Dec 14 20:17:38 x61t NetworkManager[743]: <info> WWAN now enabled by radio killswitchDec 14 20:17:41 x61t kernel: [ 4770.980065] usb 6-1: new full-speed USB device number 6 using uhci_hcd
Dec 14 20:17:41 x61t kernel: [ 4771.140142] usb 6-1: New USB device found, idVendor=1199, idProduct=6813
Dec 14 20:17:41 x61t kernel: [ 4771.140150] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 14 20:17:41 x61t kernel: [ 4771.140155] usb 6-1: Product: Mini Card
Dec 14 20:17:41 x61t kernel: [ 4771.140160] usb 6-1: Manufacturer: Sierra Wireless, Incorporated
Dec 14 20:17:41 x61t kernel: [ 4771.146208] sierra 6-1:1.0: Sierra USB modem converter detected
Dec 14 20:17:41 x61t kernel: [ 4771.147331] usb 6-1: Sierra USB modem converter now attached to ttyUSB0
Dec 14 20:17:41 x61t kernel: [ 4771.147515] usb 6-1: Sierra USB modem converter now attached to ttyUSB1
Dec 14 20:17:41 x61t kernel: [ 4771.147705] usb 6-1: Sierra USB modem converter now attached to ttyUSB2
Dec 14 20:17:41 x61t mtp-probe: checking bus 6, device 6: "/sys/devices/pci0000:00/0000:00:1d.1/usb6/6-1"
Dec 14 20:17:41 x61t mtp-probe: bus: 6, device: 6 was not an MTP device
Dec 14 20:17:42 x61t modem-manager[3286]: <info> (ttyUSB0) opening serial port...
Dec 14 20:17:42 x61t modem-manager[3286]: <warn> (ttyUSB0): port attributes not fully set
Dec 14 20:17:42 x61t modem-manager[3286]: <info> (ttyUSB2) opening serial port...
Dec 14 20:17:42 x61t modem-manager[3286]: <warn> (ttyUSB2): port attributes not fully set
Dec 14 20:17:42 x61t modem-manager[3286]: <info> (ttyUSB1) opening serial port...
Dec 14 20:17:42 x61t modem-manager[3286]: <warn> (ttyUSB1): port attributes not fully set
Dec 14 20:17:44 x61t modem-manager[3286]: <info> (ttyUSB0) opening serial port...
Dec 14 20:17:44 x61t modem-manager[3286]: <warn> (ttyUSB0): port attributes not fully set
Dec 14 20:17:46 x61t modem-manager[3286]: <info> (ttyUSB2) closing serial port...
Dec 14 20:17:46 x61t modem-manager[3286]: <info> (ttyUSB2) serial port closed
Dec 14 20:17:46 x61t modem-manager[3286]: <info> (Sierra): GSM modem /sys/devices/pci0000:00/0000:00:1d.1/usb6/6-1 claimed port ttyUSB2
Dec 14 20:17:54 x61t modem-manager[3286]: <info> (ttyUSB1) closing serial port...
Dec 14 20:17:54 x61t modem-manager[3286]: <info> (ttyUSB1) serial port closed
Dec 14 20:17:54 x61t modem-manager[3286]: <info> (ttyUSB1) opening serial port...
Dec 14 20:17:57 x61t modem-manager[3286]: <info> (ttyUSB0) closing serial port...
Dec 14 20:17:57 x61t modem-manager[3286]: <info> (ttyUSB0) serial port closed
Dec 14 20:17:57 x61t modem-manager[3286]: <info> (ttyUSB0) opening serial port...
Dec 14 20:18:00 x61t modem-manager[3286]: <info> (ttyUSB1) closing serial port...
Dec 14 20:18:00 x61t modem-manager[3286]: <info> (ttyUSB1) serial port closed
Dec 14 20:18:03 x61t modem-manager[3286]: <info> (ttyUSB0) closing serial port...
Dec 14 20:18:03 x61t modem-manager[3286]: <info> (ttyUSB0) serial port closed
Dec 14 20:18:03 x61t NetworkManager[743]: <info> ModemManager disappeared
Dec 14 20:18:03 x61t dbus[409]: [system] Activating service name='org.freedesktop.ModemManager' (using servicehelper)
Dec 14 20:18:03 x61t modem-manager[5509]: <info> ModemManager (version 0.6.0.0) starting...
Dec 14 20:18:03 x61t dbus[409]: [system] Successfully activated service 'org.freedesktop.ModemManager'
Dec 14 20:18:03 x61t NetworkManager[743]: <info> modem-manager is now available
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Ericsson MBM'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'SimTech'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Wavecom'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Longcheer'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Novatel'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'X22X'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Option'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'ZTE'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Sierra'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Huawei'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'AnyData'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Samsung'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Option High-Speed'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Linktop'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'MotoC'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Gobi'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Nokia'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Iridium'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Cinterion'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Loaded plugin 'Generic'
Dec 14 20:18:03 x61t modem-manager[5509]: <info> Successfully loaded 20 plugins
Dec 14 20:18:03 x61t modem-manager[5509]: <info> (ttyUSB0) opening serial port...
Dec 14 20:18:03 x61t modem-manager[5509]: <warn> (ttyUSB0): port attributes not fully set
Dec 14 20:18:03 x61t modem-manager[5509]: <info> (ttyUSB1) opening serial port...
Dec 14 20:18:03 x61t modem-manager[5509]: <warn> (ttyUSB1): port attributes not fully set
Dec 14 20:18:03 x61t modem-manager[5509]: <info> (ttyUSB2) opening serial port...
Dec 14 20:18:03 x61t modem-manager[5509]: <warn> (ttyUSB2): port attributes not fully set
Dec 14 20:18:06 x61t modem-manager[5509]: <info> (ttyUSB0) opening serial port...
Dec 14 20:18:06 x61t modem-manager[5509]: <warn> (ttyUSB0): port attributes not fully set
Dec 14 20:18:07 x61t modem-manager[5509]: <info> (ttyUSB2) closing serial port...
Dec 14 20:18:07 x61t modem-manager[5509]: <info> (ttyUSB2) serial port closed
Dec 14 20:18:07 x61t modem-manager[5509]: <info> (Sierra): GSM modem /sys/devices/pci0000:00/0000:00:1d.1/usb6/6-1 claimed port ttyUSB2
Dec 14 20:18:12 x61t whoopsie[1030]: online
Dec 14 20:18:13 x61t whoopsie[1030]: online
Dec 14 20:18:15 x61t modem-manager[5509]: <info> (ttyUSB1) closing serial port...
Dec 14 20:18:15 x61t modem-manager[5509]: <info> (ttyUSB1) serial port closed
Dec 14 20:18:15 x61t modem-manager[5509]: <info> (ttyUSB1) opening serial port...
Dec 14 20:18:18 x61t modem-manager[5509]: <info> (ttyUSB0) closing serial port...
Dec 14 20:18:18 x61t modem-manager[5509]: <info> (ttyUSB0) serial port closed
Dec 14 20:18:18 x61t modem-manager[5509]: <info> (ttyUSB0) opening serial port...
Dec 14 20:18:20 x61t whoopsie[1030]: online
Dec 14 20:18:21 x61t modem-manager[5509]: <info> (ttyUSB1) closing serial port...
Dec 14 20:18:21 x61t modem-manager[5509]: <info> (ttyUSB1) serial port closed
Dec 14 20:18:24 x61t modem-manager[5509]: <info> (ttyUSB0) closing serial port...
Dec 14 20:18:24 x61t modem-manager[5509]: <info> (ttyUSB0) serial port closed
Dec 14 20:18:24 x61t NetworkManager[743]: <info> ModemManager disappeared
Dec 14 20:18:24 x61t dbus[409]: [system] Activating service name='org.freedesktop.ModemManager' (using servicehelper)
Dec 14 20:18:24 x61t modem-manager[5519]: <info> ModemManager (version 0.6.0.0) starting...
Dec 14 20:18:24 x61t dbus[409]: [system] Successfully activated service 'org.freedesktop.ModemManager'
Dec 14 20:18:24 x61t NetworkManager[743]: <info> modem-manager is now available
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Ericsson MBM'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'SimTech'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Wavecom'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Longcheer'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Novatel'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'X22X'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Option'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'ZTE'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Sierra'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Huawei'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'AnyData'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Samsung'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Option High-Speed'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Linktop'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'MotoC'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Gobi'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Nokia'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Iridium'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Cinterion'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Loaded plugin 'Generic'
Dec 14 20:18:24 x61t modem-manager[5519]: <info> Successfully loaded 20 plugins
Dec 14 20:18:24 x61t modem-manager[5519]: <info> (ttyUSB0) opening serial port...
Dec 14 20:18:24 x61t modem-manager[5519]: <warn> (ttyUSB0): port attributes not fully set
Dec 14 20:18:24 x61t modem-manager[5519]: <info> (ttyUSB1) opening serial port...
Dec 14 20:18:24 x61t modem-manager[5519]: <warn> (ttyUSB1): port attributes not fully set
Dec 14 20:18:24 x61t modem-manager[5519]: <info> (ttyUSB2) opening serial port...
Dec 14 20:18:24 x61t modem-manager[5519]: <warn> (ttyUSB2): port attributes not fully set
Dec 14 20:18:27 x61t modem-manager[5519]: <info> (ttyUSB0) opening serial port...
Dec 14 20:18:27 x61t modem-manager[5519]: <warn> (ttyUSB0): port attributes not fully set
Dec 14 20:18:28 x61t modem-manager[5519]: <info> (ttyUSB2) closing serial port...
Dec 14 20:18:28 x61t modem-manager[5519]: <info> (ttyUSB2) serial port closed
Dec 14 20:18:28 x61t modem-manager[5519]: <info> (Sierra): GSM modem /sys/devices/pci0000:00/0000:00:1d.1/usb6/6-1 claimed port ttyUSB2
Dec 14 20:18:36 x61t NetworkManager[743]: <info> WWAN now disabled by radio killswitch
Dec 14 20:18:36 x61t modem-manager[5519]: <info> (ttyUSB1) closing serial port...
Dec 14 20:18:36 x61t modem-manager[5519]: <info> (ttyUSB1) serial port closed
Dec 14 20:18:36 x61t modem-manager[5519]: <info> (ttyUSB1) opening serial port...
Dec 14 20:18:36 x61t kernel: [ 4826.228194] usb 6-1: USB disconnect, device number 6
Dec 14 20:18:36 x61t kernel: [ 4826.229155] sierra ttyUSB0: resubmit read urb failed.(-19)
Dec 14 20:18:36 x61t kernel: [ 4826.229186] sierra ttyUSB1: resubmit read urb failed.(-19)
Dec 14 20:18:36 x61t kernel: [ 4826.230263] sierra ttyUSB1: resubmit read urb failed.(-19)
Dec 14 20:18:36 x61t modem-manager[5519]: <info> (ttyUSB0) closing serial port...
Dec 14 20:18:36 x61t modem-manager[5519]: <info> (ttyUSB0) serial port closed
Dec 14 20:18:36 x61t modem-manager[5519]: <warn> Couldn't probe for capabilities, probably not a GSM or CDMA modem
Dec 14 20:18:36 x61t kernel: [ 4826.232628] sierra ttyUSB0: Sierra USB modem converter now disconnected from ttyUSB0
Dec 14 20:18:36 x61t kernel: [ 4826.232935] sierra ttyUSB1: Sierra USB modem converter now disconnected from ttyUSB1
Dec 14 20:18:36 x61t kernel: [ 4826.233108] sierra ttyUSB2: Sierra USB modem converter now disconnected from ttyUSB2
Dec 14 20:18:36 x61t kernel: [ 4826.233131] sierra 6-1:1.0: device disconnected
Dec 14 20:18:36 x61t NetworkManager[743]: <info> ModemManager disappeared
