[gelöst] T61, Sound will unter Debian Squeeze nicht, Kernel 2.6.30-2-amd64 (Debian 2.6.30-8)
wie richte bei Debian Squeeze den Sound ein?
Mit der Debian Squeeze Standardinstallation funktioniert der Sound nur sehr eingeschränkt.
Beste Grüße
xsid
Edit:
http://forums.debian.net/viewtopic.php?t=36282
Diese angebliche Lösung für bei mir heute nicht zum Erfolg.
Es wird von mir ein tagesaktuelles Squeeze von mir verwendet.
lspci
]00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
Beste Grüße
xsid
Edit:
After looking through the ALSA configuration and with some googling I think I've discovered the problem. Apparently the default options for ALSA configure the AD1984A Codec (which my card uses) as a 6-jack device, when it's actually a 3-jack.
Appending this line to my /etc/modprobe.d/alsa-base seems to have cleared things up. Thanks!:
Code: Select alloptions snd-hda-intel model=3stack position_fix=1
For the interested parties, this is straight out of the ALSA configuration documentation:
Code: Select allModule snd-hda-intel
Module for Intel HD Audio (ICH6, ICH6M, ESB2, ICH7, ICH8),
ATI SB450, SB600, RS600,
VIA VT8251/VT8237A,
SIS966, ULI M5461
[Multiple options for each card instance]
model - force the model name
position_fix - Fix DMA pointer (0 = auto, 1 = use LPIB, 2 = POSBUF)
probe_mask - Bitmask to probe codecs (default = -1, meaning all slots)
bdl_pos_adj - Specifies the DMA IRQ timing delay in samples.
Passing -1 will make the driver to choose the appropriate
value based on the controller chip.
[Single (global) options]
single_cmd - Use single immediate commands to communicate with
codecs (for debugging only)
enable_msi - Enable Message Signaled Interrupt (MSI) (default = off)
power_save - Automatic power-saving timtout (in second, 0 =
disable)
power_save_controller - Reset HD-audio controller in power-saving mode
(default = on)
This module supports multiple cards and autoprobe.
Each codec may have a model table for different configurations.
If your machine isn't listed there, the default (usually minimal)
configuration is set up. You can pass "model=<name>" option to
specify a certain model in such a case. There are different
models depending on the codec chip.
AD1984
basic default configuration
thinkpad Lenovo Thinkpad T61/X61
dell Dell T3400
AD1986A
6stack 6-jack, separate surrounds (default)
3stack 3-stack, shared surrounds
laptop 2-channel only (FSC V2060, Samsung M50)
laptop-eapd 2-channel with EAPD (Samsung R65, ASUS A6J)
laptop-automute 2-channel with EAPD and HP-automute (Lenovo N100)
ultra 2-channel with EAPD (Samsung Ultra tablet PC)
