Optimierung, Performance, Verbesserungsvorschläge für Vista 64-Bit Clean Install
xsid
29 Mai 2007
meine TP T61 habe ich wie folgt mittels Clean Install neu aufgesetzt.
- Intel Chipset Driver/INF Update Utility INSTALL FIRST!!!
- Matrix Storage Manager Driver (NOTE: Only install this driver on systems without Turbo Memory. Do not download/install this driver if you
have installed the Turbo Memory driver.)
- ACPI Power "Management Driver" NOTE: The ACPI Power "Management Driver" and the Power "Manager" are two different things. The "Driver" is all that is necessary. The Power "Manager" is a ThinkVantage utility and is not necessary. (NOTE: If ThinkVantage Power Manager is
installed it can only be removed properly in "safe mode". As for the ACPI Power "Management Driver", uninstallation should never be
attempted.)
- Video Driver- Make sure to select the correct driver for integrated graphics (Intel 965/ Intel GMA X3100) or nVidia graphics (nVidia 140M or 570M) depending on what your laptop has for graphics.
- Monitor file for Windows 64
- Audio Driver
- UltrNav DRIVER
- UltraNav UTILITY
- Wifi Driver
- Hotkey Driver
- System Interface Driver
- Registry Patch enabling Device Initiated Power Management on SATA
- Intel PRO/1000 LAN adapter
- Modem Adapter
- Bluetooth +Bluetooth Driver Bluetooth Driver Install
Tips: Before installing the Driver, press Fn and F5 at the same time. You should see an on-screen display that allows you to turn "on"
Bluetooth. Now install the driver. If Fn + F5 does not work to turn on bluetooth then install ThinkVantage Access Connections. After
Access Connections has been installed you should be able to turn "on" Bluetooth and install the Bluetooth driver. After the bluetooth
driver is installed, you can uninstall ThinkVantage Access Connections from the control panel.
- Finger Print Reader
- Integrated Camera Driver
Habt Ihr zu dieser Installationsvariante Verbesserungvorschläge?
Beste Grüße
xsid
Windows 7 liegt nicht vor und ich wollte 64 Bit
Windows 7 liegt mir nicht vor und ich will mich mit Windows 64 Bit auseinandersetzen.
Windows XP mit 64-Bit, das ist nach meiner Recherche noch weniger empfehlenswert.
Beste Grüße
xsid
