Moin war grad ma auf ibm.de und wollt ma son bisschen gucken, da klick ich auf "detect my system" und es kommt folgende meldung:
Our apologies
Unable to determine your system configuration. Please use your browser's Back button to return to the previous page and navigate manually.
If you are not using Microsoft Internet Explorer
You may be receiving this error because your browser does not support ActiveX controls.
If you are using Microsoft Windows XP Service Pack 2
You may be receiving this error because you need to install an ActiveX control.
To install the ActiveX control and take advantage of this IBM Support technology:
1. Click the security warning that appears at the top of this window. The warning will appear in a yellow box and should read: "The previous site might require the following ActiveX control: 'IBM Access Support' from 'International Business Machines, Inc.'. Click here to install." After you click this warning, a menu will appear.
2. Click "Allow this page to install ActiveX controls".
3. Follow the instructions that appear to finish installing the ActiveX control.
hä????
Kennt das wer?
Our apologies
hä????
Kennt das wer?
