.cpp, Line 11916
DriveLocker: UnLockVolume completed
18:31:40 #53 Text 0 File SCSIPTICommands.cpp, Line 464
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
