Verstehe jetzt auch erst Dein Problem (hatte nicht von Anfang gelesen%u2026)%u2026 Du kannst erst gar nicht von Floppy booten, weil kein Laufwerk vorhanden ist%u2026. %u2013 dann besorg Dir eins (%u20AC5 /%u20AC10) erspart eine Menge Arbeit und Aufwand für alle%u2026.
abgesehen davon sind die Instruktionen wie nachstehend....:
* You need an AC adapter and a charged battery pack to update the system program.
* If your system is attached to any kind of port replicator, turn off the system and detach it before proceeding.
* If a USB Diskette Drive is attached to your system, turn off the system and detach it before proceeding.
* Remove the Power-on password prior to updating the BIOS in RDM (Remote Deployment Manager) environment or similar environment.
1. Print these instructions or display on another system.
2. Firmly connect the AC adapter to the system.
3. Start a supported version of Windows on the target system. For Windows NT 4.0/2000/XP, logon with administrative privileges on the target system.
4. Make the temporary directory on the hard drive (for instance, C:\Temp)
5. Download the ThinkPad BIOS Update Utility from the web site and store the file into the temporary directory.
6. Click the Start button, then click Run.
7. In the Open dialog box, specify the utility filename with the full path name where you stored ThinkPad BIOS Update Utility (e.g. C:\Temp\1YUJ13US.EXE) and then press the Enter key.
Note: For unattended update, specify the file name with options "-s -a -s". (e.g. C:\Temp\1YUJ13US.EXE -s -a -s) The BIOS is updated without any user interaction.
8. Follow the instructions on the screen.
Depending on the operating system configuration, restarting the operating system and rerunning this BIOS update utility may be required. In this case, the following message will appear on the screen. "DeviceIoControl() returns 2 Please restart your operating system and execute the BIOS or Embedded Controller update utility again."
Windows will shut down automatically and ThinkPad BIOS Update Utility screen appears.
9. Select Read this first from the menu and carefully read the information that appears.
10. Press the Esc key to return to the menu.
11. Select Update system program and follow the instruction on the screen.
