Ist auch der Schiebeschalter an der Notebookvorderseite an?
Hast Du auch die Installationsanweisungen strikt befolgt?
Installation instructions
If any previous or current version of ThinkPad Bluetooth with Enhanced Data Rate Software is already installed on your ThinkPad, uninstall the software using Add/Remove Programs in the Control Panel before installation.
Notes:
* During the installation, please do not touch the keyboard, the trackpoint, or the mouse.
* ThinkVantage System Update provides install/(uninstall) wizard for this package. Before using ThinkVantage System Update, you have to uninstall the previous or current software using Add/Remove Programs in the Control Panel or by using ThinkVantage System Update.
* Some of the virtual devices are installed when you use the Bluetooth software after the first installation. Wait for a while until the virtual devices installation completes.
1. Start Windows XP, 2000 and logon with administrative privileges.
2. Press Fn and F5 at the same time to turn on Bluetooth.
3. If 'Found New Hardware Wizard' is displayed, click Cancel.
4. Double-click the driver package to extract it to your hard drive.
The default location is C:\DRIVERS\WIN\TPBTOOTH
5. Click Start, then click Run...
6. Specify "SETUP.EXE" with the full path name where you extracted the package in step 4, and click OK.
Example: C:\DRIVERS\WIN\TPBTOOTH\SETUP.EXE
7. In "Welcome to the InstallShield Wizard for ThinkPad Bluetooth with Enhanced Data Rate Software" window, click Next.
8. In the "License Agreement" window, read the Licence Agreement carefully, if you agree, select I accept the terms in the licence agreement, then click Next.
9. In the Destination Folder window, click Next. (If you need to change the destination, click Change, select or enter the destination folder of your choice, then click Next.)
10. In the "Ready to Install the Program" window, click Install.
11. When "Driver Signature Notice" window appears, click OK.
12. When "InstallShield Wizard Completed" appears, click Finish.
13. If you are asked to restart the system, click Yes to restart.
