Hier nun die ganze Lithanei:
"I spent a couple of days installing various Windows 10 drivers for all the hardware included in my Elitebook 2560p, eventually got it all working properly. So in order to prevent others from wasting time searching for drivers, here is a list of all the stuff needed. Just search google for SPXXXX.exe (XXXX = number from below). Not all of the below are officially listed as 2560p drivers, but they are what I'm running and theyre working perfectly. Provided links for non-HP stuff as well.
HP 3D DriveGuard SP -
SP64144
HP Hotkey Support -
SP68201
HP Support Assistant 7 -
SP68201
HP Support Assistant 8 -
SP74103
HP Universal Camera Driver -
SP63913
IDT High-Definition (HD) Audio Driver -
SP59291
Intel 82579LM and 82579V Gigabit Ethernet Driver -
SP63881
Intel Chipset Installation Utility -
SP53918
Intel Management Engine Interface (MEI) Driver -
SP64098
Intel Rapid Storage Technology Driver -
SP63947
JMicron Media Card Reader Driver -
SP64135
Sierra un2430 Mobile Broadband -
SP63218 (install this 1st) &
SP63221 (install over 63218)
Software for sending receiving SMS/MMS and USSD codes from Windows 10 (works flawlessly with un2430 broadband module, if you have Ericsson hs2340 module USSD might not work):
http://support.black-it.eu/en/products/mobile broadband sms toolkit/index.htm
Validity Fingerpring Sensor info:
This one is a bit trickier, eventually managed to get it working properly on Win10.
0. If you had any other Validity drivers (or biometric sensor drivers at all) installed, uninstall them 1st and reboot
1. Install Dell's Validity495_Win8.1_Fingerprint_Setup_A00_ZPE.exe (
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=4JR6M)
2. Unpack (dont install!) Validity Fingerprint Sensor Driver
SP58900
3. Go to Device manager, select sensor and manually install (let me pick device to install -> have disk) driver from (default unpack location) C:\Swsetup\SP58900\Drivers\WBF_003c_DRVSP58900
4. Reboot again
After this Windows Hello and fingerprint login will work normally.
...", siehe
http://forum.notebookreview.com/thr...0p-owners-lounge.586353/page-32#post-10200916
