Bluetooth Treiber, Windows XP, nur alte Treiber funktionsfähig?
xsid
29 Mai 2007
auf Lenovo Seite werden für mein T61 zwei Treiber für Bluetooth bei Windows XP angeboten.
Treiber 1:
77bm03ww.exe (326,29 KB)
ThinkPad January 31, 2008
Microsoft Bluetooth Support file for Bluetooth with Enhanced
Data Rate for Windows XP
Version 2.00
Notice:
This program is language independent and can be used with any language
system.
What This Package Does
This package provides the Microsoft Bluetooth support file for
ThinkPad Bluetooth with Enhanced Data Rate.
The package enables the Bluetooth functions provided by Microsoft for
the following ThinkPad computers integrated with Bluetooth
functionality.
This release supports the following systems with Bluetooth:
- ThinkPad R60, R60e, R61, R61e, R61i
- ThinkPad T60, T60p, T61, T61p
- ThinkPad X300
- ThinkPad X60, X60s, X61, X61s
- ThinkPad X60 tablet (*1), X61 tablet (*1)
- ThinkPad Z60m, Z60t, Z61e, Z61m, Z61p, Z61t
Refer to marketing materials to find out what ThinkPad models support
which Operating Systems.
(*1) Supports Windows XP Tablet PC Edition 2005
To determine if you should update the Bluetooth software, refer to the
"Summary of Changes" section.
To update the Bluetooth software, refer to the "Installation
Instructions" section.
Released Versions
Version 2.00 Initial release
Summary of Changes
Where: Version number
(New) New function or enhancement
(Fix) Correction to existing function
<2.00>
- (New) Initial release for ThinkPad Z60t, Z60m.
- (New) Support for ThinkPad T60, T60p.
- (New) Support for ThinkPad X60, X60s.
- (New) Support for ThinkPad R60, R60e, Z61t, Z61m, Z61e.
- (New) Support for ThinkPad Z61p.
- (New) Support for ThinkPad X60 Tablet.
- (New) Support for ThinkPad R61, T61.
- (New) Support for ThinkPad R61e, R61i, T61p.
- (New) Support for ThinkPad X300.
Installation Instructions
ThinkPad Bluetooth with Enhanced Data Rate Software is already
installed on your ThinkPad preload. Uninstall the software from
Add/Remove Programs in Control Panel or by using ThinkPad Software
Installer to enable Microsoft Bluetooth software.
Microsoft Windows XP
Uninstall instructions for ThinkPad Bluetooth with Enhanced Data Rate
Software
1. Click Start, click Control Panel, then double-click Add or Remove
Programs.
2. Select "ThinkPad Bluetooth with Enhanced Data Rate Software" and
click Remove.
3. Click Yes when prompted, "Are you sure you want to remove ThinkPad
Bluetooth with Enhanced Data Rate Software from your computer?"
4. The uninstall process will begin.
5. Click OK when prompted to restart your system.
Installation instructions
1. Start Windows XP.
2. Verify that Windows XP Service Pack 2 is installed.
3. Turn the Bluetooth power on.
4. If the "Found New Hardware Wizard" window is opened, select
"Install from a list of specific location (Advanced)" and click
Next.
5. Select "Search for the best driver in these locations:", check
"Include this location in the search", and enter the location you
put the Microsoft Bluetooth support file into.
6. Click Next.
7. The driver will be installed automatically.
Trademarks
* ThinkPad is a registered trademark of Lenovo.
* The Bluetooth word mark and logos are owned by the Bluetooth SIG,
Inc.
* Microsoft and Windows are registered trademarks of Microsoft
Corporation.
Other company, product, and service names may be registered trademarks,
trademarks or service marks of others.
Treiber 2:
7vba11ww.exe (102,3 MB)
RRevision : 02
Software Name Bluetooth with Enhanced Data Rate Software II
Support models ThinkPad R400
ThinkPad R500
ThinkPad T400, T400s
ThinkPad T500
ThinkPad W500
ThinkPad W700, W700ds
ThinkPad X200, X200s, X200 Tablet
ThinkPad X300(*1), X301
ThinkPad SL300
ThinkPad SL400
ThinkPad SL500
ThinkPad R60(*1), R60e(*1)
ThinkPad R61(*1), R61e(*1), R61i(*1)
ThinkPad T60(*1), T60p(*1), T61(*1), T61p(*1)
ThinkPad X60(*1), X60s(*1), X60 Tablet(*1)
ThinkPad X61(*1), X61s(*1), X61 Tablet(*1)
ThinkPad Z60m(*1), Z60t(*1)
ThinkPad Z61e(*1), Z61m(*1), Z61p(*1), Z61t(*1)
Operating Systems Microsoft Windows XP Home Edition, Professional
Microsoft Windows XP Tablet PC Edition 2005
Refer to marketing materials to find out what computer models
support which Operating Systems.
Version 5.5.0.6400
Support devices ThinkPad Bluetooth with Enhanced Data Rate
ThinkPad Bluetooth 2.1 with Enhanced Data Rate
*1: Does not work as Bluetooth 2.1 (Bluetooth 2.0 + Enhanced Data Rate, 3Mbps),
but works as Bluetooth 1.2 (1Mbps).
WHAT THIS PACKAGE DOES
This package installs the software (Bluetooth with Enhanced Data Rate Software)
to enable the following devices.
- ThinkPad Bluetooth with Enhanced Data Rate
- Thinkpad Bluetooth 2.1 with Enhanced Data Rate
However, some models do not support Bluetooth 2.1 due to a hardware
restriction.
Refer to marketing materials to find out what computer models support which
devices.
If this package has been installed, updating (overwrite-installing) this
package will fix problems, add new functions, or expand functions as noted
below.
This program is language independent and can be used with any language system.
CHANGES IN THIS RELEASE
Version 5.5.0.6400
[Important updates]
Nothing.
[New functions or enhancements]
- Added support for ThinkPad T400s.
[Problem fixes]
- Fixed an issue where the computer could not be ejected from ThinkPad UltraBase
when a USB printer was attached to ThinkPad UltraBase and Bluetooth was on.
DETERMINING WHICH VERSION IS INSTALLED
1. Open My Bluetooth Places.
2. Select Help, then select About My Bluetooth Places.
3. The first line of pop-up window shows the version of the software.
In this release, "My Bluetooth Places 5.5.0.6400"
The driver version of "ThinkPad Bluetooth with Enhanced Data Rate" in the
device manager is 5.5.0.6500 in this release.
NOTES
Nothing.
INSTALLATION INSTRUCTIONS
Notes:
- If your computer runs satisfactorily now, it may not be necessary to update
the software. To determine if you should update the software, refer to the
Version Information section.
- During the installation, please do not touch the keyboard, the trackpoint and
the mouse.
- Some of the virtual devices are installed when you use the Bluetooth software
for the first time after you install it. Wait for a while until the virtual
devices installation completes.
Manual Install
1. Start Windows XP and logon with administrative privileges.
2. Press Fn and F5 at the same time to turn on Bluetooth.
3. If 'Found New Hardware Wizard' is displayed, click Cancel.
4. Double-click the driver package to extract it to your hard drive.
The default location is C:\DRIVERS\WIN\TPBTOOTH.
5. Click Start, then click Run...
6. Specify "SETUP.EXE" with the full path name where you extracted the package
in step 4, and click OK.
Example: C:\DRIVERS\WIN\TPBTOOTH\SETUP.EXE
7. In "Welcome to the InstallShield Wizard for ThinkPad Bluetooth with
Enhanced Data Rate Software" window, click Next.
8. In the "License Agreement" window, read the Licence Agreement carefully, if
you agree, select "I accept the terms in the licence agreement" then click
Next.
9. In the Destination Folder window, click Next. (If you need to change the
destination, click Change, select or enter the destination folder of your
choice, then click Next.)
10. In the "Ready to Install the Program" window, click Install.
11. When "Driver Signature Notice" window appears, click OK.
Note: During the installation, do not touch the keyboard, the TrackPoint,
and the mouse.
12. When "InstallShield Wizard Completed" appears, click Finish.
13. If you are asked to restart the system, click Yes to restart.
Unattended Install
This is for system administrators' use only.
2. Double-click the driver package to extract it to your hard drive.
The default location is C:\DRIVERS\WIN\TPBTOOTH\.
3. Click Start, then click Run.
4. Specify SETUP.EXE /qn /ru /ri with the full path name where you extracted
the package in the step 2, and click OK.
Example: C:\DRIVERS\WIN\TPBTOOTH\SETUP /qn /ru /ri
UNINSTALLATION INSTRUCTIONS
Manual Uninstall
1. Click Start, click Control Panel, then double-click Add or Remove Programs.
2. Select ThinkPad Bluetooth with Enhanced Data Rate Software and click
Change/Remove.
3. In the prompt 'Are you sure you want to remove ThinkPad Bluetooth with
Ehnanced Data Rate Software from your computer?' appears, click Yes.
Uninstallation will start.
4. Click OK to restart the computer.
VERSION INFORMATION
The following versions have been released to date.
Version Rev. Issue Date
5.5.0.6400 02 2009/06/11
5.5.0.6400 01 2009/02/20
5.5.0.5800 01 2009/01/19
5.5.0.4300 02 2009/01/09
5.5.0.4300 01 2008/11/18
5.5.0.4300 14th release
5.5.0.3500 13th release
5.5.0.3100 12th release
5.1.0.4700 11th release
5.1.0.4500 10th release
5.1.0.3100 9th release
5.1.0.2100 8th release
5.0.1.3200 7th release
5.0.1.2900 6th release
5.0.1.2800 5th release
5.0.1.1500 4th release
4.0.1.3000 3rd release
4.0.1.2600 2nd release
4.0.1.2302 Initial release
Note: Revision number (Rev.) is for administrative purpose of this README
document and is not related to software version. There is no need to
upgrade this software when the revision number changes.
To check the version of software, refer to the Determining which version is
installed section.
Summary of Changes
Where: < > Version number
[Important] Important update
<5.5.0.6400>
- (New) Added support for ThinkPad T400s.
<5.5.0.6400>
- (Fix) Fixed an issue where the computer could not be ejected from ThinkPad
UltraBase when a USB printer was attached to ThinkPad UltraBase and
Bluetooth was on.
<5.5.0.5800>
- (Fix) Fixed an issue where Microsoft Excel was crashed with the Bluetooth
driver when the Regional option is Italian (Italy) or France (French).
<5.5.0.4300>
- (New) Support for ThinkPad W700ds (added).
- (Fix) Bluetooth Fax does not work.
- (New) Support for ThinkPad X200s,X200 Tablet.
<5.5.0.3500>
- (Fix) Discovering devices still present in BT Help Topic.
- (Fix) Pairing Failed message even after successful pairing with Bluetooth
printer.
<5.5.0.3100>
- (New) Support for ThinkPad SL300/SL400/SL500.
- (New) Supports ThinkPad T400/T500/R400/R500/W500/X200.
- (New) Supports ThinkPad W700/X301.
- (New) Support Bluetooth 2.1 features (with systems with ThinkPad Bluetooth
2.1 with Enhanced Data Rate only).
- (Fix) Terminated Windows 2000 support.
<5.1.0.4700>
- (Fix) If a user ID has a full registry access, the system became very slow.
<5.1.0.4500>
<5.1.0.3100>
- (New) Support for the ThinkPad R61/R61e/R61i/T61/T61p.
- (Fix) Print server function cannot be used from Windows Vista.
- (Fix) Configuring Bluetooth printer sometimes fails with an error.
- (Fix) Network Adapter configuration button in Bluetooth Configuration
sometimes does not work
<5.1.0.2100>
- (New) Support for the ThinkPad X60 Tablet.
- (New) Hands Free Profile to provide HFP functions for VOIP applications.
<5.0.1.3200>
- (Fix) With ThinkPad R52/T43/T43p/X32/X40/X41/X41 tablet, Bluetooth stops
responding after log-off and log-on.
<5.0.1.2900>
- (Fix) Bluetooth Exchange Folder may not setup correctly when installed in a
certain environment.
- (Fix) With ThinkPad with integrated Camera, the system sometimes fails to
enter suspend mode.
<5.0.1.2800>
- (Fix) Sometimes fails to make a PAN connection with Linux devices.
<5.0.1.1500>
- (New) Support for ThinkPad Z61e/Z61m/Z61t/R60/R60e.
<4.0.1.3000>
- (Fix) The memory usage of Bluetooth Task Tray (BTTray.exe) increases along
with typing NumLock(NumLk) key.
- (New) Design change not to install virtual devices until the user starts
using the software for the first time.
- (New) Support for ThinkPad T60/T60p.
- (New) Support for ThinkPad X60/X60s.
- (New) Support for ThinkPad R52/T43/T43p/X32/X41/X41 tablet.
<4.0.1.2600>
- (Fix) The Headset profile sometimes does not work properly on Windows 2000.
<4.0.1.2302>
- (New) Initial release for ThinkPad Z60t/Z60m.
TRADEMARKS
* Lenovo and ThinkPad are registered trademarks of Lenovo.
* UltraBase is a trademark of Lenovo.
* The Bluetooth word mark and logos are owned by the Bluetooth SIG, Inc.
* Excel, Microsoft and Windows are registered trademarks of Microsoft
Corporation.
Wenn ich den Treiber 1. aus der 77bm03ww.exe verwende wird mir in den Netzwerkverbindungen eine mögliche PAN Bluetooth Netzwerkverbindung angeboten.
Bei Treiber 2. werden mir viele andere mögliche Netzwerkverbindungen angeboten, jedoch keine PAN Bluetooth Netzwerkverbindung. Das obwohl die Treiber Originaldatei um vielfaches größer ist als die von Treiber 1.
Für welchen Einsatzzweck ist Treiber 1. sinnvoll?
Für welchen Einsatzzweck ist Treiber 2. sinnvoll?
Wie kann ich beim neueren Treiber ein PAN Netzwerk aufbauen?
BG xsid
Erfahrung Saugblaser
Hi Saugblaser,
hast Du jetzt evtl. auch die neueren Bluetooth Treiber zu verweden?
[T6*] [gelöst]: Bluetooth-Gerät defekt ?
War dein Problem definitiv nur durch die Verwendung aktueller Treiber entstanden?
BG xsid
der neue treiber sollte auch gehen, nur zickt der irgendwie rum.
bei mir war der erst entgueltig installiert, nachdem ich ihn mehrmals installiert hatte und einige reeboots.
ein com geraeht sollte der auch einrichten oder man kann es uber die treibereigenschafften hinzufuegen.
der treiber ist recht neu, denke der hat einen kleinen fehler irgendwo,
greeTz lyvi
Treibergröße
Hi lyvi,
was mich auch verwundert ist die unterschiedliche Treibergröße von 400 kB bzw. 110 MB.
Der Mehrwert der neuen Treiberlösung muß also gigantisch sein.
Kannst Du mit dem neuen Treiber ein PAN Netz einrichten?
Oder wird beim neuen Treiber eine andere Bezeichnung für ein PAN Netz verwendet?
Eine Vielzahl von weiteren Sybmbolen bzw. Möglichkeiten erhalte ich ja mit dem neuen Treiber. Mit BT habe ich bisher sehr wenig Erfahrung.
BG xsid
kann ich dir grad nicht sagen sitze am x61s vista meist benutze ich usb kabel.
bin nur ueber das selbe problem gestolbert bei der neuinstallation meiner kiste.
hast du den SP3 da wurde einiges geaendert im bluetooth stack?
Nach der Installation von Windows XP Service Pack 2 werden Bluetooth-Geräte nicht korrekt installiert
anstell Pan bluethooth wird treiber fuer bluethooth lan zugansgserver oder so aehnlich angezeigt.
greeTz lyvi
