get-edid | parse-edid
Code:edid-decode /sys/class/drm/card0-eDP-1/edid
$ edid-decode /sys/class/drm/card0-LVDS-1/edid
Extracted contents:
Manufacturer: LGD Model 2d8 Serial Number 0
Made week 0 of 2010
EDID version: 1.3
Digital display
Maximum image size: 28 cm x 16 cm
Gamma: 2.20
DPMS levels: Standby Suspend Off
Supported color formats: RGB 4:4:4, YCrCb 4:4:4
First detailed timing is preferred timing
Established timings supported:
Standard timings supported:
Detailed mode: Clock 75.200 MHz, 277 mm x 156 mm
1366 1414 1478 1582 hborder 0
768 772 779 792 vborder 0
+hsync -vsync
Manufacturer-specified data, tag 0
[b]ASCII string: LG
ASCII string: LP125WH2-SLB1[/b]
Checksum: 0x84 (valid)
EDID block does NOT conform to EDID 1.3!
Missing name descriptor
Missing monitor ranges
Detailed block string not properly terminated
[root]~ # grep -2 "EDID (in hex):" /var/log/Xorg.0.log | head -n 3
[ 45.548] (II) intel(0): Unknown vendor-specific block f
[ 45.548] (II) intel(0): LTD141EN9B
[ 45.548] (II) intel(0): EDID (in hex):
[root]~ #
[ 120.249] (II) modeset(0): Unknown vendor-specific block f
[ 120.249] (II) modeset(0): LTN141P4-L02
[ 120.249] (II) modeset(0): EDID (in hex):
[root]~ #
[ 22.929] (II) modeset(0): BOE HYDIS
[ 22.929] (II) modeset(0): HV150UX1-101
[ 22.929] (II) modeset(0): EDID (in hex):
[root]~ #
Dein Optimismus ist unbegründetDürfte vermutlich auf beliebigen Notebooks genauso funktionieren.
stimmt:Bei neueren Versionen von X liegen die Logs in ~/.local/share/xorg.
[ 29.345] (**) Option "xkb_rules" "evdev"
[ 29.345] (**) Option "xkb_model" "microsoftpro"
[ 29.345] (**) Option "xkb_layout" "de"
[ 29.345] (**) Option "xkb_variant" "nodeadkeys"
[ 29.345] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 29.825] (II) intel(0): EDID vendor "LGD", prod id 1049
[ 29.825] (II) intel(0): Printing DDC gathered Modelines:
[ 29.825] (II) intel(0): Modeline "2560x1440"x0.0 237.80 2560 2608 2640 2720 1440 1442 1445 1457 +hsync -vsync (87.4 kHz eP)
[ 404.174] (II) evdev: ThinkPad Extra Buttons: Close
