Alle Schleppi- und ACPI-Pakete
Bei welchen Modellen ist hdaps Unterstützt
thinkpad-base - Configuration files for thinkpad-modules packages
thinkpad-source - Source code for thinkpad-modules packages
tpctl - ThinkPad hardware configuration tools
IBM specific ACPI driver
Unfortunately, special drivers for ACPI on ThinkPads were not included with kernels prior 2.6.10. So you'll have to compile one yourself or get it as precompiled module for your kernel.
You have the choice between thinkpad-acpi and ibm-acpi, with the latter being the recommended one.
If you use a post-2.6.10 kernel and you want to use ibm-acpi, it is recommended to look on its projects page for a possibly newer version.
