$ cat BOE1404_HV150UX1-101.txt
Monitor
Windows description...... Generic PnP Monitor
Manufacturer............. BOE
Plug and Play ID......... BOE1404
Data string.............. HV150UX1-101
Serial number............ n/a
Manufacture date......... 2005, ISO week 0
Filter driver............ Monitor
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 300 x 220 mm (14.6 in)
Power management......... Not supported
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.574 - Ry 0.336
Green chromaticity....... Gx 0.298 - Gy 0.553
Blue chromaticity........ Bx 0.149 - By 0.139
White point (default).... Wx 0.303 - Wy 0.329
Additional descriptors... None
Timing characteristics
Range limits............. Not available
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1600x1200p at 60Hz (4:3)
Modeline............... "1600x1200" 162.000 1600 1664 1856 2160 1200 1201 1204 1250 -hsync -vsync
Standard timings supported
Report information
Date generated........... 8/3/2011
Software revision........ 2.60.0.964
Data source.............. Registry-Active
Operating system......... 6.0.6002.2.Service Pack 2
Raw data
00,FF,FF,FF,FF,FF,FF,00,09,E5,04,14,00,00,00,00,00,0F,01,03,80,1E,16,78,0A,06,69,93,56,4C,8D,26,
23,4D,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,48,3F,40,30,62,B0,32,40,40,C0,
13,00,30,E4,10,00,00,19,00,00,00,FE,00,20,0A,20,20,20,20,20,20,20,20,20,20,20,00,00,00,FE,00,42,
4F,45,20,48,59,44,49,53,0A,20,20,20,00,00,00,FE,00,48,56,31,35,30,55,58,31,2D,31,30,31,0A,00,81
