[ 37.989] (II) NOUVEAU(0): EDID for output LVDS-1
[ 37.989] (II) NOUVEAU(0): Manufacturer: LCD Model: 5500 Serial#: 16843009
[ 37.989] (II) NOUVEAU(0): Year: 2008 Week: 24
[ 37.989] (II) NOUVEAU(0): EDID Version: 1.3
[ 37.989] (II) NOUVEAU(0): Digital Display Input
[ 37.989] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 29 vert.: 21
[ 37.989] (II) NOUVEAU(0): Gamma: 2.20
[ 37.989] (II) NOUVEAU(0): No DPMS capabilities specified
[ 37.989] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 37.989] (II) NOUVEAU(0): First detailed timing is preferred mode
[ 37.989] (II) NOUVEAU(0): redX: 0.600 redY: 0.345 greenX: 0.298 greenY: 0.551
[ 37.989] (II) NOUVEAU(0): blueX: 0.148 blueY: 0.142 whiteX: 0.313 whiteY: 0.329
[ 37.989] (II) NOUVEAU(0): Supported established timings:
[ 37.989] (II) NOUVEAU(0): 1024x768@60Hz
[ 37.989] (II) NOUVEAU(0): Manufacturer's mask: 0
[ 37.989] (II) NOUVEAU(0): Supported standard timings:
[ 37.989] (II) NOUVEAU(0): #0: hsize: 1400 vsize 1050 refresh: 60 vid: 16528
[ 37.989] (II) NOUVEAU(0): Supported detailed timing:
[ 37.989] (II) NOUVEAU(0): clock: 108.0 MHz Image Size: 287 x 215 mm
[ 37.989] (II) NOUVEAU(0): h_active: 1400 h_sync: 1448 h_sync_end 1560 h_blank_end 1688 h_border: 0
[ 37.989] (II) NOUVEAU(0): v_active: 1050 v_sync: 1051 v_sync_end 1054 v_blanking: 1066 v_border: 0
[ 37.989] (II) NOUVEAU(0): Ranges: V min: 59 V max: 61 Hz, H min: 45 H max: 51 kHz, PixClock max 108 MHz
[ 37.989] (II) NOUVEAU(0): Monitor name: LTD141ENCF
[ 37.989] (II) NOUVEAU(0): Serial No: TQR8F000739
[ 37.989] (II) NOUVEAU(0): EDID (in hex):
[ 37.989] (II) NOUVEAU(0): 00ffffffffffff003064005501010101
[ 37.989] (II) NOUVEAU(0): 18120103801d15780a941599584c8d26
[ 37.989] (II) NOUVEAU(0): 24505400080090400101010101010101
[ 37.989] (II) NOUVEAU(0): 010101010101302a7820511a10403070
[ 37.989] (II) NOUVEAU(0): 13001fd71000001e000000fd003b3d2d
[ 37.989] (II) NOUVEAU(0): 3306000a202020202020000000fc004c
[ 37.989] (II) NOUVEAU(0): 5444313431454e43460a2020000000ff
[ 37.989] (II) NOUVEAU(0): 0054515238463030303733390a20009a
[ 37.989] (II) NOUVEAU(0): EDID vendor "LCD", prod id 21760
[ 37.989] (II) NOUVEAU(0): Using EDID range info for horizontal sync
[ 37.989] (II) NOUVEAU(0): Using EDID range info for vertical refresh
[ 37.989] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 37.989] (II) NOUVEAU(0): Modeline "1400x1050"x0.0 108.00 1400 1448 1560 1688 1050 1051 1054 1066 +hsync +vsync (64.0 kHz eP)
[ 37.989] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 37.989] (II) NOUVEAU(0): Modeline "1400x1050"x0.0 101.00 1400 1448 1480 1560 1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[ 37.989] (II) NOUVEAU(0): Not using mode "1400x1050" (bad mode clock/interlace/doublescan)
[ 37.989] (II) NOUVEAU(0): Printing probed modes for output LVDS-1
[ 37.989] (II) NOUVEAU(0): Modeline "1400x1050"x60.0 108.00 1400 1448 1560 1688 1050 1051 1054 1066 +hsync +vsync (64.0 kHz eP)
[ 37.989] (II) NOUVEAU(0): Modeline "1280x1024"x59.9 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync (63.7 kHz e)
[ 37.989] (II) NOUVEAU(0): Modeline "1280x960"x59.9 101.25 1280 1360 1488 1696 960 963 967 996 -hsync +vsync (59.7 kHz e)
[ 37.989] (II) NOUVEAU(0): Modeline "1152x864"x60.0 81.75 1152 1216 1336 1520 864 867 871 897 -hsync +vsync (53.8 kHz e)
[ 37.989] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 37.989] (II) NOUVEAU(0): Modeline "1024x768"x59.9 63.50 1024 1072 1176 1328 768 771 775 798 -hsync +vsync (47.8 kHz e)
[ 37.990] (II) NOUVEAU(0): Modeline "800x600"x59.9 38.25 800 832 912 1024 600 603 607 624 -hsync +vsync (37.4 kHz e)
[ 37.990] (II) NOUVEAU(0): Modeline "640x480"x59.4 23.75 640 664 720 800 480 483 487 500 -hsync +vsync (29.7 kHz e)
[ 37.990] (II) NOUVEAU(0): Modeline "720x400"x59.6 22.25 720 744 808 896 400 403 413 417 -hsync +vsync (24.8 kHz e)
[ 37.990] (II) NOUVEAU(0): Modeline "640x400"x60.0 20.00 640 664 720 800 400 403 409 417 -hsync +vsync (25.0 kHz e)
[ 37.990] (II) NOUVEAU(0): Modeline "640x350"x59.8 17.50 640 664 720 800 350 353 363 366 -hsync +vsync (21.9 kHz e)
[ 38.010] (II) NOUVEAU(0): EDID for output VGA-1
[ 38.012] (II) NOUVEAU(0): EDID for output DVI-D-1
[ 38.012] (II) NOUVEAU(0): Output LVDS-1 connected
[ 38.012] (II) NOUVEAU(0): Output VGA-1 disconnected
[ 38.012] (II) NOUVEAU(0): Output DVI-D-1 disconnected
[ 38.012] (II) NOUVEAU(0): Using exact sizes for initial modes
[ 38.012] (II) NOUVEAU(0): Output LVDS-1 using initial mode 1400x1050
[ 38.012] (II) NOUVEAU(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 38.013] (--) NOUVEAU(0): Virtual size is 1400x1050 (pitch 0)
