IBM/Lenovo Volume Key
cyberbob
4 Juli 2004
Moin!
Ich habe gerade ein X61s vor mir stehen (Forumangebot). :thumbsup:
Nun möchte ich es wie immer plätten und das System neu aufsetzen. Dafür werde ich mir eine Vista DVD basteln (slipstream).
Um nicht bei jeder Installation den Produkt-Key neu eingeben zu müssen, möchte ich den Volume Key von Lenovo in die DVD integrieren.
Wie lässt sich dieser auslesen? Reicht TuneUp 2007?
Danke und Gruß,
BOB
Serial/Key auslesen
Von mir persönlich favorisiert:
Magical Jelly Bean Keyfinder v2.0.1
funktioniert ohne Installation
Gruß iTdee
Schau mal hier, da hat Eric die Frage bereits beantwortet: [Vista] Vista SN / Setup
Oder auf Englisch im Wiki hier: http://www.wikibestpractices.com/index.php?title=Vista_activation bzw. hier: http://forum.notebookreview.com/showthread.php?t=119587
Disclaimer: I sincerely believe this guide to be on the legitimate side and I in no way support the use of this guide for purposes other than activating Vista on your Viste preinstalled Lenovo laptop!
I recently bought a T60 [...]
The first thing I did when I bought my T60 was to clean install Vista. I suppose everyone knows the benefits of this but what not many people know is that you can’t automatically activate Vista using the product key which is located in the sticker under your laptop. You must go through the telephone activation route which is sometimes really boring or even worse, unusable. I also didn’t want to use any of my spare MSDNAA licences because… I payed for this laptop’s Vista licence and I might as well make it work!
So I started digging on how I can activate my T60 the same way Lenovo activates them during the factory restore. I’ve found out that Lenovo (and other OEMs) use a different product key, not the one you see in the sticker, which is hidden in the restore partition (or the discs you made yourself). This product key in combination with a license file that Microsoft has given to each OEM can activate windows without the need of online or telephone activation. Ofcourse for the product key/license file to work your BIOS must be compatible (aka support SLIC - Software Licensing Description Table) so that you can’t
ilegally use this technique on every pc you own (doh!).
Here are the steps for a successful offline activation:
1. While you are using your factory preinstalled Vista find out your REAL OEM product key. You can use many utilities for this, like TweakVI but the easiest one is the Magical Jelly Bean Keyfinder. Print or write your product key.
2. Clean install Vista using either a retail DVD or with the Windows Anytime Upgrade DVD that might have been included in your Lenovo purchase. They are exactly the same media so no need to go the ware… *ahmm you know * way! When asked for your product key during installation enter the product you found in step 1 and NOT the product key which is written on the sticker under your laptop.
3. Find the Lenovo OEM licence file. It is found in your recovery media. For example if you wrote 2 DVDs with the R&R4 program the licence file is located in the data DVD (big one) into an imz archive (actually an encrypted zip archive) named 0ADPE07.IMZ Inside that archive you must find
SWWORK\C\WINDOWS\SYSTEM32\OEM\lenovo.oemcert.100036.xrm-ms
The problem with all the archives in the recovery DVD is that they are encrypted! I am currently brute forcing them but it will take days to find the correct password. So to save us some trouble we can find it on the net by searching Google for lenovo.oemcert.100036.xrm-ms. Download this file and place it somewhere (for easy install put it C:\)
4. Now we can oem/offline activate Vista by issuing the following well documented and supported by Microsoft commands. These
are:
slmgr –ilc path/to/licence/file/lenovo.oemcert.100036.xrm-ms
(a message should pop after a while telling you that it installed correctly)
slmgr –ato
(another message should pop which says that vista is now activated!)
Now go to Control Panel -> System and see that you are actually activated!
I hope this mini guide will help some of you do a clean Vista OEM installation without the need of the boring telephone activation.
G.
Und immer schön dran denken... Trotz zweier Key... nur eine Lizenz!
MfG Eric
cool... direkt mal in den saturn und neue seriennummern beschaffen... ;-)
nein quatsch, nicht ernst gemeint...*G*
@cyberbob,
bist du von deinem T60 nun auf das x61s umgestiegen? Du darfst gerne mal über deine Erfahrungen damit berichten. Ich bin auch schon am überlegen ob ich mir das x61 oder das x200 besorgen soll.
Wenn man im x61s die Systemwiederherstellung macht, sollte man doch unliebsame Software abwählen können, oder? Damit sollte man eigentlich gar keinen Grund mehr zu einem Clean Install haben wie früher. Oder täusche ich mich da? Somit würde man sich zumindest das ganze Theater mit der Aktivierung und dem Key ersparen.
Moin!
Mit TuneUp 2007 scheint es zu funktionieren!
Frage an alle die, die ihr TP mit Vista im Auslieferungszustand betreiben!
Lauten die ersten 5 Ziffern des Keys 2YRV9 ?
@iTdee & paddelpatrick: Danke euch!
@goonie: Danke auch Dir, komme mit der neuen Suche nicht wirklich zurecht, bzw. finde diese Mist!
@Noreia: Wir sehen uns bei Saturn!
Gruß,
BOB
Moin!
@solarist:
Nein, ich werde weiter mein T60(p) nutzen. Das Teil habe ich ja erst seit knappen 5 Monaten und brauche so ein kleines TP nicht, da ich meins zu 99% zu Hause nutze.
Das X61s ist für eine Freundin und ich bin derjenige, der sich darum kümmern darf. Sie bekommt das Gerät aber erst in der nächsten Woche, so dass ich ein wenig Zeit habe, mich mit dem Gerät auseinander zu setzen.
Schlussendlich wird sie das Gerät auch mit XP betreiben, da sie keine Lust hat, sich umzustellen... (Mädchen...)! :D
Was ich bisher sagen kann:
schönes Gerät
gut verarbeitet
helles Display
recht flott (aber dies lässt sich bestimmt noch steigern durch ein "Clean Install")
Wenn Du Fragen hast, immer raus damit!
Gruß,
BOB
