Hiho, hab das selbe schon im englischsprachigen Forum geschrieben und
hab hier gerade nicht die Zeit das wieder zu übersetzen (bin bei nem
Freund und habe daheim noch kein Inet).
Hi!
I try to keep it short.
I tried to install my Atheros card on my T60 (2007VEH ; Atheros
chipset supports a,b,g,n (<- is that maybe the problem? the
current drivers don't work with 'n'?))
I followed the instructions here:
http://ubuntuforums.org/showthread.php?t=38972
..After this diddn't work out I tried to do what the README and
INSTALL file of the Madwifi pakage sais, which diddn't work out
either.
dmesg after modprobing "ath_pci"
[17179677.280000] ath_hal: module license 'Proprietary' taints kernel.
[17179677.284000] ath_hal: 0.9.17.2 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413)
BUT iwconfig still says..
lo no wireless extensions.
irda0 no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
which is supposed to say..
wifi0 no wireless extensions.
ath0 IEEE 802.11b ESSID:""
Mode:Managed Channel:0 Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power:50 dBm Sensitivity=0/3
Retryff RTS thrff Fragment thrff
Power Managementff
Link Quality=0/94 Signal level=-95 dBm Noise level=-95 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
CAN ANYONE HELP ME?
PS: Is it strange that the "wireless lid" on the bottom of the screen
doesnt shine? (it does in windows)
Thanks!
Hi!
either.
Power Managementff
CAN ANYONE HELP ME?
Thanks!
