X1 Genuine OEM Lenovo Thinkpad Battery
scorcher
25 Okt. 2018
Hi everyone!
Just bought a battery from a reputaded german ebay seller and now i´m trying to confirm that is a genuine battery.. how can we confirm this?
Pics from the box:
There is any way to make sure is an official Lenovo battery?
Many thanks.
Hello, to make sure, that it is a official battery, we do not need the picture of the case but of the battery label(s) (the FRU no. must be the same as on the case).
Hallo, um sicher zu gehen, dass es ein Originalakku ist, brauchen wir nicht das Bilf von der Schachtel, sondern vom Akku-Aufkleber (die FRU-Nr. muss die gleiche, wie auf der Schachtel sein).
Print from Lenovo Vantage saying SMP as manufacturer??
Ok, but look like a Lenovo case?.. there is no Lenovo reference anywhere..
Case and seal look genuine, yes. Lenovo Vantage will always give you the cell manufacturer, like SMP, Panasonic, Sanyo, and some others.
Any particular reason why you're so suspicious it could be a fake? I personally have never encountered a "fake" Lenovo battery, that's more in the mobile phone sector where it's basically impossible to find a genuine replacement for a non-user-replacable battery on eBay. Of course there are 3rd party batteries for ThinkPads, but you'll spot those easily and they'll usually not carry a Lenovo badge.
https://i.ibb.co/Yj2tFDn/56wh.jpg
So it´s a genuine OEM Lenovo battery?I'm like this because i found too many sellers trying to fool me and don´t want to be robbed by this one that cost me two times the other ones..Will make some disharge tests next days to evaluate the battery.
It seems to have the same FRU # 01AV458, "Lenovo" logo is on the battery as well as on the case label - it seems to be an original Lenovo part. It might been happened, that the seal was broken to test or charge the battery, or it was a returned battery.
