T440p Bios - Version 2.47 ----- ThinkPad T440p
xsid
29 Mai 2007
Bios - Version 2.51 ----- ThinkPad T440p
Hallo wartende, geplagte, genervte User,
endlich:
Auf US-Site achten!
https://pcsupport.lenovo.com/uu/en/...pad-t-series-laptops/thinkpad-t440p/downloads
        Revision : 01
Software name      BIOS Update CD
                   (ISO image file for bootable CD)
Support model      ThinkPad T440p
Operating Systems  Microsoft Windows 10  64-bit
                   Microsoft Windows 8.1  64-bit
                   Microsoft Windows 8  64-bit
                   Microsoft Windows 7  32-bit, 64-bit
                   Refer to marketing materials to find out what computer models
                   support which Operating Systems.
Version            2.47
WHAT THIS PACKAGE DOES
  This package provides the ISO image file of UEFI BIOS which is compatible with
  CD/DVD/BD writing software to create the CD/DVD/BD for the UEFI BIOS update.
  Hereafter the CD/DVD/BD for the UEFI BIOS update is called as "BIOS Update CD".
  The BIOS Update CD can boot the computer disregarding the operating systems
  and update the UEFI BIOS (including system program and Embedded Controller
  program) stored in the ThinkPad computer to fix problems, add new functions,
  or expand functions as noted below.
  For that purpose, it is necessary to have the CD/DVD/BD writing software (with
  CD/DVD/BD creation function from the ISO image file) prepared separately.
  Also, the following type of CD-RW, CD-RW & DVD Combo, DVD, DVD Multi, BD or
  other optical drives should be prepared. (Hereafter these drives are called as
  "optical drive".)
  - USB
  This program is language independent and can be used with any language system.
CHANGES IN THIS RELEASE
  Version 2.47
[Important updates]
- Nothing
[New functions or enhancements]
- Updated the CPU microcode.
[Problem fixes]
- Nothing
Viel Spaß und gutes Vertrauen.
MfG
xsid
Das kann gut sein, mein Vertrauen ist irgendwie dahin.
Aufspielen würde ich die FW auf jeden Fall.
Leider noch nichts für T440 & T440s
Spectre 2 Fix #2 enthalten oder deaktiviert ?
Ja schlimmer als 2.46 kann es eigentlich nicht seien ...
NOTES
- If the UEFI BIOS has been rolled back to version 2.47 from higher version,
CPU microcode (MCU) is also rolled back to older version than the one addressed
for CVE-2017-5715.
- If the UEFI BIOS has been updated to version 2.44 or higher, it is no longer
able to roll back to the version before 2.44 for security improvement.
Habe Gott sei Dank bei 2.46 abgewartet und es nicht installiert - und warte jetzt auch erstmal noch mit 2.47 bis es gesicherte Erfahrungsberichte gibt...
Hallo, bei mir funktioniert die Version 2.47 bis jetzt einwandfrei.
Auch mit der Boot-CD sagt er, dass ein Update nicht notwendig ist.
2.46 ist installiert.
Was meldet den SpecuCheck o.ä. jetzt ?
Microsoft hat den Patch ja softwareseitig auch erstmal wieder deaktiviert neulich ...
https://github.com/ionescu007/SpecuCheck/releases
ev. noch die alten Dateien vom Server bekommen ?
Ja, alles gut.
Page sagte 2.47, Download war trotzdem 2.46 - jetzt installiert und wird getestet ^^
Danke :D
SpecuCheck:
O.k. dann hat Lenovo das Microcodeupdate also erstmal deaktiviert :thumbup:
- jetzt warte ich auf 2.47 für das T440 ...
In den Zusammenhang vielleicht nicht gänzlich uninteressant:
Neue Firmware für die SSD.
https://pcsupport.lenovo.com/us/en/...APTOPS/THINKPAD-T440P/20AN/downloads/DS038904
Ja, aber wohl nur für die von Intel:
"CHANGES IN THIS RELEASE
Release FWSD45
Model Firmware
[ Intel ]
SSDSC2KF256H6L LBFL16P/LSFL43P
SSDSC2KF180H6L LBFL16P/LSFL43P
SSDSC2KF240H6L LBFL16P/LSFL43P
SSDSC2KF360H6L LBFL16P/LSFL43P
SSDSC2KF480H6L LBFL16P/LSFL43P
SSDSCKKF256H6L LBFL16P/LSFL43P
SSDSCKKF180H6L LBFL16P/LSFL43P
SSDSCKKF240H6L LBFL16P/LSFL43P
SSDSCKKF360H6L LBFL16P/LSFL43P
Ja, wobei er bei der in meinem T440p verbauten Samsung auch ein Update durchgeführt hat, der Bildschirmanzeige nach :D
Ich war mir eigentlich fast sicher, die FW wäre aktuell gewesen.
BIOS 2.51 ist raus.
Bei mir SSD Performance deutlich verbessert lt. ASSSD - insbesondere die Zugriffszeit.
HT kann jetzt lt. Changelog ab- oder angeschaltet werden.
Schauen wir mal ob es sonst noch was ändert :)
