RE: CUPS-Server-Problem (cupsd)
Original von fishmac
Original von Lordshooter01
Ich bitte höflichst um dringende Hilfe:
Besten Dank, für die bisherigen Beiträge: Antworten unter "Edit", im ersten Post.
1. Die Responsezeiten duerften bei ubuntuusers.de kuerzer sein. Noch schneller bist Du mit IRC (unter Ubuntu z.B. Pidgin) im Channel #ubuntu-de
2. ganz schlechte Idee. Wenn Du Deine Antworten in Deine erste Message reinquetscht, wer soll dann noch den roten Faden behalten koennen ?
Hallo fishmac,
ja, Du hast Recht.
Hier der Rest des Error-logs:
D [09/Dec/2007:13:00:43 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:00:43 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:00:44 +0100] cupsdAcceptClient: 6 from localhost:631 (IPv4)
D [09/Dec/2007:13:00:44 +0100] cupsdReadClient: 6 GET / HTTP/1.1
D [09/Dec/2007:13:00:44 +0100] cupsdReadClient: 6 Browser asked for language "en-us.UTF-8"...
D [09/Dec/2007:13:00:44 +0100] cupsdAuthorize: No authentication data provided.
D [09/Dec/2007:13:00:45 +0100] write_file: 6 file=8
D [09/Dec/2007:13:00:45 +0100] cupsdReadClient: 6 GET /cups.css HTTP/1.1
D [09/Dec/2007:13:00:45 +0100] cupsdReadClient: 6 Browser asked for language "en-us.UTF-8"...
D [09/Dec/2007:13:00:45 +0100] cupsdAuthorize: No authentication data provided.
D [09/Dec/2007:13:00:46 +0100] write_file: 6 file=8
D [09/Dec/2007:13:00:46 +0100] cupsdReadClient: 6 GET /favicon.ico HTTP/1.1
D [09/Dec/2007:13:00:46 +0100] cupsdReadClient: 6 Browser asked for language "en-us.UTF-8"...
D [09/Dec/2007:13:00:46 +0100] cupsdAuthorize: No authentication data provided.
D [09/Dec/2007:13:00:47 +0100] write_file: 6 file=8
D [09/Dec/2007:13:00:47 +0100] cupsdAcceptClient: 9 from localhost:631 (IPv4)
D [09/Dec/2007:13:00:47 +0100] cupsdReadClient: 9 GET /images/top-left.gif HTTP/1.1
D [09/Dec/2007:13:00:47 +0100] cupsdReadClient: 9 Browser asked for language "en-us.UTF-8"...
D [09/Dec/2007:13:00:47 +0100] cupsdAuthorize: No authentication data provided.
D [09/Dec/2007:13:02:06 +0100] [CGI] 'hplip.conf\n'
D [09/Dec/2007:13:02:06 +0100] [cups-deviced] Added device "lpd"...
D [09/Dec/2007:13:02:07 +0100] [CGI] unable to open /var/run/hplip/hpssd.port: No such file or directory: api/hplip_api.c 103
D [09/Dec/2007:13:02:07 +0100] [CGI] unable to connect hpssd socket 2207: Connection refused: api/hplip_api.c 738
D [09/Dec/2007:13:02:07 +0100] [cups-deviced] Added device "hp:/no_device_found"...
D [09/Dec/2007:13:02:08 +0100] [CGI] /usr/lib/cups/backend/z600: error while loading shared libraries: liblexprinter.so.0: cannot open shared object file: No such file or directory
D [09/Dec/2007:13:02:08 +0100] [CGI] /usr/lib/cups/backend/z700: error while loading shared libraries: liblexprinter.so.0: cannot open shared object file: No such file or directory
D [09/Dec/2007:13:02:08 +0100] [cups-deviced] Added device "ipp"...
D [09/Dec/2007:13:02:08 +0100] [CGI] perl: warning: Setting locale failed.
D [09/Dec/2007:13:02:08 +0100] [CGI] perl: warning: Please check that your locale settings:
D [09/Dec/2007:13:02:10 +0100] cupsdAuthorize: No authentication data provided.
D [09/Dec/2007:13:02:10 +0100] write_file: 6 file=8
Etc., etc....
D [09/Dec/2007:13:11:06 +0100] [CGI] cgiCopyTemplateLang(tmpl="trailer.tmpl")
D [09/Dec/2007:13:11:06 +0100] [CGI] locale="en"...
D [09/Dec/2007:13:11:06 +0100] [CGI] Template file is "/usr/share/cups/templates/trailer.tmpl"...
D [09/Dec/2007:13:11:06 +0100] [CGI] Starting at file position 0...
D [09/Dec/2007:13:11:06 +0100] [CGI] Returning at file position 614 on EOF...
D [09/Dec/2007:13:11:47 +0100] cupsdCloseClient: 8
D [09/Dec/2007:13:12:05 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:12:05 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:12:06 +0100] cupsdAcceptClient: 8 from localhost:631 (IPv4)
D [09/Dec/2007:13:12:06 +0100] cupsdReadClient: 8 POST / HTTP/1.1
D [09/Dec/2007:13:12:06 +0100] cupsdAuthorize: No authentication data provided.
D [09/Dec/2007:13:12:06 +0100] CUPS-Get-Printers
D [09/Dec/2007:13:12:06 +0100] cupsdProcessIPPRequest: 8 status_code=0 (successful-ok)
D [09/Dec/2007:13:12:06 +0100] CUPS-Get-Classes
D [09/Dec/2007:13:12:06 +0100] CUPS-Get-Default
D [09/Dec/2007:13:12:06 +0100] cupsdCloseClient: 8
D [09/Dec/2007:13:12:17 +0100] cupsdCloseClient: 6
D [09/Dec/2007:13:13:07 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:13:07 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:14:09 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:14:09 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:15:11 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:15:11 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:16:13 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:16:13 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:17:15 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:17:15 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:18:17 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:18:17 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
D [09/Dec/2007:13:19:19 +0100] cupsdNetIFUpdate: "lo" = localhost...
D [09/Dec/2007:13:19:19 +0100] cupsdNetIFUpdate: "eth0" = 192.168.1.2...
Ich glaube, dass das "Wireless", das ich nicht weiss, wie abstellen, weil ich ja eine ADSL-Verbindung habe, "sich beisst", mit dem CUPS, das glaube ich ein "Broadband-Stream", oder ähnlich, sendet.
Vielen Dank, für Deine weiteren Bemühungen.
Edit:
Hurra, hurra!!:
?Add Printer Wizard? lässt den Eintrag eines neuen Druckers zu (!).
/etc/cups/ppd/alexanders_printer.ppd
zeigt immer noch:
*PPD-Adobe: "4.3"
*% Adobe PostScript(R) Printer Description File
*% For Lexmark E350d LaserPrinter
*% Produced by Lexmark International, Inc.
*% Copyright (c) 2006 Lexmark International Inc. All Rights Reserved.
*% Permission is granted for redistribution of this file as
*% long as this copyright notice is intact and the content
*% of the file is not altered in any way from its original form.
*% General Information
*FormatVersion: "4.3"
*FileVersion: "10.4.0.0"
*LanguageVersion: English
*LanguageEncoding: UTF-8
*PCFileName: "LEXE350d.PPD"
*Product: "(Lexmark E350d - English)"
*PSVersion: "(3010.010) 20020903"
*Manufacturer: "Lexmark"
*ModelName: "Lexmark E350d - English"
*ShortNickName: "Lexmark E350d - en"
*NickName: "Lexmark E350d (English)"
*1284DeviceID: "MFG: Lexmark International ;MDL: Lexmark E350d"
Und:
/etc/cups/printers.conf
zeigt:
# Printer configuration file for CUPS v1.2.2
# Written by cupsd on 2007-11-29 21:24
<DefaultPrinter alexanders_printer>
Info Lexmark Lexmark E350d - en
Location alex's__home_office
DeviceURI parallel:/dev/lp0
State Running
StateTime 1196367714
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
AllowUser alexander
AllowUser lp
AllowUser lpadmin
AllowUser cupsys
AllowUser syslog
AllowUser root
Allow From All
OpPolicy default
</Printer>
<Printer tmpprinter_zrQLPChK>
Info tmpprinter_zrQLPChK
Location home_office
DeviceURI file:/dev/null
State Running
StateMessage Paused
StateTime 1196367848
Accepting Yes
Shared Yes
#JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
#ErrorPolicy stop-printer
</Printer>
Lieber fishmac,
wie soll ich weiter vorgehen, sodass ich meinen Drucker wider sehe, im KDE-?Menu for the print system?, etc.?
Vielen Dank, im Voraus.
