Compiling fehlgeschlagen (xrandr fehlt)
Akira
11 Apr. 2011
Ich habe nun schon allerhand Pakete nachinstalliert um endlich an diese Stelle zu kommen. Laut Google sind xrandr und xxf86vm in xorg enthalten. Dieses habe ich inzwischen ebenfalls installiert aber bekomme dennoch folgende Meldung:
user@REFUTE:~/mate-color-manager-1.8.1$ ./autogen.sh
/usr/bin/mate-autogen
/usr/bin/yelp-build
checking for autoconf >= 2.53...
  testing autoconf2.50... not found.
  testing autoconf... found 2.69
checking for automake >= 1.9...
  testing automake-1.14... found 1.14.1
checking for libtool >= 1.4.3...
  testing libtoolize... found 2.4.2
checking for glib-gettext >= 2.2.0...
  testing glib-gettextize... found 2.44.1
checking for intltool >= 0.25...
  testing intltoolize... found 0.51.0
checking for pkg-config >= 0.14.0...
  testing pkg-config... found 0.28
checking for gtk-doc >= 1.0...
  testing gtkdocize... found 1.21
Checking for required M4 macros...
Checking for forbidden M4 macros...
**Warning**: I am going to run `configure' with no arguments.
If you wish to pass any to it, please specify them on the
`./autogen.sh' command line.
Processing ./configure.ac
Running gtkdocize...
Running intltoolize...
Running autoreconf...
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force --warnings=no-portability -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
autoreconf: running: /usr/bin/autoconf --force --warnings=no-portability
autoreconf: running: /usr/bin/autoheader --force --warnings=no-portability
autoreconf: running: automake --add-missing --copy --force-missing --warnings=no-portability
autoreconf: Leaving directory `.'
Running ./configure ...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether make supports nested variables... (cached) yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking whether NLS is requested... yes
checking for intltool >= 0.35.0... 0.51.0 found
checking for intltool-update... /usr/bin/intltool-update
checking for intltool-merge... /usr/bin/intltool-merge
checking for intltool-extract... /usr/bin/intltool-extract
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for perl... /usr/bin/perl
checking for perl >= 5.8.1... 5.20.2
checking for XML::Parser... ok
checking what warning flags to pass to the C compiler... -Wall -Wmissing-prototypes
checking what language compliance flags to pass to the C compiler...
checking for itstool... itstool
checking for xmllint... xmllint
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gtk-doc... yes
checking for gtkdoc-check... gtkdoc-check.test
checking for gtkdoc-check... /usr/bin/gtkdoc-check
checking for gtkdoc-rebase... /usr/bin/gtkdoc-rebase
checking for gtkdoc-mkpdf... /usr/bin/gtkdoc-mkpdf
checking whether to build gtk-doc documentation... no
checking for GTKDOC_DEPS... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for ngettext in libc... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... (cached) /usr/bin/msgfmt
checking for dcgettext... yes
checking if msgfmt accepts -c... yes
checking for gmsgfmt... (cached) /usr/bin/msgfmt
checking for xgettext... (cached) /usr/bin/xgettext
checking for pkg-config... (cached) /usr/bin/pkg-config
checking pkg-config is at least version 0.16... yes
checking for GLIB... yes
checking for XORG... no
configure: error: Package requirements (xxf86vm xrandr) were not met:
No package 'xxf86vm' found
No package 'xrandr' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables XORG_CFLAGS
and XORG_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Ich versuche den Mate Color Manager unter Ubuntu Mate 15.04 zu installieren damit ich Farbprofile anbringen kann. Ich habe die neueste Version von hier heruntergeladen: https://github.com/raveit65/mate-color-manager/tags
Kann jemand weiterhelfen?
sind die Pakete libxxf86vm-dev und libxrandr-dev installiert ?
Entscheidend ist, ob es die Header findet. Eventuell musst du bei deiner Distri noch separate Development-Pakete installieren.
Das Programm (warum per Hand kompilieren?!) brauchst du aber nicht für Farbprofile. Argyll CMS alleine (ggf. mit colord) kann das wunderbar. (Hilfe durchlesen.)
Danke, das waren also die Paketnamen. Meine Googelei hat mich irgendwie zu xorg gebracht. Jetzt wäre der Fehler beseitigt aber jetzt beschwert er sich mit
configure: error: Package requirements (gtk+-2.0 >= 2.14.0) were not met:
No package 'gtk+-2.0' found
Wie kann man es sonst komplilieren?
Agryll muss man scheinbar auch manuell einrichten aber wenn das mit dem Mate Color Dingens nichts wird dann versuche ich es mal. Braucht man ein Colorimeter dafür? Oder funktioniert Agryll auch als standalone um ICC Profile einzubinden die ich bereits besitze?
EDIT: Als Linux n00b kann ich lediglich den ersten Zeilen der Agryll Installation folgen. Danach blicke ich nicht mehr durch. Ich weiß nicht mal was für mich relevant ist und was ich nach dem Entpacken der Dateien tun soll sehe ich auch nirgends.:confused:
http://www.argyllcms.com/doc/Installing_Linux.html
Ist argyll nicht in den Ubuntu 15.10 Quellen? Ansonsten hilft dir vielleicht dispcalgui weiter?
Tatsache, dispcalgui kann das Profil einbinden und lädt es auch automatisch beim hochfahren. Also genau das was ich gesucht habe. Danke für den Tipp!
Und rate mal, was von dispcalgui genutzt wird… genau, Argyll. Natürlich ist das in den Paketquellen. Um ein Profil (bzw. die Kalibrierung daraus) zu laden, einfach
$ dispwin xyz.icc
ausführen.
Falls hier jemand mit der Suchfunktion vorbeikommt: dieser Fehler sollte mit dem Paket libgtk2.0-dev behoben sein.
Under 14.04 hat das schon die Version 2.24.23:
$ dpkg -l | grep libgtk2.0-dev
ii  libgtk2.0-dev                               2.24.23-0ubuntu1.3                         amd64        development files for the GTK+ library
Wenn sich autoconf bzw. configure über fehlende (Library-)Pakete beschweren, sind fast immer die *-dev gemeint. Alternativ fehlen mitunter auch Tools.
