Modem Doctor
www.pcwelt.de/downloads/tools_utilities/systemdiagnose/100879/
Carrier tests place your modem into a special diagnostic mode. In this mode, the modem connects to itself and simulates an on-line connection (minus the telephone line). When in this mode, Modem Doctor can use several different tests to determine if your modem is operating properly. The test is run twice. Depending on your modem and the driver interface that is loaded, , one test uses the Originate mode for testing, and the other test uses the Answer mode. These are indicated in the lower left hand corner of the testing window. There are three tests in all;
Meine frage:
Wozu benötiget man soein Programm?
Und was ist das mit der simulierten Internetverbinduing?
Bitte erläutern!
Danke
Meine frage:
Bitte erläutern!
Danke
