http://support.microsoft.com/kb/959252
Löst das Problem
Edit:
@atomic-virus:
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: bf93777d, The address that the exception occurred at
Arg3: 959b58fc, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgef hrt werden.
FAULTING_IP:
win32k!vSpUpdateWndobjOverlap+1
bf93777d 83670800 and dword ptr [edi+8],0
TRAP_FRAME: 959b58fc -- (.trap 0xffffffff959b58fc)
ErrCode = 00000002
eax=e1e9a048 ebx=e242d9c8 ecx=e2ade0f8 edx=e10e6048 esi=00000000 edi=00000000
eip=bf93777d esp=959b5970 ebp=959b5978 iopl=0 nv up ei ng nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010282
win32k!vSpUpdateWndobjOverlap+0x1:
bf93777d 83670800 and dword ptr [edi+8],0 ds:0023:00000008=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 5
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: igfxsrvc.exe
MISALIGNED_IP:
LAST_CONTROL_TRANSFER: from 00000000 to bf93777d
STACK_TEXT:
959b596c 00000000 e1e9a008 959b5b94 bf938cc3 win32k!vSpUpdateWndobjOverlap+0x1
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: win32k!vSpUpdateWndobjOverlap+1
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: hardware
FAILURE_BUCKET_ID: IP_MISALIGNED
Followup: MachineOwner
Das sind die Ausgaben des Debuggers
