X2xx/s (X200/s-260) Mini Dock Plus Series 3 Vs x230
oxy
25 März 2015
Hi all,
it is not clear if Mini Dock Plus Series 3 supports x230.
Page http://support.lenovo.com/us/en/documents/pd014572 says yes to:
ThinkPad Mini Dock Plus Series 3 with USB 3.0 – 90W (433815U - U.S.)
ThinkPad Mini Dock Plus Series 3 with USB 3.0 – 170W (433835U - U.S.)
ThinkPad Mini Dock Plus Series 3 - 170W (433830U - 170W AC Adapter: U.S, Canada)
Page http://thinkwiki.de/ThinkPad_Mini_Dock_Series_3 says only with mechanical adaptation (??)
Page http://thinkwiki.de/Zubehör says yes!
Other pages do not list x230 among compatibles for mini dock + Series 3.
I was specially interested in the mino dock + s3 version 4338.
Also a general question: is there any dock option for x230 type 2325-78G with a dual HD display output?
Thanks a lot!
Welcome to thinkpad-forum oxy
As i have read here some time ago, it is neccessary to remove the adjustable bar next to the Powerbutton in order to dock a x230 in.
In addition there could be problems with some of the ports as the Dock isn't designed for x230 :(
(it seems that there is a little mistake in our Wiki ;) )
I haven't tried this myself so there should be people here that can give you more Details ;)
Für alle die des Englischen nicht mächtig sind(Ultrakurzfassung, zum Übersetzen bin ich jetzt zu faul :p ):
Oxy möchte ein x230 auf einer MiniDockPlus-Series3 (4338) betreiben um so 2 digitale HD-Displays anschließen zu können.
Welche Docks sind denn offiziell "designed for X230"? Oder gibt es da keine?
"Docks" gibt es offiziell keine (die muss man mechanisch anpassen wie auch im Wiki steht)
Für die x230 sind eigentlich die Ultrabase Series-3 gemacht (die passen auch ohne Modifikation) ;)
(da scheint sich eine Ungenauigkeit in's Wiki eingeschlichen zu haben ;) )
There aren't official "Docks" for x230 (the Docks have to be modified mechanically to fit a x230, like mentioned in the Wiki)
For x230 Ultrabase Series-3 are made for (these fit without modification) ;)
Ultrabases have however only 1 VGA and 1 Display Port. Not optimal for a 2Monitor desk,
since one hast to combine 2 different types of output side by side.
Of course the X230 is compatible with all Series 3 Mini docks! :) Only the X230 Tablet / X230t is not compatible with the normal docks and requires the UltraBase Series 3. Note however that the X230 can only drive 2 displays at the same time.
Bitte keine Falschinformationen verbreiten. ;)
Ich habe ein Mini Dock Series 3 für das X230 (gebraucht gekauft). Von einer Modifikation war bei der Artikelbeschreibung keine Rede und es sieht auch nicht so aus. Das X230 passt auf jeden Fall problemlos rein, es kippelt lediglich etwas:
http://thinkpad-forum.de/threads/184901-Standfestigkeit-des-X230-im-ThinkPad-Mini-Dock-Series-3
Hier steht auch, dass das X230 passt:
http://thinkspot.de/thinkpad-mini-dock-plus-series-3/
http://thinkspot.de/mini-dock-series-3/
(außerdem bei diversen Ebay-Angeboten etc.)
Of course the Mini Dock Series will work with your X230... You don't need the Plus version though since the integrated graphics chip will only support 2 external displays at once. So there's no need for more than 2 digital video ports.
The only exception is the X230t convertible which only works with the Ultrabase Series 3... you can however mod the Mini Dock 3 to fit X230t, too.
Cheers,
Matt
I can confirm that. I used X220 as well as X230 on a minidock series 3 plus (without usb 3.0) and it ist just plug and play.
The tablets need some light modifications.
Über die Angabe im Wiki bin ich auch mehrmals gestolpert. Andere Seiten bzw. Angebote waren ähnlich uneindeutig, von einer mechanischen Anpassung stand aber nirgends etwas.
Letztendlich bin ich direkt bei Lenovo gelandet. http://support.lenovo.com/us/en/documents/um006391 kann man entnehmen, dass die x230 auch direkt passen sollten.
@oxy
This table shows the compatibility.
Ich kann zumindest bestaetigen dass x230t nicht kompatibel ist! Hab dennoch ein paar MiniDocks und den "Hardware" Hack angewandt. Das ganze ist nicht toll, ich wuerd es unter keinen Umstaenden empfehlen: Der x230t liegt sehr, sehr wackeling drinnen, Bedienen (Tastatur, Stift) trau ich mich fast nicht.
Externe Displays funktionieren zwei bei mir (eins ueber DVI, eins ueber VGA).
USB 2.0 funktioniert nicht! D.h. man kann nichtmal Tastatur und sonstiges Zubehoer direkt mit dem Dock verwenden. Das neuste Modell hat allerdings einen einzigen USB 3.0 Anschluss. Dieser funktioniert - und hier hab ich einen USB Hub angeschlossen an welchem dann die Tastatur haengt.
Ich habe 2x Ultrabase (Buero und zu Hause) und das Ding ist einfach genial und relativ stabil.
Die Minidocks verwende ich lediglich an 2 anderen Orten wo ich ~1x/Monat bin.
Muesste ich eine kaufen, wuerde ich auf jeden Fall die UltraBase nehmen auch wenn sie teurer ist.
An beiden Ultra-Bases habe ich uebrigens zwei externe Monitore haengen und verwende zusaetzlich das interne Display mit dem Stift als Notizbuch (waehrend es in der UltraBase ist).
Der erste externe Monitor geht bei mir entweder ueber DisplayLink oder VGA und fuer den anderen hab ich jeweils um ~17$ bei Amazon den Lenovo DisplayLink Adapter gekauft ...
Habe die Angaben im Kaste auf der Wiki-Seite mal geändert - oder betrifft die mechanische Anpassung neben dem 230T auch das X220?
Dürfte auch das X220t betreffen, wenn das X230t nicht passt. Evtl. mag das mal ebenfalls jemand überprüfen!
Kleine Anmerkung dazu:
Der USB 3.0-Port funktioniert zwar in Verbindung mit dem X230t, ist aber elektrisch leider ein USB 2.0-Port obwohl dieser am USB 3.0-Controller hängt.
Ich weiß das man keine alten Threas wiederbelebt, aber ich habe den Beitrag per Suchfunktion gefunden und mir deswegen die Dockstation umsonst gekauft.
