Linksys SPA-3102 konfigurieren
Flatterlight
21 Okt. 2012
ich möchte meine analoge Telefonleitung an meine Asterisk Telefonanlage einbinden. Dafür habe ich mir eine SPA-3102 zugelegt. Diese müsste nun konfiguriert werden. Leider habe ich jedoch wenig bis gar keine Ahnung von der Konfiguration der analogen Seite. Ich hänge die Analogkonfiguration an.
[TABLE="class: stat, width: 100%"]
[TR="bgcolor: #d3d3d3"]
[/TR]
[TR="bgcolor: #dcdcdc"]
[TD]Line Enable:[/TD]
[TD]yesno[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TD="colspan: 4"][/TD]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]NAT Settings[/COLOR][/TD]
[/TR]
[TD]NAT Mapping Enable:[/TD]
[TD]yesno[/TD]
[TD]NAT Keep Alive Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]NAT Keep Alive Msg:[/TD]
[TD][/TD]
[TD]NAT Keep Alive Dest:[/TD]
[TD][/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]Network Settings[/COLOR][/TD]
[/TR]
[TD]SIP ToS/DiffServ Value:[/TD]
[TD][/TD]
[TD]SIP CoS Value:[/TD]
[TD][0-7][/TD]
[/TR]
[TD]RTP ToS/DiffServ Value:[/TD]
[TD][/TD]
[TD]RTP CoS Value:[/TD]
[TD][0-7][/TD]
[/TR]
[TD]Network Jitter Level:[/TD]
[TD]lowmediumhighvery highextremely high[/TD]
[TD]Jitter Buffer Adjustment:[/TD]
[TD]up and downup onlydown onlydisable[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]SIP Settings[/COLOR][/TD]
[/TR]
[TD]SIP Transport:[/TD]
[TD]UDPTCPTLS[/TD]
[TD]SIP Port:[/TD]
[TD][/TD]
[/TR]
[TD]SIP 100REL Enable:[/TD]
[TD]yesno[/TD]
[TD]EXT SIP Port:[/TD]
[TD][/TD]
[/TR]
[TD]Auth Resync-Reboot:[/TD]
[TD]yesno[/TD]
[TD]SIP Proxy-Require:[/TD]
[TD][/TD]
[/TR]
[TD]SIP Remote-Party-ID:[/TD]
[TD]yesno[/TD]
[TD]SIP GUID:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]SIP Debug Option:[/TD]
[TD]none1-line1-line excl. OPT1-line excl. NTFY1-line excl. REG1-line excl. OPT|NTFY|REGfullfull excl. OPTfull excl. NTFYfull excl. REGfull excl. OPT|NTFY|REG[/TD]
[TD]RTP Log Intvl:[/TD]
[TD][/TD]
[/TR]
[TD]Restrict Source IP:[/TD]
[TD]yesno[/TD]
[TD]Referor Bye Delay:[/TD]
[TD][/TD]
[/TR]
[TD]Refer Target Bye Delay:[/TD]
[TD][/TD]
[TD]Referee Bye Delay:[/TD]
[TD][/TD]
[/TR]
[TD]Refer-To Target Contact:[/TD]
[TD]yesno[/TD]
[TD]Sticky 183:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Auth INVITE:[/TD]
[TD]yesno[/TD]
[TD]Use Anonymous With RPID:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Use Local Addr In FROM:[/TD]
[TD]yesno[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]Proxy and Registration[/COLOR][/TD]
[/TR]
[TD]Proxy:[/TD]
[TD="colspan: 3"][/TD]
[/TR]
[TD]Outbound Proxy:[/TD]
[/TR]
[TD]Use Outbound Proxy:[/TD]
[TD]yesno[/TD]
[TD]Use OB Proxy In Dialog:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Register:[/TD]
[TD]yesno[/TD]
[TD]Make Call Without Reg:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Register Expires:[/TD]
[TD][/TD]
[TD]Ans Call Without Reg:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Use DNS SRV:[/TD]
[TD]yesno[/TD]
[TD]DNS SRV Auto Prefix:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Proxy Fallback Intvl:[/TD]
[TD][/TD]
[TD]Proxy Redundancy Method:[/TD]
[TD]NormalBased on SRV Port[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]Subscriber Information[/COLOR][/TD]
[/TR]
[TD]Display Name:[/TD]
[TD][/TD]
[TD]User ID:[/TD]
[TD][/TD]
[/TR]
[TD]Password:[/TD]
[TD][/TD]
[TD]Use Auth ID:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Auth ID:[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TD]Mini Certificate:[/TD]
[/TR]
[TD]SRTP Private Key:[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]Audio Configuration[/COLOR][/TD]
[/TR]
[TD]Preferred Codec:[/TD]
[TD]G711uG711aG726-16G726-24G726-32G726-40G729aG723[/TD]
[TD]Silence Supp Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Use Pref Codec Only:[/TD]
[TD]yesno[/TD]
[TD]Echo Canc Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]G729a Enable:[/TD]
[TD]yesno[/TD]
[TD]Echo Canc Adapt Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]G723 Enable:[/TD]
[TD]yesno[/TD]
[TD]Echo Supp Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]G726-16 Enable:[/TD]
[TD]yesno[/TD]
[TD]FAX CED Detect Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]G726-24 Enable:[/TD]
[TD]yesno[/TD]
[TD]FAX CNG Detect Enable:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]G726-32 Enable:[/TD]
[TD]yesno[/TD]
[TD]FAX Passthru Codec:[/TD]
[TD]G711uG711a[/TD]
[/TR]
[TD]G726-40 Enable:[/TD]
[TD]yesno[/TD]
[TD]FAX Codec Symmetric:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]DTMF Process INFO:[/TD]
[TD]yesno[/TD]
[TD]FAX Passthru Method:[/TD]
[TD]NoneNSEReINVITE[/TD]
[/TR]
[TD]DTMF Process AVT:[/TD]
[TD]yesno[/TD]
[TD]DTMF Tx Method:[/TD]
[TD]InBandAVTINFOAutoInBand+INFOAVT+INFO[/TD]
[/TR]
[TD]DTMF Tx Mode:[/TD]
[TD]NormalStrict[/TD]
[TD]DTMF Tx Strict Hold Off Time:[/TD]
[TD][/TD]
[/TR]
[TD]Release Unused Codec:[/TD]
[TD]yesno[/TD]
[TD]FAX Process NSE:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Symmetric RTP:[/TD]
[TD]yesno[/TD]
[TD]FAX Disable ECAN:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Audio Dump Option1:[/TD]
[TD]nb_innb_outfullall_lines_fullnone[/TD]
[TD]Audio Dump Option2:[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]Dial Plans[/COLOR][/TD]
[/TR]
[TD]Dial Plan 1:[/TD]
[/TR]
[TD]Dial Plan 2:[/TD]
[/TR]
[TD]Dial Plan 3:[/TD]
[/TR]
[TD]Dial Plan 4:[/TD]
[/TR]
[TD]Dial Plan 5:[/TD]
[/TR]
[TD]Dial Plan 6:[/TD]
[/TR]
[TD]Dial Plan 7:[/TD]
[/TR]
[TD]Dial Plan 8:[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]VoIP-To-PSTN Gateway Setup[/COLOR][/TD]
[/TR]
[TD]VoIP-To-PSTN Gateway Enable:[/TD]
[TD]yesno[/TD]
[TD]VoIP Caller Auth Method:[/TD]
[TD]nonePINHTTP Digest[/TD]
[/TR]
[TD]VoIP PIN Max Retry:[/TD]
[TD][/TD]
[TD]One Stage Dialing:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Line 1 VoIP Caller DP:[/TD]
[TD]none12345678[/TD]
[TD]VoIP Caller Default DP:[/TD]
[/TR]
[TD]Line 1 Fallback DP:[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TD]VoIP Caller ID Pattern:[/TD]
[/TR]
[TD]VoIP Access List:[/TD]
[/TR]
[TD]VoIP Caller 1 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 1 DP:[/TD]
[/TR]
[TD]VoIP Caller 2 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 2 DP:[/TD]
[/TR]
[TD]VoIP Caller 3 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 3 DP:[/TD]
[/TR]
[TD]VoIP Caller 4 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 4 DP:[/TD]
[/TR]
[TD]VoIP Caller 5 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 5 DP:[/TD]
[/TR]
[TD]VoIP Caller 6 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 6 DP:[/TD]
[/TR]
[TD]VoIP Caller 7 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 7 DP:[/TD]
[/TR]
[TD]VoIP Caller 8 PIN:[/TD]
[TD][/TD]
[TD]VoIP Caller 8 DP:[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]VoIP Users and Passwords (HTTP Authentication)[/COLOR][/TD]
[/TR]
[TD]VoIP User 1 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 1 DP:[/TD]
[/TR]
[TD]VoIP User 1 Password:[/TD]
[/TR]
[TD]VoIP User 2 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 2 DP:[/TD]
[/TR]
[TD]VoIP User 2 Password:[/TD]
[/TR]
[TD]VoIP User 3 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 3 DP:[/TD]
[/TR]
[TD]VoIP User 3 Password:[/TD]
[/TR]
[TD]VoIP User 4 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 4 DP:[/TD]
[/TR]
[TD]VoIP User 4 Password:[/TD]
[/TR]
[TD]VoIP User 5 ID Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 5 DP:[/TD]
[/TR]
[TD]VoIP User 5 Password:[/TD]
[/TR]
[TD]VoIP User 6 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 6 DP:[/TD]
[/TR]
[TD]VoIP User 6 Password:[/TD]
[/TR]
[TD]VoIP User 7 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 7 DP:[/TD]
[/TR]
[TD]VoIP User 7 Password:[/TD]
[/TR]
[TD]VoIP User 8 Auth ID:[/TD]
[TD][/TD]
[TD]VoIP User 8 DP:[/TD]
[/TR]
[TD]VoIP User 8 Password:[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]PSTN-To-VoIP Gateway Setup[/COLOR][/TD]
[/TR]
[TD]PSTN-To-VoIP Gateway Enable:[/TD]
[TD]yesno[/TD]
[TD]PSTN Caller Auth Method:[/TD]
[TD]nonePIN[/TD]
[/TR]
[TD]PSTN Ring Thru Line 1:[/TD]
[TD]yesno[/TD]
[TD]PSTN PIN Max Retry:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN CID For VoIP CID:[/TD]
[TD]yesno[/TD]
[TD]PSTN CID Number Prefix:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN Caller Default DP:[/TD]
[TD]12345678[/TD]
[TD]Off Hook While Calling VoIP:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Line 1 Signal Hook Flash To PSTN:[/TD]
[TD]DisabledDouble Hook Flash[/TD]
[TD]PSTN CID Name Prefix:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN Caller ID Pattern:[/TD]
[/TR]
[TD]PSTN Access List:[/TD]
[/TR]
[TD]PSTN Caller 1 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 1 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 2 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 2 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 3 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 3 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 4 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 4 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 5 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 5 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 6 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 6 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 7 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 7 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[TD]PSTN Caller 8 PIN:[/TD]
[TD][/TD]
[TD]PSTN Caller 8 DP:[/TD]
[TD]12345678[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]FXO Timer Values (sec)[/COLOR][/TD]
[/TR]
[TD]VoIP Answer Delay:[/TD]
[TD][/TD]
[TD]VoIP PIN Digit Timeout:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN Answer Delay:[/TD]
[TD][/TD]
[TD]PSTN PIN Digit Timeout:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN-To-VoIP Call Max Dur:[/TD]
[TD][/TD]
[TD]PSTN Ring Thru Delay:[/TD]
[TD][/TD]
[/TR]
[TD]VoIP-To-PSTN Call Max Dur:[/TD]
[TD][/TD]
[TD]PSTN Ring Thru CWT Delay:[/TD]
[TD][/TD]
[/TR]
[TD]VoIP DLG Refresh Intvl:[/TD]
[TD][/TD]
[TD]PSTN Ring Timeout:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN Dialing Delay:[/TD]
[TD][/TD]
[TD]PSTN Dial Digit Len:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN Hook Flash Len:[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]PSTN Disconnect Detection[/COLOR][/TD]
[/TR]
[TD]Detect CPC:[/TD]
[TD]yesno[/TD]
[TD]Detect Polarity Reversal:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]Detect PSTN Long Silence:[/TD]
[TD]yesno[/TD]
[TD]Detect VoIP Long Silence:[/TD]
[TD]yesno[/TD]
[/TR]
[TD]PSTN Long Silence Duration:[/TD]
[TD][/TD]
[TD]VoIP Long Silence Duration:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN Silence Threshold:[/TD]
[TD]very highhighmediumlowvery low[/TD]
[TD]Min CPC Duration:[/TD]
[TD][/TD]
[/TR]
[TD]Detect Disconnect Tone:[/TD]
[TD]yesno[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TD]Disconnect Tone:[/TD]
[/TR]
[/TR]
[TD="colspan: 4, align: left"][COLOR=#990000]International Control[/COLOR][/TD]
[/TR]
[TD]FXO Port Impedance:[/TD]
[TD]600900270+750||150nF220+820||120nF370+620||310nF320+1050||230nF370+820||110nF275+780||115nF120+820||110nF350+1000||210nF0+900||30nF600+2.16uF900+1uF900+2.16uF600+1uFGlobal[/TD]
[TD]Ring Frequency Min:[/TD]
[TD][/TD]
[/TR]
[TD]Dtmf Playback Level:[/TD]
[TD][/TD]
[TD]Dtmf Playback Twist:[/TD]
[TD][/TD]
[/TR]
[TD]SPA To PSTN Gain:[/TD]
[TD][/TD]
[TD]Ring Frequency Max:[/TD]
[TD][/TD]
[/TR]
[TD]PSTN To SPA Gain:[/TD]
[TD][/TD]
[TD]Ring Validation Time:[/TD]
[TD]100 ms150 ms200 ms256 ms384 ms512 ms640 ms1024 ms[/TD]
[/TR]
[TD]Tip/Ring Voltage Adjust:[/TD]
[TD]3.1 V3.2 V3.35 V3.5 V[/TD]
[TD]Ring Indication Delay:[/TD]
[TD]0256 ms512 ms 768 ms1024 ms1280 ms1536 ms1792 ms[/TD]
[/TR]
[TD]Operational Loop Current Min:[/TD]
[TD]10 mA12 mA14 mA16 mA[/TD]
[TD]Ring Timeout:[/TD]
[TD]0128 ms256 ms384 ms512 ms640 ms768 ms896 ms1024 ms1152 ms1280 ms1408 ms1536 ms1664 ms1792 ms1920 ms[/TD]
[/TR]
[TD]On-Hook Speed:[/TD]
[TD]Less than 0.5 ms3 ms (ETSI)26 ms (Australia)[/TD]
[TD]Ring Threshold:[/TD]
[TD]13.5-16.5 Vrms19.35-23.65 Vrms40.5-49.5 Vrms[/TD]
[/TR]
[TD]Current Limiting Enable:[/TD]
[TD]yesno[/TD]
[TD]Ringer Impedance:[/TD]
[TD]High (Normal)Synthesized (Poland,S.Africa,Slovenia)[/TD]
[/TR]
[TD]Line-In-Use Voltage:[/TD]
[TD][/TD]
[/TR]
[/TABLE]
Vielleicht kann mir jemand weiter helfen.
Flatterlight
