hat jemand die Bedeutung der Blinkcodes der Akku LED parat? In der Dokumentation steht dazu leider nichts drin.
Sieht dann also so aus, als sei das Mainboard defekt (sozusagen Todesblinken). Das Netzteilkabel hatte sekundärseitig nämlich einen Kurzschluss.
Re: Lenovo 3000 N500 23G Battery Status LED problem.
02-21-2009 08:40 AM
Hello,
I have been researching a little bit about the laptops and this is what i have found:
Battery status as in manual for N500:
Blue: The battery is charged to 95% or more of its capacity.
Blinking blue: The battery is being trickle-charged.
Orange: The battery is being normally charged.
Off: The computer is operating on battery power, and the battery has enough power.
Blinking orange: The computer is operating on battery power, and the battery is charged to no more than 8% of capacity.
Battery status for N200 machines (based on which n500 has been developed)
Green: The battery is charged between 80% to 100% of the capacity, and being discharged between 0% to 80% of the capacity.
Blinking green: The battery is charged between 20% to 80% of the capacity, and being charged.
Orange: The battery is charged between 5% and 20% of the capacity, and being discharged.
Blinking orange (slow): The battery is charged between 5% to 20% of the capacity,and being charged.
Blinking orange (rapid): The battery is charged between 0% to 5% of the capacity.
I beleive the N500 also follows the same battery status as followed by N200. but instead of being green , our laptops show
blue.
i had raised a request with the IBM Team yesterday and was replied that the 'MANUAL is INCORRECT' and the battery is fine.
Wenn ich auf den Einschaltknopf drücke, blinkt die LED 2x kurz und anschließend eine ganze weile schnell.
Es kann auch die Akku- oder Ladeelektronik sein...
Wie jetzt, mit
- (nur) Netzteil
- (nur) Akku
- Netzteil und Akku ?
Werde mir wohl ein Netzteil zulegen müssen, um genaueres herauszufinden.
Hier eine kurze Rückmeldung: mit dem neuen Netzteil funktioniert das Notebook wieder einwandfrei.
