[Erledigt] Wordpress Blog nicht mehr ansprechbar - wie Daten retten?
NewNoise
8 Juli 2009
der Blog meiner Schwester ist irgendwie im Eimer.
Wenn ich mich als Admin einloggen will, kommen Zeilen von Fehlercodes:
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-settings.php on line 472
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-settings.php on line 487
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-settings.php on line 494
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-settings.php on line 530
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-includes/cache.php on line 103
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-includes/query.php on line 21
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-includes/theme.php on line 623
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 43
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 53
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 61
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 69
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 78
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 80
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 84
Deprecated: Assigning the return value of new by reference is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/swift_engine.php on line 197
Warning: Cannot modify header information - headers already sent by (output started at /data/multiserv/users/169468/projects/198547/www/wp-settings.php:472) in /data/multiserv/users/169468/projects/198547/www/wp-login.php on line 267
Warning: Cannot modify header information - headers already sent by (output started at /data/multiserv/users/169468/projects/198547/www/wp-settings.php:472) in /data/multiserv/users/169468/projects/198547/www/wp-login.php on line 279
Deprecated: Function split() is deprecated in /data/multiserv/users/169468/projects/198547/www/wp-content/plugins/cimy-swift-smtp/Swift/php5/lib/Swift.php on line 277
Warning: Cannot modify header information - headers already sent by (output started at /data/multiserv/users/169468/projects/198547/www/wp-settings.php:472) in /data/multiserv/users/169468/projects/198547/www/wp-includes/pluggable.php on line 770
Hab ich irgendwie noch Hoffnung an die Daten zu kommen? Wuerde doch sehr gern die Beitraege da noch rausziehen.
Danke fuer jede Idee.
noise
Mach erstmal einen Backup von der MySQL Datenbank. Dann setze ein neues Wordpress auf zum Test und importiere die MySQL-Datenbank wieder rein.
Das ganze machst du natürlich über deine Tools beim Hoster, nicht im defekten Wordpress.
Puh,
nach einigem gefriemel hab ich das nun hinbekommen die als SQL Set zu exportieren.
Kann ich das auf nem anderen Server jetzt wieder zusammenpacken?
Also Datenbank zurueck spielen und Dateien drauf kopieren?
Danke
Genau so kannste das machen, ja, hab ich letztens auch so gemacht, als ich mit meinem WP-Blog auf einen anderen Server umgezogen bin.
Das heißt, die Datenbank sichern (haste ja gemacht), dann Wordpress nochmal installieren bzw. die Wordpress-Dateien neu draufbügeln und bei Bedarf die Datenbankinformationen in der Konfiguration neu anpassen, dann das Datenbank-Backup zurückspielen und fertig is. Geht in der Regel ganz unkompliziert.
Ich hoffe natürlich, dass der Fehler in deinem Blog dann wieder behoben ist und alles wieder aussehen wie es sollte. Weiß aber nicht, obs nur an der Datenbank liegt. Aber wenn du, wie du schreibst, sowohl die Datenbank als auch die WP-Installation aufsetzt ist die Wahrscheinlichkeit ja recht hoch, dass hinterher wieder alles in Butter is ;)
hi,
so, dass habe ich nun soweit, db wiederhergestellt, und per ftp alle wordpress dateien draufgeklatscht.
nun ist das doofe, dass er wenn man die neue url aufruft er automatisch auf die alte blockadresse weiterleitet.
weiss da jemand nen rat?
danke!
Ändere mal in der wp-config die angegebene URL des Blogs.
BTW vermute ich, dass das plötzliche Kaputtgehen des anderen Blogs von einem PHP-Update seitens kilu ausgelöst wurde...
ich suche die einstellung schon die ganze zeit, aber die ist nicht in der wp-config.
ja mag sein, dann hoffe ich mal das auf dem neuen noch die alte php version laeuft.
sonst muss ich mal sehen ob ich das in die neue wp version bekomme.
man man man. sowas versaut einem doch den donnerstag abend ;)
edit: in der db hab ich die url geaendert und nun gehts!
