Das habe ich mich auch mal gefragt, war aber letzendlich zu faul darüber nachzudenken
uhci_hcd verursacht ohne USB suspend eben regelmäßige wakeups, evtl. springt die CPU dann häufig zwischen C4/3 und C0 hin und her, was dann ein Fiepen bedingt. Das war jetzt einfach ins Blaue geraten![]()
cat /sys/bus/usb/devices/*/power/level
cat /sys/bus/usb/devices/*/power/autosuspend
http://www.blackberryforums.com/linux-users-corner/97661-enable-disable-config_usb_suspends-autosuspend-mode.html schrieb:autosuspend
-1 or 0 means off, depending on kernel, otherwise it is the number of seconds to autosuspend level with the settings:
on - suspend is disabled, device is fully powered
auto - suspend is controlled by the kernel (default)
suspend - suspend is enabled permanently
You can write these strings to the file to control behaviour on a per-device basis.
echo on > /sys/usb_device/.../device/power/level
state
current state of device
0 - fully powered
2 - suspended
You can write these numbers to control behaviour, but any change you make here might change automatically if autosuspend is on.
echo -n 0 > /sys/usb_device/.../device/power/state
