Die Boot-Zeit ist relativa lang und 'ne Menge Fehlermeldungen erscheinen.
Ausserdem funktioniert der SD-Karten-Reader nicht mehr.
Kann das mit dem Bios-update (unter mit Boot-CD durchgeführt) zusammenhängen?
Oder damit dass ich im DeviceManager Intel Wifi 5100 disabled habe?
Es handelt sich um ein Thinkpad W500 mit Win7.
Dies sind die Fehlermeldungen im einzelnen:
Error 16/02/2011 9:44:21 RemoteAccess 20152 None "The currently configured authentication provider failed to load and initialize successfully. The requested name is valid, but no data of the requested type was found."
Error 16/02/2011 9:44:05 Service Control Manager 7000 None "The TPM Base Services service failed to start due to the following error:
The account specified for this service is different from the account specified for other services running in the same process."
Error 16/02/2011 9:43:57 Service Control Manager 7000 None "The Ricoh xD-Picture Card Driver service failed to start due to the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it."
Error 16/02/2011 9:43:57 Service Control Manager 7000 None "The rimsptsk service failed to start due to the following error:
Error 16/02/2011 9:43:57 Service Control Manager 7000 None "The rimmptsk service failed to start due to the following error:
Error 16/02/2011 9:43:53 Microsoft-Windows-PrintService 315 Sharing a printer The print spooler failed to share printer Brother DCP-385C Printer with shared resource name Brother DCP-385C Printer. Error 2114. The printer cannot be used by others on the network.
Warning 16/02/2011 9:43:45 Microsoft-Windows-Wininit 11 None Custom dynamic link libraries are being loaded for every application. The system administrator should review the list of libraries to ensure they are related to trusted applications.
Error 16/02/2011 9:43:39 Microsoft-Windows-EapHost 2002 Peer Skipping: Eap method DLL path name validation failed. Error: typeId=43, authorId=9, vendorId=0, vendorType=0
Error 16/02/2011 9:43:39 Microsoft-Windows-EapHost 2002 Peer Skipping: Eap method DLL path name validation failed. Error: typeId=25, authorId=9, vendorId=0, vendorType=0
Error 16/02/2011 9:43:39 Microsoft-Windows-EapHost 2002 Peer Skipping: Eap method DLL path name validation failed. Error: typeId=17, authorId=9, vendorId=0, vendorType=0
Error 16/02/2011 9:43:33 amdkmdag 43029 DAL Display is not active
Error 16/02/2011 9:43:33 amdkmdag 52236 CPLIB CPLIB :: General - Invalid Parameter
Error 15/02/2011 14:37:34 Service Control Manager 7001 None "The UPnP Device Host service depends on the SSDP Discovery service which failed to start because of the following error:
Error 15/02/2011 14:37:34 Service Control Manager 7000 None "The SSDP Discovery service failed to start due to the following error:
Error 15/02/2011 14:36:37 Service Control Manager 7000 None "The TPM Base Services service failed to start due to the following error:
